Skip to main content (Press Enter).
Register | Sign in
Skip auxiliary navigation (Press Enter).
Skip main navigation (Press Enter).
Toggle navigation
Discussion
Support
Aruba Documentation Portal
Aruba Support Knowledge Base
Community Learning
News
ACEX Hall of Fame
MVP Overview
Tech Corners
Search
Community Home
Discussion
Topic Thread
Community Home
Discussion
31K
Library
937
Events
0
Members
1.6K
Back to discussions
Expand all
Collapse all
sort by most recent
sort by thread
Cannot download firmware for Aruba AP 315/325
This thread has been viewed 24 times
1.
1
Kudos
martinsin
Posted Jun 28, 2022 11:36 AM
Reply Privately
Options Dropdown
I'm no able to download firmware for Aruba 315,325 from ASP with this server response:
Http failure response for
https://asp.arubanetworks.com/api/v1/files/RmlsZTo4MmZkNmIxNi1mM2YzLTExZWMtODUyYy00MzQ3NDRjNzAyMTI=/download/QWNjb3VudDo1MmY2NWEyNC1mNmE4LTExZWMtYjkxMC0wNzBkOGY5OTFmNjU=:
404 Not Found
On instant aruba controller on aps (over web interface) - Chceck for new Firmware button return
image_check_internal error 001 code 2
What's wrong wit it, any suggestions?
Best regards, Martin S.
2.
RE: Cannot download firmware for Aruba AP 315/325
1
Kudos
ariyap
Posted Jul 03, 2022 09:17 PM
Reply Privately
Options Dropdown
You can download the lifetime warranty firmware without a login. In order to do that, search for 'factory image' on ASP:
https://asp.arubanetworks.com/downloads;search=factory;products=Aruba%20Access%20Points
Original Message
Original Message:
Sent: Jun 28, 2022 02:49 AM
Subject: Cannot download firmware for Aruba AP 315/325
404 Not Found
New Best Answer
This thread already has a best answer. Would you like to mark this message as the new best answer?
Privacy policy
Terms of service
Site Map
Legal
© Copyright 2024 Hewlett Packard Enterprise Development LP
All Rights Reserved.
Powered by Higher Logic
