SD-WAN
Cannot login to my controller
  • 1.  Cannot login to my controller
    Posted Jul 03, 2014 11:20 PM
    I have just fresh install SDN controller. It always said "Invalid user & password combination specified!" when i try to login with sdn/skyline.
    Please help me on this issue.
    Attached file shown my user-list
  • 2.  RE: Cannot login to my controller
    Posted Jul 07, 2014 02:53 AM
    Hi pokintania,
    Thanks for your query.
    We hope that you have successfully executed all steps to install the SDN Controller.
    Could you please let us know the below-
    1. Version of the Controller
    2. Controller logs
    3. Command used to install keystone
    4. Are you able to login using other account(e.g. rsdoc)
    HP SDN Team
  • 3.  RE: Cannot login to my controller
    Posted Jul 25, 2014 05:56 AM
    Experiencing the same issue
    here is the details
    1) SDN controller Version :hp-sdn-ctl_2.2.5.0016_amd64.deb
    command used :sudo dpkg -i hp-sdn-ctl_2.2.5.0016_amd64.deb (as mentioned in the installation guide)
    2)Keystone command :
    sudo apt-get install openjdk-7-jre-headless postgresql
    keystone keystone-doc python-keystone iptables unzip
    3) could login to the rsdoc interface .
    Unable to login to the SDN controller  using  default  Username ="sdn" password="skylake"
    Please specify the steps to follow to login to the SDN controller Console GUI.
    and also  how to create the username and password  in keystone authentication server .
  • 4.  RE: Cannot login to my controller
    Posted Aug 01, 2014 05:26 AM
    Hi RASHMIBS,
    As per your post you are not able to login using sdn as user and skylake as the password.
    Please note that default password is skyline so try with skyline and let us know if you still face the issue.
    Please make sure you executed all installation steps(including dependency installation) successfully
    In case you still face the issue please provide controller logs and the steps/commands you executed in order to install controller.Also please share the environment details where you are installing the controller.
    You can change the password by using steps mentioned in Installation Guide[page 9 onwards ]
    HP SDN Team
  • 5.  RE: Cannot login to my controller
    Posted Aug 02, 2014 08:18 AM
    Hello.
    There is new behavior of installation VAN SDN 2.3 - no users are added by setup to keystone during installation (for version <2.3 this is done by install package automatically). You must add it manually (see "install guide 2.3" step 2.2.2 on page 8 (for example run script on page 16).
    Martin Cerveny
  • 6.  RE: Cannot login to my controller
    Posted Aug 12, 2014 06:50 AM
    I've the same problem
    i'have installed keystone with
    	# apt-get install keystone
    	Reading package lists... Done
    	Building dependency tree
    	Reading state information... Done
    	The following NEW packages will be installed:
    	  keystone
    	0 upgraded, 1 newly installed, 0 to remove and 3 not upgraded.
    	Need to get 0 B/25.2 kB of archives.
    	After this operation, 160 kB of additional disk space will be used.
    	Selecting previously unselected package keystone.
    	(Reading database ... 59879 files and directories currently installed.)
    	Unpacking keystone (from .../keystone_1%3a2013.2.3-0ubuntu1~cloud0_all.deb) ...
    	Processing triggers for man-db ...
    	Processing triggers for ureadahead ...
    	Setting up keystone (1:2013.2.3-0ubuntu1~cloud0) ...
    	keystone start/running, process 18349
    so I've executed your script add_to_keystone.sh
    and I've the current user-list
    	# keystone --token ADMIN --endpoint http://localhost:35357/v2.0/ user-list
    	|                id                | name | enabled | email |
    	| 0eecd42191cc4ab8bc9fdfd5446e3eae | sdn  |   True  |       |
    then I've setup hp-sdn-ctl
    	# dpkg -i hp-sdn-ctl_2.3.5.6505_amd64.deb
    	Selecting previously unselected package hp-sdn-ctl.
    	(Reading database ... 59902 files and directories currently installed.)
    	Unpacking hp-sdn-ctl (from .../hp-sdn-ctl_2.3.5.6505_amd64.deb) ...
    	Setup has detected a compatible jre-headless - 1.7.0_55
    	Verifying keystone server...
    	Creating system group 'sdn'...
    	...done.
    	Creating system user 'sdn'...
    	...done.
    	Creating system user 'sdnadmin'...
    	...done.
    	Found pg_hba.conf at /etc/postgresql/9.1/main/pg_hba.conf
    	Configuring PostgreSQL database...
    	 * Restarting PostgreSQL 9.1 database server        [ OK ]
    	...done.
    	Setting up hp-sdn-ctl (2.3.5.6505) ...
    	Certificate was added to keystore
    	Finalize configuration for keystone...
    	... done
    	sdna start/running, process 18591
    	sdnc start/running, process 18597
    but when I login to https://localhost:8443/sdn/ui
    I get "Invalid user & password combination specified!"
    the result of
    	#tail -f /var/log/sdn/virgo/logs/log.log
    	[2014-08-12 12:36:07.365] INFO  http-bio-8443-exec-1         com.sun.jersey.server.impl.application.WebApplicationImpl         Initiating Jersey application, version 'Jersey: 1.17.1 02/28/2013 12:47 PM'
    	[2014-08-12 12:36:07.631] INFO  http-bio-8443-exec-9         com.sun.jersey.server.impl.application.WebApplicationImpl         Initiating Jersey application, version 'Jersey: 1.17.1 02/28/2013 12:47 PM'
    	[2014-08-12 12:36:30.752] INFO  http-bio-8443-exec-2         com.sun.jersey.server.impl.application.WebApplicationImpl         Initiating Jersey application, version 'Jersey: 1.17.1 02/28/2013 12:47 PM'
    	[2014-08-12 12:36:32.062] ERROR http-bio-8443-exec-2         hp.keystone                                                       Failed to authenticate sdn domain user sdn due to com.hp.api.auth.AuthenticationException: Validation error code 401
    I can connect to "https://localhost:8443/admin"with default user and password
    and "https://localhost:8443/api/" get "200 : OK"
    passing {"login":{"user":"sdn","password":"skyline"}}
    to https://localhost:8443/api/#!/auth/
    I get 200 Response Code and this Response Body
    	  "record": {
    	    "token": "MIICagYJKoZIhvcNAQcCoIICWzCCAlcCAQExCTAHBgUrDgMCGjCCAUMGCSqGSIb3DQEHAaCCATQEggEweyJhY2Nlc3MiOiB7InRva2VuIjogeyJpc3N1ZWRfYXQiOiAiMjAxNC0wOC0xMlQxMDo0Mjo1Mi4xMzA0NzEiLCAiZXhwaXJlcyI6ICIyMDE0LTA4LTEzVDEwOjQyOjUyWiIsICJpZCI6ICJwbGFjZWhvbGRlciJ9LCAic2VydmljZUNhdGFsb2ciOiBbXSwgInVzZXIiOiB7InVzZXJuYW1lIjogInNkbiIsICJyb2xlc19saW5rcyI6IFtdLCAiaWQiOiAiMGVlY2Q0MjE5MWNjNGFiOGJjOWZkZmQ1NDQ2ZTNlYWUiLCAicm9sZXMiOiBbXSwgIm5hbWUiOiAic2RuIn0sICJtZXRhZGF0YSI6IHsiaXNfYWRtaW4iOiAwLCAicm9sZXMiOiBbXX19fTGB-zCB-AIBATBcMFcxCzAJBgNVBAYTAlVTMQ4wDAYDVQQIEwVVbnNldDEOMAwGA1UEBxMFVW5zZXQxDjAMBgNVBAoTBVVuc2V0MRgwFgYDVQQDEw93d3cuZXhhbXBsZS5jb20CAQEwBwYFKw4DAhowDQYJKoZIhvcNAQEBBQAEgYCMnST-qTZN2qXTwBtg3GO38q-YZ1ClAb6n0dA6GfPInjDWdxKBwEemNqnLuM9FK3rIfGEblOsLcHui5ZX4SB7-db6wpfPpt7hnHF6ynvEfJQQAarLtbeGMzmvMOplsrIPqde6FOJRavQbajVZJM4nWvbzQ603ZcZwqTRfrdhlO6Q==",
    	    "expiration": 1407926572000,
    	    "expirationDate": "2014-08-13 12-42-52 +0200",
    	    "userId": "0eecd42191cc4ab8bc9fdfd5446e3eae",
    	    "userName": "sdn",
    	    "domainId": "",
    	    "domainName": ""
    but if I specify "domain":"sdn" in login value
    	{"login":{"user":"sdn","password":"skyline","domain":"sdn"}}
    I get Response Code 401 and Response Body
      "error": "com.hp.api.auth.AuthenticationException",
      "message": "Authentication required"
     can I have help ???
  • 7.  RE: Cannot login to my controller
    Posted Aug 12, 2014 11:57 AM
    Hi cedLevoni
    1. Did you remember to do the apt-get update before installing keystone ?
    2. From th HP VAN SDN INstallation guide 2.3 on page 9
    Edit the /etc/keystone/keystone.conf file with the following line to set UUID as the
    provider type, you will need to add this in the [token] section:
    provider=keystone.token.providers.uuid.Provider
    Then restart the keystone service.
    HTH
    Gerhard
  • 8.  RE: Cannot login to my controller
    Posted Aug 12, 2014 02:55 PM
    I am seeing the same behavior from a fresh install this morning. Just tried your suggestions and it is still a no go.
  • 9.  RE: Cannot login to my controller
    Posted Aug 13, 2014 02:55 AM
    done
    done
    >> line to set UUID as the provider type, you will need to add this
    done
    no success
    [2014-08-13 08:47:34.374] ERROR http-bio-8443-exec-5 hp.keystone Failed to authenticate sdn domain user sdn due to com.hp.api.auth.AuthenticationException: Validation error code 401
  • 10.  RE: Cannot login to my controller
    Posted Aug 14, 2014 09:10 AM
    HI cedLevoni and dysanf
    1.Which version of keystone are you using ( Icehouse / Havanna / Grizzly … )
    2.Can you please collect the output of the following command “keystone –version” from the controller
    3.Can you please collect the output of the following command “uname -a” from the controller
    4.Can you please collect the output of the following command “lsb_release -a” from the controller
    5.Keystone user mapping
    Lets run through this on the controller Please collect the output . I will include a sample inline. Please be aware some of the commands might line wrap but they are all in a single line. SOme of the tables in my example wrapped but sorry not much I can do about that.
    List tenants
    Command:
    keystone --os-token ADMIN --os-endpoint http://127.0.0.1:35357/v2.0 tenant-list
    Output:
    | f7209570ff8a49708b1995492cbfab28 | sdn  |   True  |
    List Users
    Command:
    keystone --os-token ADMIN --os-endpoint http://127.0.0.1:35357/v2.0 user-list
    Output:
    | 3d93720e361847acac98150661e2c655 | sdn  |   True  |       |
    List Roles
    Command:
    keystone --os-token ADMIN --os-endpoint http://127.0.0.1:35357/v2.0 role-list
    Output:
    |                id                |    name   |
    | 9fe2ff9ee4384b1894a90878d3e92bab |  _member_ |
    | c10f9e5469574da0a90326b8cf660185 | sdn-admin |
    | 008893e266cc4dfd80e613721d8363c3 |  sdn-user |
    Get the user to role mappings for the given tenant
    This is where it gets tricky we need to find which user has been mapped to which role for the sdn tenant
    In the following command the value after tenant is the id for the sdn tenant from the earlier commands, and the value for user is id for the sdn user
    Command :
    keystone --os-token ADMIN --os-endpoint http://127.0.0.1:35357/v2.0 user-role-list --tenant <SDNTENANTIDHERE>  --user <SDNUSERIDHERE>
    Example
    keystone --os-token ADMIN --os-endpoint http://127.0.0.1:35357/v2.0 user-role-list --tenant f7209570ff8a49708b1995492cbfab28  --user 3d93720e361847acac98150661e2c655
    |                id                |    name   |             user_id              |            tenant_id             |
    | c10f9e5469574da0a90326b8cf660185 | sdn-admin | 3d93720e361847acac98150661e2c655 | f7209570ff8a49708b1995492cbfab28 |
    | 008893e266cc4dfd80e613721d8363c3 |  sdn-user | 3d93720e361847acac98150661e2c655 | f7209570ff8a49708b1995492cbfab28 |
    6. Can you please attempt the following curl for me please from the command liune for the HP van SDN Controller and collect the output please without the domain.
    curl -sk -H 'Content-Type:application/json' -d '{"login":{"user":"sdn","password":"skyline"}}' https://127.0.0.1:8443/sdn/v2.0/auth
    7. Can you please attempt the following curl for me please from the command liune for the HP van SDN Controller and collect the output please with the domain.
    curl -sk -H 'Content-Type:application/json' -d '{"login":{"user":"sdn","password":"skyline","domain":"sdn"}}' https://127.0.0.1:8443/sdn/v2.0/auth
    Thanks in advance
    Gerhard Roets
    HP SDN Team
  • 11.  RE: Cannot login to my controller
    Posted Aug 14, 2014 10:38 AM
    sorry for the trouble
    but the problem is solved
    I performed the reinstallation of the package
    and now everything works fine
    thank you very much
    I've tried this:
    #apt-get purge keystone
    #rm -Rf /var/lib/keystone/
    #apt-get install keystone
    #./add_users_keystone.sh
    #vi /etc/keystone/keystone.conf
    #service keystone restart
    #service sdna restart
    #service sdnc restart
  • 12.  RE: Cannot login to my controller
    Posted Sep 08, 2014 06:00 AM
    I am still facing the issue. This is what I tried:
    #sudo apt-get purge keystone
    #sudo rm -Rf /var/lib/keystone/
    #sudo apt-get update
    #sudo apt-get install keystone
    #sudo ./add_to_keystone.sh
    #sudo vi /etc/keystone/keystone.conf
    #sudo service keystone restart
    #sudo service sdna restart
    #sudo service sdnc restart
    I am getting authentication error when I am using the following curl:
    {"error":"com.hp.api.auth.AuthenticationException","message":"Authentication required"}
    The add_to_keystone.sh I used is attached.
  • 13.  RE: Cannot login to my controller
    Posted Sep 08, 2014 06:32 AM
    Hi Abhik
    would you mind posting the output of the following command please ?
    curl --header "X-Auth-Token:ADMIN" -ksS --request GET --url "http://127.0.0.1:35357/v2.0/tenants" | python -mjson.tool
    curl --header "X-Auth-Token:ADMIN" -ksS --request GET --url "http://127.0.0.1:35357/v2.0/users" | python -mjson.tool
    curl --header "X-Auth-Token:ADMIN" -ksS --request GET --url "http://127.0.0.1:35357/v2.0/OS-KSADM/roles" | python -mjson.tool
    Note each curl command is one line.
    Sample from my system
    gpr@lyncsdn:~$ curl --header "X-Auth-Token:ADMIN" -ksS --request GET --url "http://127.0.0.1:35357/v2.0/tenants"  | python -mjson.tool
        "tenants": [
                "description": "",
                "enabled": true,
                "id": "e13fd642ee754377be0d18e6969dc68d",
                "name": "sdn"
        "tenants_links": []
    gpr@lyncsdn:~$ curl --header "X-Auth-Token:ADMIN" -ksS --request GET --url "http://127.0.0.1:35357/v2.0/users"  | python -mjson.tool
        "users": [
                "enabled": true,
                "id": "a191b03bdc784855a1e7cdb64d959bf1",
                "name": "sdn",
                "username": "sdn"
    gpr@lyncsdn:~$
    gpr@lyncsdn:~$ curl --header "X-Auth-Token:ADMIN" -ksS --request GET --url "http://127.0.0.1:35357/v2.0/OS-KSADM/roles"  | python -mjson.tool
        "roles": [
                "description": "Default role for project membership",
                "enabled": "True",
                "id": "9fe2ff9ee4384b1894a90878d3e92bab",
                "name": "_member_"
                "id": "f9f75b4662b1421eb894476ad1442300",
                "name": "sdn-admin"
                "id": "c2f061d1740d44b8beabb1df7180ae90",
                "name": "sdn-user"
    Even if you get errors please post the output here.
    Kind Regards
    Gerhard
  • 14.  RE: Cannot login to my controller
    Posted Sep 08, 2014 11:50 AM
    Hi Gerhard,
    Thanks for your reply.
    I tried the curl commands, but I am getting the error "couldn't connect to host".
    cnlabs@cnlabs-VirtualBox:~$ curl --header "X-Auth-Token:ADMIN" -ksS --request GET --url "http://127.0.0.1:35357/v2.0/tenants" | python -mjson.tool
    curl: (7) couldn't connect to host
    No JSON object could be decoded
    cnlabs@cnlabs-VirtualBox:~$ curl --header "X-Auth-Token:ADMIN" -ksS --request GET --url "http://127.0.0.1:35357/v2.0/users" | python -mjson.tool
    cnlabs@cnlabs-VirtualBox:~$ curl --header "X-Auth-Token:ADMIN" -ksS --request GET --url "http://127.0.0.1:35357/v2.0/OS-KSADM/roles" | python -mjson.tool
    Abhik
  • 15.  RE: Cannot login to my controller
    Posted Sep 08, 2014 01:26 PM
    Hi Abhik
    That is odd.
    Can you get the following output
    service keystone status
    netstat -na | grep 35357
    lsb_realease -a
    dpkg -l keystone
    Do you have any firewalls running like iptables ?
    Kind Regards
    Gerhard
    HP SDN Team
  • 16.  RE: Cannot login to my controller
    Posted Sep 09, 2014 04:22 AM
    Hi Gerhard,
    cnlabs@cnlabs-VirtualBox:~$ service keystone status
    keystone start/running, process 2699
    cnlabs@cnlabs-VirtualBox:~$ netstat -na | grep 35357
    cnlabs@cnlabs-VirtualBox:~$ lsb_release -a
    No LSB modules are available.
    Distributor ID: Ubuntu
    Description: Ubuntu 12.04.4 LTS
    Release: 12.04
    Codename: precise
    cnlabs@cnlabs-VirtualBox:~$ dpkg -l keystone
    Desired=Unknown/Install/Remove/Purge/Hold
    | Status=Not/Inst/Conf-files/Unpacked/halF-conf/Half-inst/trig-aWait/Trig-pend
    |/ Err?=(none)/Reinst-required (Status,Err: uppercase=bad)
    ||/ Name Version Description
    ii keystone 2012.2.4-0ubun OpenStack identity service - Daemons
    cnlabs@cnlabs-VirtualBox:~$ sudo iptables -L
    Chain INPUT (policy ACCEPT)
    target prot opt source destination
    ACCEPT tcp -- 127.0.0.0/8 anywhere tcp dpt:9160
    REJECT tcp -- anywhere anywhere tcp dpt:9160 rejec t-with icmp-port-unreachable
    ACCEPT tcp -- 127.0.0.0/8 anywhere tcp dpt:7199
    REJECT tcp -- anywhere anywhere tcp dpt:7199 rejec t-with icmp-port-unreachable
    Chain FORWARD (policy ACCEPT)
    Chain OUTPUT (policy ACCEPT)
    Does the patch 65 of java 7 still has the issue in handling SSL connections?
    cnlabs@cnlabs-VirtualBox:~$ java -version
    java version "1.7.0_65"
    OpenJDK Runtime Environment (IcedTea 2.5.1) (7u65-2.5.1-4ubuntu1~0.12.04.2)
    OpenJDK 64-Bit Server VM (build 24.65-b04, mixed mode)
    Abhik
  • 17.  RE: Cannot login to my controller
    Posted Sep 09, 2014 07:35 AM
    Hi Abhik
    It looks to me as if keystone is not listening on the default port, I would suggest you look in /etc/keystone/keystone.conf, and see if the admin_port value has been changed.
    Kind Regards
    Gerhard
  • 18.  RE: Cannot login to my controller
    Posted Sep 12, 2014 10:28 AM
    Yes Gerhard, you were right. It is now working. Thanks :)
  • 19.  RE: Cannot login to my controller
    Posted Oct 01, 2014 05:51 AM
    I have now tried everything in this post without success. I still get "Invalid user & password combination specified!" everytime i try to login with "sdn" and "skyline"
    Any suggestions on what i can try?
  • 20.  RE: Cannot login to my controller
    Posted Oct 09, 2014 06:43 AM
    Hello Skaarup,
    Apologies for the delay.
    Please provide below details-
    1.Controller version ?
    2.did you upgrade the controller or install afresh?
    3.version of keystone?
    4.command used to install keystone?
    5.Are you able to login using other user?
    6.Are you able to see REST API page?
    HP SDN Team
  • 21.  RE: Cannot login to my controller
    Posted Oct 16, 2014 09:07 AM
    When I tried to create a user on keystone using command,
    $keystone user-create --name sdn.
    Im getting the below error,
    Warning: Bypassing the authendication,
    and Service Unavailable (503).
    Can you please let me know, also,
    What are the proxy settings I need to take care for keysone configuration while adding an user (mainly in the script add_to_keystone.sh) and ALSO In keystone.conf file
    regards,
    Satish
  • 22.  RE: Cannot login to my controller
    Posted Oct 21, 2014 02:34 AM
    Hi Gerhard / SDN Team,
    Thank you,, for your support.
    Now my keystone is working much fine, I did the proxy setting then I can able to add user, role and tenant to it.
    But when I run/install the controller the default port is not coming up. ie 8443 is not listing,
    when I did netstat I can see the 35357 port is up and listening, but not the 8443.
    So I am not able to open the UI page from my firefoz .. https:/127.0.0.1:8443/... ( all the option, like api, auth ,, model etc)
    I even tried with proxy setting to noproxy in browers but no gain.
    Can you please advice me what is happening or what went wrong.
    I can see the sdnc and sdna are up and runnig,
    In log i can see one thing..
    Bundle org.eclipse.virgo.medic.core_3.6.2 RELEASE service 38 as service event UNREGISTERING.
    When I scrolled a bit above I can see an error saying Ilogservicelistner.
    attached is the error log.
    Thanks for all,,
    Satish K
  • 23.  RE: Cannot login to my controller
    Posted Oct 21, 2014 08:53 AM
    Hi Satish
    If you can post the following output it would be much appreciated
    I would like the the following file. If you can zip and attach it it would be much appreciated /var/log/sdn/virgo/logs/log.log
    lsb_release -a
    update-java-alternatives -l
     dpkg -l hp-sdn-ctl
    Example output from the commands
    root@sdn1:/var/log/sdn/virgo/logs# lsb_release -a
    Description:    Ubuntu 12.04.5 LTS
    Release:        12.04
    Codename:       precise
    root@sdn1:/var/log/sdn/virgo/logs# update-java-alternatives -l
    java-1.7.0-openjdk-amd64 1051 /usr/lib/jvm/java-1.7.0-openjdk-amd64
    root@sdn1:/var/log/sdn/virgo/logs# dpkg -l hp-sdn-ctl
    ii  hp-sdn-ctl     2.3.5.6505     HP VAN SDN Controller
    Kind Regards
    Gerhard
  • 24.  RE: Cannot login to my controller
    Posted Oct 29, 2014 09:55 AM
    Hi Gerhard,
    Good day,
    Please find below the o/p of commands you have asked, ( looks like all the below command works fine),
    Basically I feel It was due to proxy I was not able to create users, tenants,. Now with proxy off I can create.
    satish@ubuntu:~$ lsb_release -a
    Release: 12.04
    Codename: precise
    satish@ubuntu:~$ update-java-alternatives -l
    java-1.6.0-openjdk-amd64 1061 /usr/lib/jvm/java-1.6.0-openjdk-amd64
    satish@ubuntu:~$ dpkg -l hp-sdn-ctl
    I feel the issue is with Truststore, please see the attached img. I ran the below command,
    satish@ubuntu:~$ keytool -importcert -trustcacerts -keystore keystore -file root.cer -alias CARoot
    satish@ubuntu:~$ keytool -importcert -trustcacerts -keystore truststore -file root.cer -alias CARoot
    When I ran the below command,
    satish@ubuntu:~$ keytool -genkey -alias keystone -keyalg rsa -keysize 2048 -keystore keystore-name
    I can see the keystore generating in /opt/sdn/admin, but not able to see the "truststore".
    Also can you please eloberate what does this mean (Page 44, Controller_Admin_guide)
    (Send the sdn-server.csr to a CA to be signed. The CA will authenticate you and return a signed certificate and its CA certificate chain. We assume the signed certificate from the CA is named signed.cer and the CA's certificate is root.cer. If root.cer is from your own internal CA, then you need to import root.cer into your browser as an authority.)
    Thanks I advance,
    Satish K
    #certificate
  • 25.  RE: Cannot login to my controller
    Posted Oct 30, 2014 08:45 AM
    Hi Satish
    I do not know if you have done much with your controller yet. I would suggest that lets work with the following objectives
    1. Get the controller to work with a self signed certificate so you can access the gui.
    2. If we need to install a certificate we need to install this as the second step after we have succeeded with 1.
    So lets see what version of Java your controller is trying to use. Since you have two versions of java installed
    Login on the controller
    Become root ( sudo -i )
    Become the sdn use ( su - sdn )
    Enter the following command
    java -version
    (Sample without initial login)
    gpr@lyncsdn:~$
    gpr@lyncsdn:~$ sudo -i
    root@lyncsdn:~# su - sdn
    sdn@lyncsdn:~$ java -version
    java version "1.7.0_55"
    OpenJDK Runtime Environment (IcedTea 2.4.7) (7u55-2.4.7-1ubuntu1~0.12.04.2)
    OpenJDK 64-Bit Server VM (build 24.51-b03, mixed mode)
    You need to ensure this is Java 1.7 and not 1.6 if this is 1.6 I would suggest you simply uninstall the Java 1.6 environment. If you can inform me if it was using 1.6 it would be great.
    Now since you worked with certificates I would suggest your remove you purge your sdn controller software and start with a fresh install.
    The command to purge the software - dpkg -p hp-sdnc-ctl
    This should not effect your keystone users if you are using version 2.3.5
    Now you can reinstall the controller
    dpkg -i filename.deb
    dpkg -l hp-sdn-ctl
    This would be a good point to see if you can connect to the web gui and to the rest UI.
    Once this is doen we can do the next steps. I will detail the certification process in a follow on post.
    Kind Regards
    Gerhard
    HP SDN Team
  • 26.  RE: Cannot login to my controller
    Posted Oct 30, 2014 09:02 AM
    Hi Satish
    To elaborate on the certificate install process. The key item here is you will need to work with either your internal CA or an external one. I am not sure how this is set up.
    I would suggest you also install your CA certificate on the Ubuntu OS
    Get certificate info: openssl x509 -in ca.crt -text | grep -i issuer
    Rename as appropriate **note must end in .crt
    Copy cert files to /usr/local/share/ca-certificates
    update-ca-certificates -v
    Based on your message I would suggest you need to download an updated admin guide since there is much more detail in the current guide. The reason I suspect you are using an older one is well our page numbers do not line up.
    You can download the guide from the following url:
    http://h20565.www2.hp.com/portal/site/hpsc/template.BINARYPORTLET/public/kb/docDisplay/resource.process/?spf_p.tpst=kbDocDisplay_ws_BI&spf_p.rid_kbDocDisplay=docDisplayResURL&javax.portlet.begCacheTok=com.vignette.cachetoken&spf_p.rst_kbDocDisplay=wsrp-resourceState%3DdocId%253Demr_na-c04383845-4%257CdocLocale%253D&javax.portlet.endCacheTok=com.vignette.cachetoken
    Page 63 is of interest to you
    The link to this document and other interesting documents specific to this release can be found on the following URL:
    http://h20565.www2.hp.com/portal/site/hpsc/public/psi/home/?sp4ts.oid=5443170&ac.admitted=1414673554878.876444892.492883150#manuals
    Please keep me in the loop of how things are progressing.
    Kind Regards
    Gerhard
    HP SDN Team
  • 27.  RE: Cannot login to my controller
    Posted Oct 30, 2014 11:10 AM
    Hi Gerhard,
    Thanks for your swift responce,
    I too was looking for GUI access only, which is first step, When it is not coming I thought there is some dependency.
    Ok Let me finish with first step then I will go for 2 step.
    Whatever you have suggested for first step, I have executed,
    Please see the attachment for all the 3 one.
    If you are not able to see the attachment please let me know,
    Here I am using remote server so I can copy the o/p so using the screenshot. :-)
    (crome has proxy settings)
    Still I am not able to connect.
    Satish Khandre
  • 28.  RE: Cannot login to my controller
    Posted Oct 30, 2014 11:15 AM
    Also note that when I ran the command,
    $ netstat -na | grep 8443
    I am not getting anyting, meaning the port is not listing, Is it someting missing.
    regards,
    Satish Khandre
  • 29.  RE: Cannot login to my controller
    Posted Oct 30, 2014 11:37 AM
    Hi Satish
    One thing ... depending on your machine specs the web server might(Even minutes) take some time to spool up. So be patient. I would suggest you monitor the output of the command top especially the field "%Cpu(s): " ( you can press q to quit.
    On a side note "apt-get install openssh-server" is your friend ;)
    Also you have an private message on the forums.
    Kind Regards
    Gerhard
    HP SDN Team
  • 30.  RE: Cannot login to my controller
    Posted Nov 05, 2014 03:25 AM
    Hi Gerhard,
    It got SOLVED,
    First of all, let me thank you for the kind of support you have provided, deeply and truly appreciated.  Thank you.
    As suggested,, I did a clean reinstall of all the software.
    Once after installing the controller, I was able to see the port 8443 listening this time.
    Then in the chrome I added the proxy setting to bypass for my controlled and it worked.
    Satish K
    #solved
