Cannot delete 'guest' WLAN
  • 1.  Cannot delete 'guest' WLAN
    Posted Mar 10, 2013 04:11 PM
    I'm trying to delete a WLAN that as been configured as a guest network. However, when I use the wizard to modify the settings, I get the following error. Can anyone help me please?
    guest has been modified such that it is no longer editable from this Wizard. REASON: Required CP portal profile missing..
    Use the full Configuration user interface to edit it.
    Thanks in advance.
  • 2.  RE: Cannot delete 'guest' WLAN
    Posted Mar 10, 2013 05:05 PM
    Here is what you can do:
    Go to configuration> Wireless LAN> AP Configuration.
    Edit the Ap-group that you added the WLAN to.  Expand Wireless Lan> Click on Virtual AP.  In the Right pane, click on "Delete" next to the Virtual AP you want to go away..
  • 3.  RE: Cannot delete 'guest' WLAN
    Posted Mar 10, 2013 05:36 PM
    Many thanks for your quick response. All sorted now!
