Cannot ping APs
  • 1.  Cannot ping APs
    Posted Dec 18, 2012 06:46 PM
    Out of 473 APs, I can only ping 20 of them.  For those that I cannot ping, they are pingable from the same subnet, but not from outside the subnet.
    The APs are configured exactly the same and I cannot see any difference between the ones that are pingable and the ones that are not.  In all cases I can ping other devices that are in the same subnet as the AP.  It is only the APs that do not respond to ping.
    I've checked firewall logs and confirmed that the pings are getting through.
    It seems to me that the pings are reaching the APs, but for whatever reason they are not getting back.  Any ideas of what may be the issue or where to look?
  • 2.  RE: Cannot ping APs
    Posted Dec 18, 2012 07:32 PM
    Ddi you check the default gateway of the APs?
    If they are not correctly set you wont be able to ping them from another network....
    Did you statically put the IP to the AP? or its through a DHCP?
    If the controller is in the same vlan than the APS then they wont need a default gateway to work in tunnel mode.... you will see everything working perfectly as all the traffic is send to the Wireless controller...
    If you manually set it... you can check the AP default gateway under ap installation and checking it there on the configuration.
    Cheers
    Carlos
  • 3.  RE: Cannot ping APs
    Posted Dec 18, 2012 08:30 PM
    I've confirmed that the default gateways are correct.  The IPs are all set statically and the APs are not on the same VLAN as the controller.
    The APs function normally except for the fact that I cannot ping most of them.
  • 4.  RE: Cannot ping APs
    Posted Dec 18, 2012 09:09 PM
    are yout pinging it from your computer? can you try pinging it from the wirrless controller instead? if it work from the controller then it must be a routing issue... do you know if the aps that you can ping are on an specific vlan or vlans? and the ones you cannot ping are on other specific vlans
  • 5.  RE: Cannot ping APs
    Posted Dec 18, 2012 10:58 PM
    I'm unable to ping them from anywhere outside of the VLAN, including my computer and the controller.  It can't be a routing issue because I can ping other devices in the same VLAN.
    All of the APs are remote APs on different VLANs that are specific to each remote location.  I do not see any pattern or difference in configuration between the 20 that are pingable and the 473 that are not.  One thing that I have noticed is that if I can ping one AP in a specific VLAN, I can ping all of the APs from that particular VLAN.
    There is no difference between the VLANs that are pinging and the ones that are not other than they are in a different physical location.
  • 6.  RE: Cannot ping APs
    Posted Dec 18, 2012 11:03 PM
    Oh all those aps are remote APs?  though they were campuses APs...
    Do you mean they are on RAP mode? right?
    Because thats different...
    ALL of them? are you pinging the outside address ip of the RAP?
  • 7.  RE: Cannot ping APs
    Posted Dec 18, 2012 11:18 PM
    Also on the System profile of those RAPS that you cannot ping,  can you tell me what ACL is applied on the paramether Session ACL can you tell me on the access list that selected there the firewall rules of it?
     Also Are those RAPS are going over a private link or over intenret? i suppose they are going through a private link... right?
    A nice network diagram will help us to help you.... remenber we are trying to imaginate what you got in there..
  • 8.  RE: Cannot ping APs
    Posted Dec 18, 2012 11:23 PM
    Couple of other thoughts/questions:
    - You say these are remote APs; I assume you mean true RAPs and not just APs are a remote site?
    - If they are RAPs, are you pinging the AP IP (inner L2TP pool IP) or the Outer AP IP?  The inner IP should respond if the RAP is terminated on the controller that handed out that address.  The outer IP will likely not be pingable from the controller.
    - Are you sure the controller you are pinging from is the one the RAPs are terminated on?  If not, you can add a route to the inner IP on the controller (or your network) to direct the next hop to the controller's IP
  • 9.  RE: Cannot ping APs
    Posted Dec 19, 2012 03:10 PM
    We have several hundred remote locations and each has anywhere from 2-5 APs.  Our controller is located at our central datacenter.  The APs communicate with our controller via our MPLS network.  They are mostly 125's and a few 105's.
    Here is the configuration of our APs:
    AP "s012aruba01" Provisioning Parameters
    Item Value
    AP Name s012aruba01
    AP Group RETAIL-L1
    Location name N/A
    SNMP sysLocation N/A
    Master 10.186.1.100
    Gateway 10.11.1.1
    Netmask 255.255.255.0
    IP Addr 10.11.1.3
    DNS IP N/A
    Domain Name N/A
    Server Name aruba-master
    Server IP 10.186.1.100
    Antenna gain for 802.11a N/A
    Antenna gain for 802.11g N/A
    Antenna for 802.11a both
    Antenna for 802.11g both
    IKE PSK N/A
    PAP User Name N/A
    PAP Password N/A
    PPPOE User Name N/A
    PPPOE Password N/A
    PPPOE Service Name N/A
    USB User Name N/A
    USB Password N/A
    USB Device Type any
    USB Device Identifier N/A
    USB Dial String N/A
    USB Initialization String N/A
    USB TTY device path N/A
    USB modeswitch parameters N/A
    Remote AP Yes
    Link Priority Ethernet 0
    Link Priority Cellular 0
    Mesh Role none
    Installation default
    Latitude N/A
    Longitude N/A
    Altitude N/A
    Antenna bearing for 802.11a N/A
    Antenna bearing for 802.11g N/A
    Antenna tilt angle for 802.11a N/A
    Antenna tilt angle for 802.11g N/A
    Mesh SAE sae-disable
  • 10.  RE: Cannot ping APs
    Posted Dec 19, 2012 03:15 PM
    Here is the configuration of the system-profile:
    AP system profile "RETAIL-L1"
    Parameter Value
    LMS IP 10.186.1.101
    Backup LMS IP 10.186.1.100
    LMS Preemption Enabled
    LMS Hold-down Period 600 sec
    Number of IPSEC retries 360
    LED operating mode (AP-9x/AP-10x/AP-12x/RAP-5x only) normal
    RF Band g
    Double Encrypt Disabled
    Native VLAN ID 11
    SAP MTU N/A
    Bootstrap threshold 8
    Request Retry Interval 10 sec
    Maximum Request Retries 10
    Keepalive Interval 60 sec
    Dump Server N/A
    Telnet Disabled
    SNMP sysContact N/A
    AeroScout RTLS Server N/A
    RTLS Server configuration N/A
    Remote-AP DHCP Server VLAN N/A
    Remote-AP DHCP Server Id 192.168.11.1
    Remote-AP DHCP Default Router 192.168.11.1
    Remote-AP DHCP DNS Server N/A
    Remote-AP DHCP Pool Start 192.168.11.2
    Remote-AP DHCP Pool End 192.168.11.254
    Remote-AP DHCP Pool Netmask 255.255.255.0
    Remote-AP DHCP Lease Time 0 days
    Remote-AP Backup Ports Enabled
    Remote-AP uplink total bandwidth 0 kbps
    Remote-AP bw reservation 1 N/A
    Remote-AP bw reservation 2 N/A
    Remote-AP bw reservation 3 N/A
    Heartbeat DSCP 0
    Session ACL allowall
    Corporate DNS Domain N/A
    Maintenance Mode Disabled
    WISPr Location-ID ISO Country Code N/A
    WISPr Location-ID E.164 Country Code N/A
    WISPr Location-ID E.164 Area Code N/A
    WISPr Location-ID SSID/Zone N/A
    WISPr Operator Name N/A
    WISPr Location Name N/A
    Remote-AP Local Network Access Disabled
  • 11.  RE: Cannot ping APs
    Posted Dec 19, 2012 03:18 PM
    Would you please answer the question i asked you in my previus post please?
  • 12.  RE: Cannot ping APs
    Posted Dec 19, 2012 04:35 PM
    Which question are you referring to?
    These are all RAPs on a private network and I am pinging the outside interface.  The session ACL is set to allowall.
  • 13.  RE: Cannot ping APs
    Posted Dec 19, 2012 04:37 PM
    the  Session ACL under the AP system profile is set to allow all?
    So you changed it from the default to test ?
  • 14.  RE: Cannot ping APs
    Posted Dec 19, 2012 05:55 PM
    This is what we've had it to set to.
  • 15.  RE: Cannot ping APs
    Posted Dec 19, 2012 06:27 PM
    You can see, while you are pinging that AP, what traffic is going through it by typing:
    show datapath session ap-name <name of remote ap>
    That will determine if it is even seeing that traffic.
  • 16.  RE: Cannot ping APs
    Posted Dec 19, 2012 08:01 PM
    Yes, the pings are reaching the AP.  I've also run this command on one of the APs that is pinging and the output is pretty much identical to the one that is not pinging.  As I've mentioned before, I have no problem pinging other devices on the same VLAN, so it can't be a routing issue.
    PING NOT WORKING
    Source IP Destination IP Prot SPort DPort Cntr Prio ToS Age Destination TAge Flags
    10.186.6.90 10.11.1.3 1 55934 2048 0/0 0 0 1 dev4 21 FYCI
    10.186.6.90 10.11.1.3 1 55928 2048 0/0 0 0 1 dev4 3a FYCI
    10.186.6.90 10.11.1.3 1 55946 2048 0/0 0 0 0 dev4 1a FYCI
    10.186.6.90 10.11.1.3 1 55940 2048 0/0 0 0 0 dev4 33 FYCI
    10.186.6.90 10.11.1.3 1 55952 2048 0/0 0 0 0 dev4 2 FYCI
    10.11.1.3 10.186.6.90 1 55946 0 0/0 0 0 0 dev4 1b FYI
    10.11.1.3 10.186.6.90 1 55940 0 0/0 0 0 0 dev4 34 FYI
    10.11.1.3 10.186.6.90 1 55952 0 0/0 0 0 0 dev4 2 FYI
    10.11.1.3 10.186.6.90 1 55934 0 0/0 0 0 1 dev4 54 FYI
    10.11.1.3 10.186.6.90 1 55928 0 0/0 0 0 1 dev4 6d FYI
    C:\Users\jbyun>ping 10.11.1.3
    Pinging 10.11.1.3 with 32 bytes of data&colon;
    Request timed out.
    Request timed out.
    Request timed out.
    Request timed out.
    Ping statistics for 10.11.1.3:
    Packets: Sent = 4, Received = 0, Lost = 4 (100% loss),
    PING WORKING
    10.186.6.90 10.186.127.99 1 57352 2048 0/0 0 0 0 dev4 14 FYCI
    10.186.6.90 10.186.127.99 1 57358 2048 0/0 0 0 0 dev4 5 FYCI
    10.186.6.90 10.186.127.99 1 57356 2048 0/0 0 0 0 dev4 a FYCI
    10.186.6.90 10.186.127.99 1 57350 2048 0/0 0 0 0 dev4 19 FYCI
    10.186.6.90 10.186.127.99 1 57348 2048 0/0 0 0 0 dev4 1e FYCI
    10.186.6.90 10.186.127.99 1 57360 2048 0/0 0 0 0 dev4 3 FYCI
    10.186.127.99 10.186.6.90 1 57368 0 0/0 0 0 0 dev4 8 FYI
    10.186.127.99 10.186.6.90 1 57370 0 0/0 0 0 0 dev4 3 FYI
    10.186.127.99 10.186.6.90 1 57364 0 0/0 0 0 0 dev4 12 FYI
    10.186.127.99 10.186.6.90 1 57366 0 0/0 0 0 0 dev4 d FYI
    10.186.127.99 10.186.6.90 1 57360 0 0/0 0 0 0 dev4 1d FYI
    C:\Users\jbyun>ping 10.186.127.99
    Pinging 10.186.127.99 with 32 bytes of data&colon;
    Reply from 10.186.127.99: bytes=32 time=46ms TTL=58
    Reply from 10.186.127.99: bytes=32 time=47ms TTL=58
    Ping statistics for 10.186.127.99:
    Packets: Sent = 4, Received = 4, Lost = 0 (0% loss),
    Approximate round trip times in milli-seconds:
    Minimum = 46ms, Maximum = 47ms, Average = 46ms
  • 17.  RE: Cannot ping APs
    Posted Dec 19, 2012 08:15 PM
    I would open a support case.  Depending on how your network is summarized, the access point "could" be responding through the tunnel interface to the controller as opposed to on the local lan.  Only support would be able to determine that.
    I am not sure if deploying APs as RAPs is supported in the Campus, and the way they are designed they might not expect to be pinged across a layer3 subnet.  They expect to be at a remote site behind a firewall..
    Campus APs can be pinged with no issue....
  • 18.  RE: Cannot ping APs
    Posted Dec 19, 2012 08:58 PM
    Collin you an correct me if im wrong and also i would like to know
    As far i know the acl in the system AP profile the Session ACL is the one that control that kind of thing and its applied to the ports on the RAPS....
    If the acl on the ap system profile says that it cannot ping then he would have not be able to ping... but as he has allowed all then he would have permition to ping.. right?
  • 19.  RE: Cannot ping APs
    Posted Dec 19, 2012 09:01 PM
    jbyun
    On your computer
    I would do a tracert -d 10.11.1.3
    To see Where the last jump responding to the packet
    Also i would do  a  tracert -d 10.186.127.99
    To compare
    Cheers
    Carlos
  • 20.  RE: Cannot ping APs
    Posted Dec 19, 2012 09:04 PM
    These APs are at remote sites behind a firewall.  As I mentioned in my original post, I have no problem pinging the APs from the same subnet.  As you can see, the packets are reaching the AP and the AP is even responding, but getting dropped on the way back it appears.  The gateway is correct.
    The APs are fully functional except for the fact that I cannot ping them.  I've compared the 20 working APs with the rest and there is no difference in any of the configurations.
  • 21.  RE: Cannot ping APs
    Posted Dec 19, 2012 09:08 PM
    I've tried those traces and the last hop shows as our firewall's external interface which is the last hop.  The next hop is the device itself.
    C:\Users\jbyun>tracert -d 10.11.1.3
    Tracing route to 10.11.1.3 over a maximum of 30 hops
    1 <1 ms <1 ms <1 ms 10.186.6.1
    9 58 ms 61 ms 56 ms 10.11.1.28
    10 * * * Request timed out.
    11 * ^C
    C:\Users\jbyun>tracert -d 10.11.1.2
    Tracing route to 10.11.1.2 over a maximum of 30 hops
    1 <1 ms 1 ms <1 ms 10.186.6.1
    9    62 ms    56 ms    61 ms  10.11.1.28
    10 66 ms 56 ms 63 ms 10.11.1.2
    Trace complete.
  • 22.  RE: Cannot ping APs
    Posted Dec 19, 2012 09:10 PM
    That is one aspect of it.  The other aspect of it is that the AP itself may be designed to route everything that is not going to the controller or the local subnet through the tunnel.  It is not meant to be managed locally VIA ip.  The session ACL also is to control gratuitous traffic to the bridged users on the AP.  Again, it is not meant to be managed externally otherwise.
  • 23.  RE: Cannot ping APs
    Posted Dec 19, 2012 09:52 PM
    Did you know that the AP you cannot do ping is reporting to the Backup LMS? instead of the primary?
    Can you check that if the APs that you can ping are reporting to the LMS? instead the backup LMS
    Or that AP should report to the controller 10.186.1.100 instead of the 10.186.1.101 ?
    Is this is a master local deployment?  or what kind of deployment is this?
    This is areally weird case as Collin advised you should open a support case.
  • 24.  RE: Cannot ping APs
    Posted Dec 20, 2012 01:23 PM
    We have a master-local deployment.  We opened a support case before and the issue was not resolved.  :smileyfrustrated:
    I'm going to go to the remote location and do a packet capture sometime soon.
  • 25.  RE: Cannot ping APs
    Posted Dec 20, 2012 01:42 PM
    Did you see that if the ones you can ping terminate in one WC and the ones you cannto ping terminate in the other?
    For example one you could not ping was terminating on the backup lms it hink
  • 26.  RE: Cannot ping APs
    Posted Dec 20, 2012 04:37 PM
    No, they are all the same which is why it makes even less sense.
  • 27.  RE: Cannot ping APs
    Posted Dec 20, 2012 04:38 PM
    It would be really nice if after the tac help you to resolve this you could post what was the issue becasue im really interested in the resoltuion... and what is causing this issue...
  • 28.  RE: Cannot ping APs
    Posted Feb 13, 2013 07:55 AM
    jbyun did you ever work this out?
  • 29.  RE: Cannot ping APs
    Posted Mar 25, 2014 06:20 AM
    Same here, did you manage to resolve this with the support ?
    We can't ping the RAP, it makes them reboot.
  • 30.  RE: Cannot ping APs
    Posted Mar 25, 2014 09:50 AM
    since i asked last time i learned that APs just behave like this, once the tunnel is setup they dont reply to traffic from outside the local subnet, they send this back via the tunnel through the controller and often then you dont see it anymore.
    as for the RAP rebooting when you ping it, that sounds a little odd, if you are 100% sure i would open a TAC case for that.
  • 31.  RE: Cannot ping APs
    Posted Jan 20, 2015 08:51 AM
    Hi
    I faced similar issue. I suggested to ping tunnel IPs. My customer wrote a route to controller for tunnel ip subnet. So it worked. I mean now they can ping from monitoring server to tunnel ip through controller. Packets goes from tunnel and comes from same way. For this reason there is no asymmetric routing problem. Meanwhile we used vrrp ip address for route destination for redundancy.
    Regards
  • 32.  RE: Cannot ping APs
    Posted Feb 03, 2016 10:03 PM
    is this issue ever get resolved? could you post the result from TAC?
    i am facing exact similiar issue.
  • 33.  RE: Cannot ping APs
    Posted Feb 04, 2016 03:12 AM
    Tac said this is Aruba behavior
