Cannot connect to SSID
  • 1.  Cannot connect to SSID
    Posted Nov 15, 2015 11:59 AM
    Hi all,
    I trying to configure SSID "aruba_demo" and "arubanetworks"  as in the picture with the OS version 6.4.3.1-4.2.0.2_52056. They are both use the same configuration but i can only connect to the second, with "arubademo" i receive this
    Does anyone has the same prolem?
    Please help me with this.
    Duc Nguyen.
  • 2.  RE: Cannot connect to SSID
    Posted Nov 15, 2015 12:00 PM
    We need more information.  Is there authentication or encryption on this SSID?
  • 3.  RE: Cannot connect to SSID
    Posted Nov 15, 2015 01:34 PM
    Hi Joseph,
    I just used pre shared key, ip managed by virtual controller or network are the same problem. When i created SSID "aruba_demo" there wasn't any notifications appeared.
    Duc Nguyen.
  • 4.  RE: Cannot connect to SSID
    Posted Nov 15, 2015 02:41 PM
    Try using Virtual Controller Managed and Client VLAN assignment of Default.
