Network Management
Cannot delete or unignore device in Airwave
  • 1.  Cannot delete or unignore device in Airwave
    Posted Sep 22, 2015 09:01 AM
    I'm trying put back in the new device list a device that was once ignored.
    In the webUI neither the delete button or unignore works, clicking on them will only show me a message about the licensing. As shown on the screenshot bellow :
    Here's the result of clicking on one of those button :
    Can anyone help ?
  • 2.  RE: Cannot delete or unignore device in Airwave
    Posted Sep 22, 2015 09:03 AM
    Looks like you're out of licenses. You'll need to add more or delete some existing devices.
    Tim
  • 3.  RE: Cannot delete or unignore device in Airwave
    Posted Sep 22, 2015 09:06 AM
    I'm not out of licences, as you can see I'm at 98% of my limit, with still 31 remaining licenses.
    Adding new devices from the "New devices" list still works alright.
  • 4.  RE: Cannot delete or unignore device in Airwave
    Posted Sep 23, 2015 02:52 PM
    For anyone looking for a fix to this problem, i got it from Aruba Support :
    #dbc 'update ap set state = 0 where state =3;'
    The corresponding command will move the all the APs in Ignored List to New Devices List.
  • 5.  RE: Cannot delete or unignore device in Airwave
    Posted Sep 25, 2015 01:18 PM
    That's surprising since I'm able to both unignore and delete.  What version of AirWave code are you running?  I tested on 8.0.9
  • 6.  RE: Cannot delete or unignore device in Airwave
    Posted Sep 30, 2015 09:57 AM
    I had the problem on version 8.0.9, then trying to fix it I upgraded to 8.0.9.1, still the same problem.
    It seems the problem only appear when you are using 95% or more licences.
  • 7.  RE: Cannot delete or unignore device in Airwave
    Posted Jan 04, 2016 01:40 PM
    Sorry to drum up an old topic, but I just ran into this issue this morning.  I am using 93% of my licenses.
    Running 8.0.9.1, I am unable to unignore or delete devices in my ignore list.
  • 8.  RE: Cannot delete or unignore device in Airwave
    Posted Jan 04, 2016 02:14 PM
    Do you happen to know how many ignored devices you have?  Did you try setting all ignored devices to new devices?
    #dbc 'select count(*) from ap where state = 3;'
    #dbc 'update ap set state = 0 where state = 3;'
  • 9.  RE: Cannot delete or unignore device in Airwave
    Posted Jan 04, 2016 02:17 PM
    I had 129 ignored devices.  I was able to set them all back to new using:
  • 10.  RE: Cannot delete or unignore device in Airwave
    Posted Sep 30, 2015 02:44 PM
    Mr Wind, this worked and my devices are now in the new category. Thanks!
