Cannot join Aruba 3000 Controller
  • 1.  Cannot join Aruba 3000 Controller
    Posted Nov 13, 2014 04:51 AM
    Hi all, My company has a set of Aruba Wifi system (Aruba 3000 Controller + 4 Aruba 93 AP). On Monday, whole server room devices were down caused building power supply issue. Most of services had been resumed. But the wifi service has problem: I can access Controller thru Web UI and all AP are standby, every setting seems find. But guest/staff cannot join to wifi network. We tired connect thru smart mobile phone or notebook, all failed with "Cannot Join to...". Furthermore, I don't know why around 10 devices connected and working properly. Except the 10 devices, all other devices cannot access the wifi. Please help. Many thanks. Best regards cncheung from Hong Kong
  • 2.  RE: Cannot join Aruba 3000 Controller
    Posted Nov 13, 2014 04:52 AM
    Connect to the controller using the console.  Login, then enter enable mode.
    Type "show log system 50" to see if you see anything.
  • 3.  RE: Cannot join Aruba 3000 Controller
    Posted Nov 13, 2014 05:55 AM
    (Aruba3200) #show log system 50
    Nov 13 18:26:30  KERNEL: 0:Parsing the partition  info
    Nov 13 18:26:30  KERNEL: 0:<5>cmdlinepart partition parsing not available
    Nov 13 18:26:30  KERNEL: 0:Adding partitions...
    Nov 13 18:26:30  KERNEL: 0:<5>Using physmap partition definition
    Nov 13 18:26:30  KERNEL: 0:<5>Creating 4 MTD partitions on "phys_mapped_flash":
    Nov 13 18:26:30  KERNEL: 0:<5>0x00000000-0x00200000 : "bootROM0"
    Nov 13 18:26:30  KERNEL: 0:<5>0x003c0000-0x003e0000 : "nvram-eeprom"
    Nov 13 18:26:30  KERNEL: 0:<5>0x003e0000-0x00400000 : "eeprom"
    Nov 13 18:26:30  KERNEL: 0:<5>0x00400000-0x00800000 : "pnoimg"
    Nov 13 18:26:30  KERNEL: 0:Intializing BK-3220 I2C Host Adapter...0:done.
    Nov 13 18:26:30  KERNEL: 0:i2c-palm-bk3220: Added I2C Bus 0
    Nov 13 18:26:30  KERNEL: 0:<6>i2c-nebbiolo: using default base 0xbd840000
    Nov 13 18:26:30  KERNEL: 0:Registering I2C based Power Supply driver...
    Nov 13 18:26:30  KERNEL: 0:Registering max6657 I2C based Temperature Sensor driver...
    Nov 13 18:26:30  KERNEL: 0:Registering powr6at6 I2C Power Trim Controller driver
    Nov 13 18:26:30  KERNEL: 0:Found POWR6AT6 on Palm Chip BK3220 Adapter 0
    Nov 13 18:26:30  KERNEL: 0:Registering max6640 I2C based Temperature Sensor driver...
    Nov 13 18:26:30  KERNEL: 0:Found MAX6640 on Palm Chip BK3220 Adapter 0
    Nov 13 18:26:30  KERNEL: 0:Registering Phoenix I2C based RTC driver...
    Nov 13 18:26:30  KERNEL: 0:<6>: Found DS1374 on Palm Chip BK3220 Adapter 0
    Nov 13 18:26:30  KERNEL: 0:Registering Phoenix I2C based TPM driver...
    Nov 13 18:26:30  KERNEL: 0:<6>GRE over IPv4 tunneling driver
    Nov 13 18:26:30  KERNEL: 0:<6>lo: Disabled Privacy Extensions
    Nov 13 18:26:30  KERNEL: 0:<6>IPv6 over IPv4 tunneling driver
    Nov 13 18:26:30  KERNEL: 0:<6>802.1Q VLAN Support v1.8 Ben Greear <greearb@candelatech.com>
    Nov 13 18:26:30  KERNEL: 0:<6>All bugs added by David S. Miller <davem@redhat.com>
    Nov 13 18:26:30  KERNEL: 0:<6>kjournald starting.  Commit interval 5 seconds
    Nov 13 18:26:30  KERNEL: 0:<6>EXT3 FS on hda3, 0:internal journal
    Nov 13 18:26:30  KERNEL: 0:<6>EXT3-fs: mounted filesystem with ordered data mode.
    Nov 13 18:26:30  KERNEL: 1:!!!!!!!PINOT BYPASS(1)!!!!!!!
    Nov 13 18:26:30  KERNEL: 1:<4>process `syslogd' is using obsolete setsockopt SO_BSDCOMPAT
    Nov 13 18:26:30  KERNEL: 0:<4>process `soed' is using obsolete setsockopt SO_BSDCOMPAT
    Nov 13 18:27:04 :399816:  <ERRS> |nanny|  Received the PAPI_APP_SPAWN_PROC Message
    Nov 13 18:27:09 :306510:  <WARN> |publisher|  Dropping message from 8214 for service '51 (service not found)'
    Nov 13 18:27:11  KERNEL: 2:<4>process `snmpd' is using obsolete setsockopt SO_BSDCOMPAT
    Nov 13 18:27:14 :306510:  <WARN> |publisher|  Dropping message from 8214 for service '51 (service not found)'
    Nov 13 18:27:15  KERNEL: 0:<4>process `trapd' is using obsolete setsockopt SO_BSDCOMPAT
    Nov 13 18:27:20 :311002:  <WARN> |AP AP2@192.168.1.54 sapd|  Rebooting: SAPD: Unable to contact switch. Called by sapd_hello_cb:4.  HBT miss seq_gen=7600 seq_snt=7600 seq_rcv=7592 218 sec before: Last Ctrl message: HELLO len=923 dest=192.168.1.52 tries=10 seq=0
    Nov 13 18:27:20 :303086:  <ERRS> |AP AP2@192.168.1.54 nanny| Process Manager (nanny) shutting down - AP will reboot!
    Nov 13 18:27:26 :304001:  <ERRS> |stm|  Unexpected stm (Station management) runtime error at data_path_handler, 642, data_path_handler: recv - Network is down
    Nov 13 18:27:26 :311002:  <WARN> |AP AP1@192.168.1.53 sapd|  Rebooting: SAPD: Unable to contact switch. Called by sapd_hello_cb:4.  HBT miss seq_gen=48797 seq_snt=48797 seq_rcv=48789 225 sec bef: Last Ctrl message: HELLO len=923 dest=192.168.1.52 tries=10 seq=0
    Nov 13 18:27:26 :303086:  <ERRS> |AP AP1@192.168.1.53 nanny| Process Manager (nanny) shutting down - AP will reboot!
    Nov 13 18:27:36 :311002:  <WARN> |AP AP4@192.168.1.56 sapd|  Rebooting: SAPD: Unable to contact switch. Called by sapd_hello_cb:4.  HBT miss seq_gen=48797 seq_snt=48797 seq_rcv=48789 233 sec bef: Last Ctrl message: HELLO len=923 dest=192.168.1.52 tries=10 seq=0
    Nov 13 18:27:36 :303086:  <ERRS> |AP AP4@192.168.1.56 nanny| Process Manager (nanny) shutting down - AP will reboot!
    Nov 13 18:27:45 :311002:  <WARN> |AP AP3@192.168.1.55 sapd|  Rebooting: SAPD: Unable to contact switch. Called by sapd_hello_cb:4.  HBT miss seq_gen=48796 seq_snt=48796 seq_rcv=48788 241 sec bef: Last Ctrl message: HELLO len=923 dest=192.168.1.52 tries=10 seq=0
    Nov 13 18:27:45 :303086:  <ERRS> |AP AP3@192.168.1.55 nanny| Process Manager (nanny) shutting down - AP will reboot!
    Nov 13 18:28:00 :303022:  <WARN> |AP AP2@192.168.1.54 nanny|  Reboot Reason: AP rebooted Thu Nov 13 18:27:19 pst 2014; SAPD: Unable to contact switch. Called by sapd_hello_cb:4. HBT miss seq_gen=7600 seq_snt=7600 seq_rcv=7592 218 sec before: Last Ctrl message: HELLO len=923 dest=192.168.1.52 tries=10 seq=0
    Nov 13 18:28:07 :303022:  <WARN> |AP AP1@192.168.1.53 nanny|  Reboot Reason: AP rebooted Thu Nov 13 18:27:25 pst 2014; SAPD: Unable to contact switch. Called by sapd_hello_cb:4. HBT miss seq_gen=48797 seq_snt=48797 seq_rcv=48789 225 sec bef: Last Ctrl message: HELLO len=923 dest=192.168.1.52 tries=10 seq=0
    Nov 13 18:28:16 :303022:  <WARN> |AP AP4@192.168.1.56 nanny|  Reboot Reason: AP rebooted Thu Nov 13 18:27:34 pst 2014; SAPD: Unable to contact switch. Called by sapd_hello_cb:4. HBT miss seq_gen=48797 seq_snt=48797 seq_rcv=48789 233 sec bef: Last Ctrl message: HELLO len=923 dest=192.168.1.52 tries=10 seq=0
    Nov 13 18:28:25 :303022:  <WARN> |AP AP3@192.168.1.55 nanny|  Reboot Reason: AP rebooted Thu Nov 13 18:27:42 pst 2014; SAPD: Unable to contact switch. Called by sapd_hello_cb:4. HBT miss seq_gen=48796 seq_snt=48796 seq_rcv=48788 241 sec bef: Last Ctrl message: HELLO len=923 dest=192.168.1.52 tries=10 seq=0
  • 4.  RE: Cannot join Aruba 3000 Controller
    Posted Nov 13, 2014 05:58 AM
    When you type "show ap active" do you see all of your access points up?
  • 5.  RE: Cannot join Aruba 3000 Controller
    Posted Nov 13, 2014 05:59 AM
    yes, all up
  • 6.  RE: Cannot join Aruba 3000 Controller
    Posted Nov 13, 2014 06:00 AM
    Type "show log error 100" to see if you see anything wrong with your users...
  • 7.  RE: Cannot join Aruba 3000 Controller
    Posted Nov 13, 2014 06:01 AM
    (Aruba3200) #show log errorlog 100
    Nov 13 18:26:25 <fpapps 399816>  <ERRS> |fpapps|  DispAddInput failed
    Nov 13 18:26:25 <fpapps 315382>  <CRIT> |fpapps|  Reboot Cause: User reboot.
    Nov 13 18:27:04 <nanny 399816>  <ERRS> |nanny|  Received the PAPI_APP_SPAWN_PROC Message
    Nov 13 18:27:10 <certmgr 118004>  <ERRS> |certmgr|  Received unknown message
    Nov 13 18:27:14 <certmgr 118004>  <ERRS> |certmgr|  Received unknown message
    Nov 13 18:27:20 <nanny 303086>  <ERRS> |AP AP2@192.168.1.54 nanny| Process Manager (nanny) shutting down - AP will reboot!
    Nov 13 18:27:26 <stm 304001>  <ERRS> |stm|  Unexpected stm (Station management) runtime error at data_path_handler, 642, data_path_handler: recv - Network is down
    Nov 13 18:27:26 <nanny 303086>  <ERRS> |AP AP1@192.168.1.53 nanny| Process Manager (nanny) shutting down - AP will reboot!
    Nov 13 18:27:36 <nanny 303086>  <ERRS> |AP AP4@192.168.1.56 nanny| Process Manager (nanny) shutting down - AP will reboot!
    Nov 13 18:27:45 <nanny 303086>  <ERRS> |AP AP3@192.168.1.55 nanny| Process Manager (nanny) shutting down - AP will reboot!
  • 8.  RE: Cannot join Aruba 3000 Controller
    Posted Nov 13, 2014 06:03 AM
    Okay.  nothing is there about your clients.
    Do this:
    config t
    logging level debugging user
    show log user 100
  • 9.  RE: Cannot join Aruba 3000 Controller
    Posted Nov 13, 2014 06:05 AM
    (Aruba3200) #configure t
    Enter Configuration commands, one per line. End with CNTL/Z
    (Aruba3200) (config) #logging level debugging user
    (Aruba3200) (config) #show log user 100
    Nov 13 18:40:02 :501074:  <WARN> |stm|  wifi_deauth_sta: bad data, dropping. mac: 68:17:29:ed:5b:f2 bssid: 24:de:c6:8c:f9:b0
    Nov 13 18:54:09 :501074:  <WARN> |stm|  wifi_deauth_sta: bad data, dropping. mac: 60:36:dd:39:3a:7d bssid: 24:de:c6:8c:f9:60
    Nov 13 18:57:28 :501074:  <WARN> |stm|  wifi_deauth_sta: bad data, dropping. mac: 60:36:dd:39:3a:7d bssid: 24:de:c6:8c:f9:b0
    Nov 13 19:02:51 :500511:  <DBUG> |mobileip|  Station 60:6c:66:01:90:64, 0.0.0.0: Received disassociation on ESSID: conpak_guest Mobility service ON, HA Discovery on Association Off, Fastroaming Disabled, AP: Name AP4 Group default BSSID 24:de:c6:8c:f9:61, phy g, VLAN 32
    Nov 13 19:02:51 :522036:  <INFO> |authmgr|  MAC=60:6c:66:01:90:64 Station DN: BSSID=24:de:c6:8c:f9:61 ESSID=conpak_guest VLAN=32 AP-name=AP4
    Nov 13 19:02:51 :500010:  <NOTI> |mobileip|  Station 60:6c:66:01:90:64, 255.255.255.255: Mobility trail, on switch 192.168.1.52, VLAN 32, AP AP4, conpak_guest/24:de:c6:8c:f9:61/g
    Nov 13 19:02:51 :522004:  <DBUG> |authmgr|  MAC=60:6c:66:01:90:64 ingress 0x1093 (tunnel 19), u_encr 32, m_encr 32, slotport 0x1043 , type: local, FW mode: 0, AP IP: 0.0.0.0
    Nov 13 19:02:51 :522004:  <DBUG> |authmgr|  station free: bssid=24:de:c6:8c:f9:61, @=0x108b06fc
    Nov 13 19:02:51 :522004:  <DBUG> |authmgr|  MAC=60:6c:66:01:90:64 Send Station delete message to mobility
    Nov 13 19:02:51 :501105:  <NOTI> |AP AP4@192.168.1.56 stm|  Deauth from sta: 60:6c:66:01:90:64: AP 192.168.1.56-24:de:c6:8c:f9:61-AP4 Reason STA has left and is deauthenticated
    Nov 13 19:02:51 :501000:  <DBUG> |AP AP4@192.168.1.56 stm|  Station 60:6c:66:01:90:64: Clearing state
    Nov 13 19:02:52 :501109:  <NOTI> |AP AP4@192.168.1.56 stm|  Auth request: 60:6c:66:01:90:64: AP 192.168.1.56-24:de:c6:8c:f9:60-AP4 auth_alg 0
    Nov 13 19:02:52 :501065:  <DBUG> |AP AP4@192.168.1.56 stm|  remove_stale_sta 1748: client 60:6c:66:01:90:64 not in stale hash table
    Nov 13 19:02:52 :501095:  <NOTI> |stm|  Assoc request @ 19:02:52.994276: 60:6c:66:01:90:64 (SN 2681): AP 192.168.1.56-24:de:c6:8c:f9:60-AP4
    Nov 13 19:02:52 :501093:  <NOTI> |AP AP4@192.168.1.56 stm|  Auth success: 60:6c:66:01:90:64: AP 192.168.1.56-24:de:c6:8c:f9:60-AP4
    Nov 13 19:02:52 :501095:  <NOTI> |AP AP4@192.168.1.56 stm|  Assoc request @ 19:02:52.988476: 60:6c:66:01:90:64 (SN 2681): AP 192.168.1.56-24:de:c6:8c:f9:60-AP4
    Nov 13 19:02:52 :501100:  <NOTI> |stm|  Assoc success @ 19:02:52.997857: 60:6c:66:01:90:64: AP 192.168.1.56-24:de:c6:8c:f9:60-AP4
    Nov 13 19:02:53 :501100:  <NOTI> |AP AP4@192.168.1.56 stm|  Assoc success @ 19:02:52.989413: 60:6c:66:01:90:64: AP 192.168.1.56-24:de:c6:8c:f9:60-AP4
    Nov 13 19:02:52 :501065:  <DBUG> |stm|  Sending STA 60:6c:66:01:90:64 message to Auth and Mobility Unicast Encr WPA2 PSK AES Multicast Encr WPA2 PSK AES VLAN 0x1f, wmm:0, rsn_cap:3c
    Nov 13 19:02:52 :500511:  <DBUG> |mobileip|  Station 60:6c:66:01:90:64, 0.0.0.0: Received association on ESSID: HK-conpak Mobility service ON, HA Discovery on Association Off, Fastroaming Disabled, AP: Name AP4 Group default BSSID 24:de:c6:8c:f9:60, phy g, VLAN 31
    Nov 13 19:02:52 :500010:  <NOTI> |mobileip|  Station 60:6c:66:01:90:64, 0.0.0.0: Mobility trail, on switch 192.168.1.52, VLAN 31, AP AP4, HK-conpak/24:de:c6:8c:f9:60/g
    Nov 13 19:02:52 :522035:  <INFO> |authmgr|  MAC=60:6c:66:01:90:64 Station UP: BSSID=24:de:c6:8c:f9:60 ESSID=HK-conpak VLAN=31 AP-name=AP4
    Nov 13 19:02:52 :522004:  <DBUG> |authmgr|  MAC=60:6c:66:01:90:64 ingress 0x1092 (tunnel 18), u_encr 32, m_encr 32, slotport 0x1043 , type: local, FW mode: 0, AP IP: 0.0.0.0
    Nov 13 19:02:53 :522004:  <DBUG> |authmgr|  MAC=60:6c:66:01:90:64 def_vlan 31 derive vlan: 0 auth_type 0 auth_subtype 0
    Nov 13 19:02:53 :501080:  <NOTI> |stm|  Deauth to sta: 68:17:29:ec:a8:2e: Ageout AP 192.168.1.55-24:de:c6:8c:f9:b0-AP3 Denied: AP Ageout
    Nov 13 19:02:53 :501080:  <NOTI> |stm|  Deauth to sta: 68:17:29:ec:a8:2e: Ageout AP 192.168.1.55-24:de:c6:8c:f9:b0-AP3 Denied; Internal Error
    Nov 13 19:02:53 :501114:  <NOTI> |AP AP3@192.168.1.55 stm|  Deauth from sta: 68:17:29:ec:a8:2e: AP 192.168.1.55-24:de:c6:8c:f9:b0-AP3 Reason 255
    Nov 13 19:02:53 :501044:  <NOTI> |AP AP3@192.168.1.55 stm|  Station 68:17:29:ec:a8:2e: No authentication found trying to de-authenticate to BSSID 24:de:c6:8c:f9:b0 on AP AP3
  • 10.  RE: Cannot join Aruba 3000 Controller
    Posted Nov 13, 2014 06:09 AM
    It is not clear from that output what is happening.
    Find a client that is having problems, and try to connect it.  Then, run the "show log user 100" command again, so we can possibly see what the issue is with that client.  Do you know what provides DHCP for those clients?
  • 11.  RE: Cannot join Aruba 3000 Controller
    (Aruba3200) #show ap active
    Active AP Table
    Name  Group    IP Address    11g Clients  11g Ch/EIRP/MaxEIRP  11a Clients  11a Ch/EIRP/MaxEIRP  AP Type  Flags  U               ptime   Outer IP
    AP1   default  192.168.1.53  2            AP:HT:11/20/20       0                                 93       a      2               9m:52s  N/A
    AP2   default  192.168.1.54  1            AP:HT:11/20/20       0                                 93       a      2               9m:57s  N/A
    AP3   default  192.168.1.55  2            AP:HT:11/20/20       0                                 93       a      2               9m:32s  N/A
    AP4   default  192.168.1.56  4            AP:HT:1/20/20        0                                 93       a      2               9m:41s  N/A
    Flags: a = Reduce ARP packets in the air;  A = Enet1 in active/standby mode;
           B = Battery Boost On; C = Cellular; D = Disconn. Extra Calls On;
           d = Drop Mcast/Bcast On; E = Wired AP enabled; K = 802.11K Enabled; n = Don't convert IPv6 Mcast RA to Ucas               t
           L = Client Balancing Enabled; M = Mesh; N = 802.11b protection disabled;
           P = PPPOE; R = Remote AP; X = Maintenance Mode;
           1 = 802.1x authenticated AP; F = AP failed 802.1x authentication;2 = Using IKE version 2;
    Channel followed by "*" indicates channel selected due to unsupported configured channel.
    "Spectrum" followed by "^" indicates Local Spectrum Override in effect.
    Num APs:4
  • 12.  RE: Cannot join Aruba 3000 Controller
    Monitoring --> Debug --> Process Logs
    Nov 13 18:49:36    authmgr[1574]: <132094> <WARN> |authmgr| MIC failed in WPA2 Key Message 2 from Station 60:36:dd:39:3a:7d 24:de:c6:8c:f9:60 AP4
    Nov 13 18:49:37    authmgr[1574]: <132094> <WARN> |authmgr| MIC failed in WPA2 Key Message 2 from Station 60:6c:66:01:90:64 24:de:c6:8c:f9:61 AP4
    Nov 13 18:49:37    authmgr[1574]: <132094> <WARN> |authmgr| MIC failed in WPA2 Key Message 2 from Station 60:36:dd:39:3a:7d 24:de:c6:8c:f9:60 AP4
    Nov 13 18:49:39    authmgr[1574]: <132094> <WARN> |authmgr| MIC failed in WPA2 Key Message 2 from Station 60:6c:66:01:90:64 24:de:c6:8c:f9:60 AP4
    Nov 13 18:49:55    authmgr[1574]: <132094> <WARN> |authmgr| MIC failed in WPA2 Key Message 2 from Station 68:17:29:48:a1:2f 24:de:c6:8c:f9:b0 AP3
    Nov 13 18:49:55    authmgr[1574]: <132094> <WARN> |authmgr| MIC failed in WPA2 Key Message 2 from Station ac:7b:a1:4f:f1:69 24:de:c6:8c:f9:b0 AP3
    Nov 13 18:49:56    authmgr[1574]: <132094> <WARN> |authmgr| MIC failed in WPA2 Key Message 2 from Station 68:17:29:48:a1:2f 24:de:c6:8c:f9:b0 AP3
    Nov 13 18:49:56    authmgr[1574]: <132094> <WARN> |authmgr| MIC failed in WPA2 Key Message 2 from Station ac:7b:a1:4f:f1:69 24:de:c6:8c:f9:b0 AP3
    Nov 13 18:49:57    authmgr[1574]: <132094> <WARN> |authmgr| MIC failed in WPA2 Key Message 2 from Station 68:17:29:48:a1:2f 24:de:c6:8c:f9:b0 AP3
    Nov 13 18:49:57    authmgr[1574]: <132094> <WARN> |authmgr| MIC failed in WPA2 Key Message 2 from Station ac:7b:a1:4f:f1:69 24:de:c6:8c:f9:b0 AP3
    Nov 13 18:49:58    authmgr[1574]: <132094> <WARN> |authmgr| MIC failed in WPA2 Key Message 2 from Station 68:17:29:48:a1:2f 24:de:c6:8c:f9:b0 AP3
    Nov 13 18:49:58    authmgr[1574]: <132094> <WARN> |authmgr| MIC failed in WPA2 Key Message 2 from Station ac:7b:a1:4f:f1:69 24:de:c6:8c:f9:b0 AP3
    Nov 13 18:49:58    authmgr[1574]: <132094> <WARN> |authmgr| MIC failed in WPA2 Key Message 2 from Station 68:17:29:ed:5b:f2 24:de:c6:8c:f9:b0 AP3
    Nov 13 18:50:27    authmgr[1574]: <132094> <WARN> |authmgr| MIC failed in WPA2 Key Message 2 from Station 68:5d:43:f5:84:e4 24:de:c6:8c:f9:61 AP4
    Nov 13 18:50:35    authmgr[1574]: <132094> <WARN> |authmgr| MIC failed in WPA2 Key Message 2 from Station 68:17:29:ec:a8:2e 24:de:c6:8c:f9:b0 AP3
    Nov 13 18:50:38    authmgr[1574]: <132094> <WARN> |authmgr| MIC failed in WPA2 Key Message 2 from Station 00:27:10:5f:fa:24 24:de:c6:8c:f9:a0 AP2
    Nov 13 18:50:41    authmgr[1574]: <132094> <WARN> |authmgr| MIC failed in WPA2 Key Message 2 from Station 60:36:dd:39:3a:7d 24:de:c6:8c:f9:60 AP4
    Nov 13 18:50:45    authmgr[1574]: <132094> <WARN> |authmgr| MIC failed in WPA2 Key Message 2 from Station 60:6c:66:01:90:64 24:de:c6:8c:f9:61 AP4
    Nov 13 18:50:46    authmgr[1574]: <132094> <WARN> |authmgr| MIC failed in WPA2 Key Message 2 from Station 60:36:dd:39:3a:7d 24:de:c6:8c:f9:60 AP4
    Nov 13 18:50:46    authmgr[1574]: <132094> <WARN> |authmgr| MIC failed in WPA2 Key Message 2 from Station 60:6c:66:01:90:64 24:de:c6:8c:f9:61 AP4
    Nov 13 18:50:47    authmgr[1574]: <132094> <WARN> |authmgr| MIC failed in WPA2 Key Message 2 from Station 60:36:dd:39:3a:7d 24:de:c6:8c:f9:60 AP4
    Nov 13 18:50:47    authmgr[1574]: <132094> <WARN> |authmgr| MIC failed in WPA2 Key Message 2 from Station 60:6c:66:01:90:64 24:de:c6:8c:f9:61 AP4
    Nov 13 18:50:48    authmgr[1574]: <132094> <WARN> |authmgr| MIC failed in WPA2 Key Message 2 from Station 60:36:dd:39:3a:7d 24:de:c6:8c:f9:60 AP4
    Nov 13 18:50:48    authmgr[1574]: <132094> <WARN> |authmgr| MIC failed in WPA2 Key Message 2 from Station 60:6c:66:01:90:64 24:de:c6:8c:f9:61 AP4
    Nov 13 18:50:52    authmgr[1574]: <132094> <WARN> |authmgr| MIC failed in WPA2 Key Message 2 from Station 60:6c:66:01:90:64 24:de:c6:8c:f9:60 AP4
    Nov 13 18:51:01    authmgr[1574]: <132094> <WARN> |authmgr| MIC failed in WPA2 Key Message 2 from Station 68:17:29:48:a1:2f 24:de:c6:8c:f9:b0 AP3
    Nov 13 18:51:01    authmgr[1574]: <132094> <WARN> |authmgr| MIC failed in WPA2 Key Message 2 from Station ac:7b:a1:4f:f1:69 24:de:c6:8c:f9:b0 AP3
    Nov 13 18:51:02    authmgr[1574]: <132094> <WARN> |authmgr| MIC failed in WPA2 Key Message 2 from Station 68:17:29:48:a1:2f 24:de:c6:8c:f9:b0 AP3
    Nov 13 18:51:02    authmgr[1574]: <132094> <WARN> |authmgr| MIC failed in WPA2 Key Message 2 from Station ac:7b:a1:4f:f1:69 24:de:c6:8c:f9:b0 AP3
    Nov 13 18:51:03    authmgr[1574]: <132094> <WARN> |authmgr| MIC failed in WPA2 Key Message 2 from Station 68:17:29:48:a1:2f 24:de:c6:8c:f9:b0 AP3
    Nov 13 18:51:03    authmgr[1574]: <132094> <WARN> |authmgr| MIC failed in WPA2 Key Message 2 from Station ac:7b:a1:4f:f1:69 24:de:c6:8c:f9:b0 AP3
    Nov 13 18:51:04    authmgr[1574]: <132094> <WARN> |authmgr| MIC failed in WPA2 Key Message 2 from Station 68:17:29:48:a1:2f 24:de:c6:8c:f9:b0 AP3
    Nov 13 18:51:04    authmgr[1574]: <132094> <WARN> |authmgr| MIC failed in WPA2 Key Message 2 from Station ac:7b:a1:4f:f1:69 24:de:c6:8c:f9:b0 AP3
    Nov 13 18:51:05    authmgr[1574]: <132094> <WARN> |authmgr| MIC failed in WPA2 Key Message 2 from Station 68:17:29:ed:5b:f2 24:de:c6:8c:f9:b0 AP3
    Nov 13 18:51:41    authmgr[1574]: <132094> <WARN> |authmgr| MIC failed in WPA2 Key Message 2 from Station 68:17:29:ec:a8:2e 24:de:c6:8c:f9:b0 AP3
    Nov 13 18:51:47    authmgr[1574]: <132094> <WARN> |authmgr| MIC failed in WPA2 Key Message 2 from Station 00:27:10:5f:fa:24 24:de:c6:8c:f9:a0 AP2
    Nov 13 18:51:51    authmgr[1574]: <132094> <WARN> |authmgr| MIC failed in WPA2 Key Message 2 from Station 60:36:dd:39:3a:7d 24:de:c6:8c:f9:b0 AP3
    Nov 13 18:51:58    authmgr[1574]: <132094> <WARN> |authmgr| MIC failed in WPA2 Key Message 2 from Station 60:6c:66:01:90:64 24:de:c6:8c:f9:61 AP4
    Nov 13 18:52:04    authmgr[1574]: <132094> <WARN> |authmgr| MIC failed in WPA2 Key Message 2 from Station 60:6c:66:01:90:64 24:de:c6:8c:f9:60 AP4
    Nov 13 18:52:07    authmgr[1574]: <132094> <WARN> |authmgr| MIC failed in WPA2 Key Message 2 from Station 68:17:29:48:a1:2f 24:de:c6:8c:f9:b0 AP3
    Nov 13 18:52:08    authmgr[1574]: <132094> <WARN> |authmgr| MIC failed in WPA2 Key Message 2 from Station ac:7b:a1:4f:f1:69 24:de:c6:8c:f9:60 AP4
    Nov 13 18:52:08    authmgr[1574]: <132094> <WARN> |authmgr| MIC failed in WPA2 Key Message 2 from Station 68:17:29:48:a1:2f 24:de:c6:8c:f9:b0 AP3
    Nov 13 18:52:09    authmgr[1574]: <132094> <WARN> |authmgr| MIC failed in WPA2 Key Message 2 from Station ac:7b:a1:4f:f1:69 24:de:c6:8c:f9:60 AP4
    Nov 13 18:52:09    authmgr[1574]: <132094> <WARN> |authmgr| MIC failed in WPA2 Key Message 2 from Station 68:17:29:48:a1:2f 24:de:c6:8c:f9:b0 AP3
    Nov 13 18:52:10    authmgr[1574]: <132094> <WARN> |authmgr| MIC failed in WPA2 Key Message 2 from Station ac:7b:a1:4f:f1:69 24:de:c6:8c:f9:60 AP4
    Nov 13 18:52:10    authmgr[1574]: <132094> <WARN> |authmgr| MIC failed in WPA2 Key Message 2 from Station 68:17:29:48:a1:2f 24:de:c6:8c:f9:b0 AP3
    Nov 13 18:52:11    authmgr[1574]: <132094> <WARN> |authmgr| MIC failed in WPA2 Key Message 2 from Station ac:7b:a1:4f:f1:69 24:de:c6:8c:f9:60 AP4
    Nov 13 18:52:11    authmgr[1574]: <132094> <WARN> |authmgr| MIC failed in WPA2 Key Message 2 from Station 68:17:29:ed:5b:f2 24:de:c6:8c:f9:b0 AP3
    Nov 13 18:52:41    authmgr[1574]: <132094> <WARN> |authmgr| MIC failed in WPA2 Key Message 2 from Station 68:5d:43:f5:84:e4 24:de:c6:8c:f9:61 AP4
    Nov 13 18:52:47    authmgr[1574]: <132094> <WARN> |authmgr| MIC failed in WPA2 Key Message 2 from Station 68:17:29:ec:a8:2e 24:de:c6:8c:f9:b0 AP3
    Nov 13 18:52:55    authmgr[1574]: <132094> <WARN> |authmgr| MIC failed in WPA2 Key Message 2 from Station 00:27:10:5f:fa:24 24:de:c6:8c:f9:a0 AP2
    Nov 13 18:52:58    authmgr[1574]: <132094> <WARN> |authmgr| MIC failed in WPA2 Key Message 2 from Station 60:36:dd:39:3a:7d 24:de:c6:8c:f9:60 AP4
    Nov 13 18:52:58    authmgr[1574]: <132094> <WARN> |authmgr| MIC failed in WPA2 Key Message 2 from Station 00:27:10:5f:fa:24 24:de:c6:8c:f9:a0 AP2
    Nov 13 18:52:59    authmgr[1574]: <132094> <WARN> |authmgr| MIC failed in WPA2 Key Message 2 from Station 60:36:dd:39:3a:7d 24:de:c6:8c:f9:60 AP4
    Nov 13 18:52:59    authmgr[1574]: <132094> <WARN> |authmgr| MIC failed in WPA2 Key Message 2 from Station 00:27:10:5f:fa:24 24:de:c6:8c:f9:a0 AP2
    Nov 13 18:53:00    authmgr[1574]: <132094> <WARN> |authmgr| MIC failed in WPA2 Key Message 2 from Station 60:36:dd:39:3a:7d 24:de:c6:8c:f9:60 AP4
    Nov 13 18:53:00    authmgr[1574]: <132094> <WARN> |authmgr| MIC failed in WPA2 Key Message 2 from Station 00:27:10:5f:fa:24 24:de:c6:8c:f9:a0 AP2
    Nov 13 18:53:01    authmgr[1574]: <132094> <WARN> |authmgr| MIC failed in WPA2 Key Message 2 from Station 60:36:dd:39:3a:7d 24:de:c6:8c:f9:60 AP4
    Nov 13 18:53:01    authmgr[1574]: <132094> <WARN> |authmgr| MIC failed in WPA2 Key Message 2 from Station 00:27:10:5f:fa:24 24:de:c6:8c:f9:a0 AP2
    Nov 13 18:53:10    authmgr[1574]: <132094> <WARN> |authmgr| MIC failed in WPA2 Key Message 2 from Station 60:6c:66:01:90:64 24:de:c6:8c:f9:b1 AP3
    Nov 13 18:53:13    authmgr[1574]: <132094> <WARN> |authmgr| MIC failed in WPA2 Key Message 2 from Station 68:17:29:48:a1:2f 24:de:c6:8c:f9:b0 AP3
    Nov 13 18:53:13    authmgr[1574]: <132094> <WARN> |authmgr| MIC failed in WPA2 Key Message 2 from Station 60:6c:66:01:90:64 24:de:c6:8c:f9:b1 AP3
    Nov 13 18:53:14    authmgr[1574]: <132094> <WARN> |authmgr| MIC failed in WPA2 Key Message 2 from Station 68:17:29:48:a1:2f 24:de:c6:8c:f9:b0 AP3
    Nov 13 18:53:14    authmgr[1574]: <132094> <WARN> |authmgr| MIC failed in WPA2 Key Message 2 from Station ac:7b:a1:4f:f1:69 24:de:c6:8c:f9:b0 AP3
    Nov 13 18:53:15    authmgr[1574]: <132094> <WARN> |authmgr| MIC failed in WPA2 Key Message 2 from Station 68:17:29:48:a1:2f 24:de:c6:8c:f9:b0 AP3
    Nov 13 18:53:15    authmgr[1574]: <132094> <WARN> |authmgr| MIC failed in WPA2 Key Message 2 from Station ac:7b:a1:4f:f1:69 24:de:c6:8c:f9:b0 AP3
    Nov 13 18:53:16    authmgr[1574]: <132094> <WARN> |authmgr| MIC failed in WPA2 Key Message 2 from Station 68:17:29:48:a1:2f 24:de:c6:8c:f9:b0 AP3
    Nov 13 18:53:16    authmgr[1574]: <132094> <WARN> |authmgr| MIC failed in WPA2 Key Message 2 from Station ac:7b:a1:4f:f1:69 24:de:c6:8c:f9:b0 AP3
    Nov 13 18:53:16    authmgr[1574]: <132094> <WARN> |authmgr| MIC failed in WPA2 Key Message 2 from Station 60:6c:66:01:90:64 24:de:c6:8c:f9:60 AP4
    Nov 13 18:53:17    authmgr[1574]: <132094> <WARN> |authmgr| MIC failed in WPA2 Key Message 2 from Station ac:7b:a1:4f:f1:69 24:de:c6:8c:f9:b0 AP3
    Nov 13 18:53:17    authmgr[1574]: <132094> <WARN> |authmgr| MIC failed in WPA2 Key Message 2 from Station 60:6c:66:01:90:64 24:de:c6:8c:f9:60 AP4
    Nov 13 18:53:17    authmgr[1574]: <132094> <WARN> |authmgr| MIC failed in WPA2 Key Message 2 from Station 68:17:29:ed:5b:f2 24:de:c6:8c:f9:b0 AP3
    Nov 13 18:53:18    authmgr[1574]: <132094> <WARN> |authmgr| MIC failed in WPA2 Key Message 2 from Station 60:6c:66:01:90:64 24:de:c6:8c:f9:60 AP4
    Nov 13 18:53:18    authmgr[1574]: <132094> <WARN> |authmgr| MIC failed in WPA2 Key Message 2 from Station 68:17:29:ed:5b:f2 24:de:c6:8c:f9:b0 AP3
    Nov 13 18:53:19    authmgr[1574]: <132094> <WARN> |authmgr| MIC failed in WPA2 Key Message 2 from Station 60:6c:66:01:90:64 24:de:c6:8c:f9:60 AP4
    Nov 13 18:53:19    authmgr[1574]: <132094> <WARN> |authmgr| MIC failed in WPA2 Key Message 2 from Station 68:17:29:ed:5b:f2 24:de:c6:8c:f9:b0 AP3
    Nov 13 18:53:47    authmgr[1574]: <132094> <WARN> |authmgr| MIC failed in WPA2 Key Message 2 from Station 68:5d:43:f5:84:e4 24:de:c6:8c:f9:b1 AP3
    Nov 13 18:53:53    authmgr[1574]: <132094> <WARN> |authmgr| MIC failed in WPA2 Key Message 2 from Station 68:17:29:ec:a8:2e 24:de:c6:8c:f9:b0 AP3
    Nov 13 18:54:05    authmgr[1574]: <132094> <WARN> |authmgr| MIC failed in WPA2 Key Message 2 from Station 60:36:dd:39:3a:7d 24:de:c6:8c:f9:60 AP4
    Nov 13 18:54:08    authmgr[1574]: <132094> <WARN> |authmgr| MIC failed in WPA2 Key Message 2 from Station 00:27:10:5f:fa:24 24:de:c6:8c:f9:a0 AP2
    Nov 13 18:54:09    stm[1575]: <501074> <WARN> |stm| wifi_deauth_sta: bad data, dropping. mac: 60:36:dd:39:3a:7d bssid: 24:de:c6:8c:f9:60
    Nov 13 18:54:09    authmgr[1574]: <132094> <WARN> |authmgr| MIC failed in WPA2 Key Message 2 from Station 00:27:10:5f:fa:24 24:de:c6:8c:f9:a0 AP2
    Nov 13 18:54:19    authmgr[1574]: <132094> <WARN> |authmgr| MIC failed in WPA2 Key Message 2 from Station 68:17:29:48:a1:2f 24:de:c6:8c:f9:b0 AP3
    Nov 13 18:54:20    authmgr[1574]: <132094> <WARN> |authmgr| MIC failed in WPA2 Key Message 2 from Station ac:7b:a1:4f:f1:69 24:de:c6:8c:f9:b0 AP3
    Nov 13 18:54:21    authmgr[1574]: <132094> <WARN> |authmgr| MIC failed in WPA2 Key Message 2 from Station 68:17:29:48:a1:2f 24:de:c6:8c:f9:b0 AP3
    Nov 13 18:54:21    authmgr[1574]: <132094> <WARN> |authmgr| MIC failed in WPA2 Key Message 2 from Station ac:7b:a1:4f:f1:69 24:de:c6:8c:f9:b0 AP3
    Nov 13 18:54:22    authmgr[1574]: <132094> <WARN> |authmgr| MIC failed in WPA2 Key Message 2 from Station 68:17:29:48:a1:2f 24:de:c6:8c:f9:b0 AP3
    Nov 13 18:54:22    authmgr[1574]: <132094> <WARN> |authmgr| MIC failed in WPA2 Key Message 2 from Station 60:6c:66:01:90:64 24:de:c6:8c:f9:61 AP4
    Nov 13 18:54:22    authmgr[1574]: <132094> <WARN> |authmgr| MIC failed in WPA2 Key Message 2 from Station ac:7b:a1:4f:f1:69 24:de:c6:8c:f9:b0 AP3
    Nov 13 18:54:23    authmgr[1574]: <132094> <WARN> |authmgr| MIC failed in WPA2 Key Message 2 from Station 60:6c:66:01:90:64 24:de:c6:8c:f9:61 AP4
    Nov 13 18:54:23    authmgr[1574]: <132094> <WARN> |authmgr| MIC failed in WPA2 Key Message 2 from Station ac:7b:a1:4f:f1:69 24:de:c6:8c:f9:b0 AP3
    Nov 13 18:54:23    authmgr[1574]: <132094> <WARN> |authmgr| MIC failed in WPA2 Key Message 2 from Station 68:17:29:ed:5b:f2 24:de:c6:8c:f9:b0 AP3
    Nov 13 18:54:24    authmgr[1574]: <132094> <WARN> |authmgr| MIC failed in WPA2 Key Message 2 from Station 60:6c:66:01:90:64 24:de:c6:8c:f9:61 AP4
    Nov 13 18:54:24    authmgr[1574]: <132094> <WARN> |authmgr| MIC failed in WPA2 Key Message 2 from Station 68:17:29:ed:5b:f2 24:de:c6:8c:f9:b0 AP3
    Nov 13 18:54:25    authmgr[1574]: <132094> <WARN> |authmgr| MIC failed in WPA2 Key Message 2 from Station 60:6c:66:01:90:64 24:de:c6:8c:f9:61 AP4
    Nov 13 18:54:25    authmgr[1574]: <132094> <WARN> |authmgr| MIC failed in WPA2 Key Message 2 from Station 68:17:29:ed:5b:f2 24:de:c6:8c:f9:b0 AP3
    Nov 13 18:54:28    authmgr[1574]: <132094> <WARN> |authmgr| MIC failed in WPA2 Key Message 2 from Station 60:6c:66:01:90:64 24:de:c6:8c:f9:60 AP4
    Nov 13 18:54:53    authmgr[1574]: <132094> <WARN> |authmgr| MIC failed in WPA2 Key Message 2 from Station 68:5d:43:f5:84:e4 24:de:c6:8c:f9:61 AP4
    Nov 13 18:55:00    authmgr[1574]: <132094> <WARN> |authmgr| MIC failed in WPA2 Key Message 2 from Station 68:17:29:ec:a8:2e 24:de:c6:8c:f9:b0 AP3
    Nov 13 18:55:11    authmgr[1574]: <132094> <WARN> |authmgr| MIC failed in WPA2 Key Message 2 from Station 60:36:dd:39:3a:7d 24:de:c6:8c:f9:60 AP4
    Nov 13 18:55:17    authmgr[1574]: <132094> <WARN> |authmgr| MIC failed in WPA2 Key Message 2 from Station 00:27:10:5f:fa:24 24:de:c6:8c:fc:60 AP1
    Nov 13 18:55:25    authmgr[1574]: <132094> <WARN> |authmgr| MIC failed in WPA2 Key Message 2 from Station 68:17:29:48:a1:2f 24:de:c6:8c:f9:b0 AP3
    Nov 13 18:55:26    authmgr[1574]: <132094> <WARN> |authmgr| MIC failed in WPA2 Key Message 2 from Station ac:7b:a1:4f:f1:69 24:de:c6:8c:f9:b0 AP3
    Nov 13 18:55:27    authmgr[1574]: <132094> <WARN> |authmgr| MIC failed in WPA2 Key Message 2 from Station 68:17:29:48:a1:2f 24:de:c6:8c:f9:b0 AP3
    Nov 13 18:55:27    authmgr[1574]: <132094> <WARN> |authmgr| MIC failed in WPA2 Key Message 2 from Station ac:7b:a1:4f:f1:69 24:de:c6:8c:f9:b0 AP3
    Nov 13 18:55:28    authmgr[1574]: <132094> <WARN> |authmgr| MIC failed in WPA2 Key Message 2 from Station 68:17:29:48:a1:2f 24:de:c6:8c:f9:b0 AP3
    Nov 13 18:55:28    authmgr[1574]: <132094> <WARN> |authmgr| MIC failed in WPA2 Key Message 2 from Station ac:7b:a1:4f:f1:69 24:de:c6:8c:f9:b0 AP3
  • 13.  RE: Cannot join Aruba 3000 Controller
    Posted Nov 13, 2014 08:14 AM
    That message typically means "wrong preshared key" for those devices...  Was the preshared key changed at any time recently?
  • 14.  RE: Cannot join Aruba 3000 Controller
    Posted Nov 13, 2014 10:51 PM
    Hi Joesph,
    Good morning. We hadn't change any password recently. Anyway, I reset the password and clients can connect now. In fact, I still don't know why some devices can connect the wifi without problem. That's why I hadn't reset the password at first moment.
    Many thanks for your help. Have a nice day!!
    Best regards
    cncheung
    from Hong Kong
