Cannot ping from one client to another on the same vlan
  • 1.  Cannot ping from one client to another on the same vlan
    Posted Dec 09, 2016 05:12 PM
    Have one vlan for my clients which routes through a campus router.  Clients get gateway info through dhcp from campus Infoblox server.  I am unable to ping from client to client, however, if I ping each client from the controller, then the two clients can ping each other fine.  If wifi is turned off of the clients and turned back on after a minute or so, again they cannot ping each other.  Only after pinging each device from the controller can the clients start pinging each other.  Suggestions?
  • 2.  RE: Cannot ping from one client to another on the same vlan
    Posted Dec 09, 2016 05:32 PM
    In your Virtual AP, make sure you have both "Drop Broadcast and Multicast" and "Convert Broadcast ARP requests to unicast" are enabled in your virtual AP.
  • 3.  RE: Cannot ping from one client to another on the same vlan
    Posted Dec 09, 2016 05:45 PM
    Verified both but no change.
  • 4.  RE: Cannot ping from one client to another on the same vlan
    Posted Dec 10, 2016 08:54 AM
    What else is there about your configuration that I should know?
  • 5.  RE: Cannot ping from one client to another on the same vlan
    Posted Dec 12, 2016 07:24 PM
    Under the VAP profile for that SSID, check if "Deny inter user traffic" is checked. Users on same SSID wont be able to communicate if that is checked.
