Hi - my situation - I am sitting on 192.168.1.0/24
2 HP 2910 Al4G switches sitting on 192.168.3.0/24
HP Switch 1 Default VLAN1 IP:
192.168.3.3
Subnet Mask: 255.255.255.0
Default Gateway: 192.168.3.3
HP Switch 2 Default VLAN1 IP:
192.168.3.4
I can access any other device on the 192.168.3.x network using its access protocol (HTTP, PING, SNMP, Telnet) from the 192.168.1.x network.
I cannot access the management console of my switches via HTTP or Telnet from the 192.168.1.x network.
The only way I can access the switches is from a device/host located on the 192.168.3.x network using either HTTP or Telnet to either switches IP address.
Can anyone explain why? Thanks in advance
