Cannot ping 7030 controller
  • 1.  Cannot ping 7030 controller
    Posted Nov 24, 2015 10:07 PM
    Hi, We cannot ping from certain IP addresses to our 7030 controller, but the controller can ping those IP addresses. Does it blacklist certain IP? How to verify? Please advise.
    Sam
  • 2.  RE: Cannot ping 7030 controller
    Posted Nov 25, 2015 07:13 AM
    There is a long list of reasons why you would have that problem, but you do not provide much detail.  Are all of the ip addresses on the same or different subnet?
  • 3.  RE: Cannot ping 7030 controller
    Posted Nov 25, 2015 07:27 AM
    Thanks for your reply. Those IP address are on different subnets from the controller IP, but only some IP in the subnet cannot ping the controller. Any idea?
  • 4.  RE: Cannot ping 7030 controller
    Posted Nov 25, 2015 07:29 AM
    Yes.  Please check the subnet masks and default gateways of those devices that cannot ping the controller.  They could be missing or incorrect.
  • 5.  RE: Cannot ping 7030 controller
    Posted Nov 26, 2015 04:37 AM
    Dear Colin,
    We can ping the controller by adding the "trusted" command under the port-channel interface.
    Before that, we just have the "trusted" command under the gigabit-ethernet interface. We have two questions. Thanks a lot.
    1. Does the port- channel configuration override the gigabit port configuration?
    2. Before we added "trusted" command under the port-channel interface, we have "trusted vlan 1-4094" command.  It looks like the "trusted vlan" command doesn't allow all traffic from these vlan. Is this normal? How should it work?
    interface gigabitethernet 0/0/1
    description "GE0/0/1"
    trusted
    trusted vlan 1-4094
    no spanning-tree
    lacp timeout short
    lacp group 7 mode active
    interface gigabitethernet 0/0/2
    description "GE0/0/2"
    trusted
    trusted vlan 1-4094
    no spanning-tree
    lacp timeout short
    interface port-channel 7
    trusted     <<========================just added this command
    trusted vlan 1-4094
    switchport mode trunk
  • 6.  RE: Cannot ping 7030 controller
    Posted Nov 26, 2015 07:29 AM
    The port channel is untrusted by default when you create it. The port channel configuration overrides the configuration of the nterfaces that are members of the port channel, yes.
