Cannot Provision AP93H
  • 1.  Cannot Provision AP93H
    Posted Mar 26, 2016 11:42 AM
    Hi Everyone,
    Ive been struggleing with this for a few days so i am hoping one of you can help. i know the kit is long past EOL but im learning as i go,
    i have had an 800 controller and 2 AP105's (one RAP) for some time. i recenly purchased (2nd hand) a pair of AP93H as i wanted wired access for a Cisco phone where the RAP is located.
    so i plugged in the AP93's and purged them, but they do not show on the controller, the AP boot log shows DHCP Timeout but the DHCP is fine when in APboot
    Proof DHCP works
    apboot> dhcp
    eth0 up: 100 Mb/s full duplex
    DHCP broadcast 1
    DHCP IP address: 10.1.2.127
    DHCP subnet mask: 255.255.255.0
    DHCP def gateway: 10.1.2.254
    DHCP DNS server: 10.1.2.254
    DHCP DNS domain: xxxxxxxxxxxxxx.net
    apboot>
    apboot> ping 10.1.2.99
    Using eth0 device
    host 10.1.2.99 is alive
    apboot>
    Boot Process (DHCP Enabled)
    APBoot 1.3.9.7 (build 37301)
    Built: 2013-02-20 at 21:26:34
    Model: AP-9x
    CPU:   AR7242 revision: 1
    Clock: 390 MHz, DDR rate: 390 MHz, Bus clock: 195 MHz
    DRAM:  64 MB
    POST1: passed
    Copy:  done
    Flash: 16 MB
    PCI:   scanning bus 0 ...
           dev fn venID devID class  rev    MBAR0    MBAR1    MBAR2    MBAR3
           00  00  168c  002a 00002   01 10000004 00000000 00000000 00000000
    Net:   eth0
    Radio: ar9280#0
    Hit <Enter> to stop autoboot:  0
    Checking image @ 0xbf100000
    Image is signed; verifying checksum... passed
    Signer Cert OK
    Policy Cert OK
    RSA signature verified.
    ELF file is 32 bit
    Loading .text @ 0x80e00000 (3325720 bytes)
    Clearing .bss @ 0x8112bf20 (16 bytes)
    Loading .data @ 0x8112bf30 (32 bytes)
    ## Starting application at 0x80e00000 ...
    Uncompressing..............................
    Aruba Networks
    ArubaOS Version 5.0.4.8 (build 35054 / label #35054)
    Built by p4build@corsica on 2012-08-27 at 10:31:45 PDT (gcc version 3.4.3)
    CPU Rev: 1101
    72x CPU
    No manufacturing information available; assuming AP-92
    Flash variant: 16M
    Cache parity protection disabled
    Using 195.000 MHz high precision timer. cycles_per_jiffy=390000
    Memory: 58556k/65536k available (1640k kernel code, 6924k reserved, 720k data, 2600k init, 0k highmem)
     available.
    detected lzma initramfs
    initramfs: LZMA lc=3,lp=0,pb=2,dictSize=8388608,origSize=13853184
    LZMA initramfs by Ming-Ching Tiew <mctiew@yahoo.com> ....................................................................................................................................................................................................................
    Returning IRQ 48
    AR7240 GPIOC major 0
    wdt: registered with refresh
    Enabling Watchdog
    Talisker RSSI LED initialization
    Creating 1 MTD partitions on "ar7240-nor0":
    0x00000000-0x01000000 : "flash"
    i2c /dev entries driver
    i2c-talisker: using default base 0x18040000
    Starting Kernel SHA1 KAT ...Completed Kernel SHA1 KAT
    Starting Kernel HMAC-SHA1 KAT ...Completed Kernel HMAC-SHA1 KAT
    Starting Kernel DES KAT ...Completed Kernel DES KAT
    Starting Kernel AES KAT ...Completed Kernel AES KAT
    Domain Name: arubanetworks.com
    No panic info available
    AG7240: Length per segment 1536
    AG7240: Max segments per packet 1
    AG7240: Max tx descriptor count    40
    AG7240: Max rx descriptor count    252
    AG7240: fifo cfg 3 01f00140
    AG7240CHH: Mac address for unit 0
    AG7240CHH: 00:0b:86:9c:13:46
    ATHRSF1_PHY: Port 0, Neg Success
    ATHRSF1_PHY: unit 0 phy addr 0 <6>AP xml model 42, num_radios 1 (jiffies 3118)
    init_asap_mod: installation:0
    radio 0: band 2 ant 1 max_ssid 16
    asap_gre_init: ADDED GRE protocol c00aed60
    setting bond0 as bridge child
    setting gre0 as split child
    USB not provisioned
    Starting watchdog process...
    Getting an IP address...
    ag7240_ring_alloc Allocated 640 at 0x8118ac00
    ag7240_ring_alloc Allocated 4032 at 0x8118c000
    Virian MDC CFG Value ==> 4
    Setting PHY...
    ATHRSF1_PHY: unit 0 phy addr 0 Not enabling interrupts in AR7242 yet...
    Kernel watchdog refresh ended.
    DHCP timed out. Rebooting
    killall: nanny: no process killed
    killall: sapd: no process killed
    Sending SIGKILL to all processes.
    Please stand by while rebooting the system.
    Restarting system.
    it looks like once arubaos launches there is no network communication. i am plugged from eth0 on the AP directly into the controller
    the only thing i can think is that the AP's may have been on a higher arubaos version, the only difference i can see between the new ap93's and the existing 105's is that the APboot versions are different.
    ive tried factory resetting them and a clearos.
    setting the ip address and master using setenv gets to a prompt but the AP reboots with "failed to communicate with switch"
    Boot Process (static)
     DHCP
    10.1.2.10 255.255.255.0 10.1.2.254
    Running ADP...Done. Master is 10.1.2.99
    ath_hal: module license 'Proprietary' taints kernel.
    ath_hal: 0.9.17.1 (AR5416, REGOPS_FUNC, PRIVATE_DIAG, WRITE_EEPROM, 11D)
    ath_rate_atheros: Copyright (c) 2001-2005 Atheros Communications, Inc, All Rights Reserved
    ath_rate_atheros: Aruba Networks Rate Control Algorithm
    ath_dfs: Version 2.0.0
    Copyright (c) 2005-2006 Atheros Communications, Inc. All Rights Reserved
    ath_dev: Copyright (c) 2001-2007 Atheros Communications, Inc, All Rights Reserved
    ath_pci: 0.9.4.5 (Atheros/multi-bss)
    wifi0: Base BSSID 00:0b:86:41:34:60, 16 available BSSID(s)
    edev->dev_addr=00:0b:86:9c:13:46
    wifi0: AP type AP-92, radio 0, max_bssids 16
    wifi0: Atheros 9280: mem=0x10000000, irq=48 hw_base=0xb0000000
    AP rebooted Fri Dec 31 16:02:37 PST 1999: DHCP timed out
    shutting down watchdog process (nanny will restart it)...
            <<<<<       Welcome to the Access Point     >>>>>
    ~ # ping 10.1.2.99
    PING 10.1.2.99 (10.1.2.99): 56 data bytes
    ^X
    --- 10.1.2.99 ping statistics ---
    81 packets transmitted, 0 packets received, 100% packet loss
    am i missing something stupid?
    Kindest regards
    Adam
  • 2.  RE: Cannot Provision AP93H
    Posted Mar 26, 2016 12:08 PM
    What version of code is the controller on?
  • 3.  RE: Cannot Provision AP93H
    Posted Mar 26, 2016 12:10 PM
    Hi Colin
    5.0.4.8
    Cheers
    Adam
  • 4.  RE: Cannot Provision AP93H
    Posted Mar 26, 2016 01:49 PM
    The minimum code revision for the AP-93H is (I think) 6.1.3.x. SO it won't come up, and the 800 controller you ahve won't support AOS 6.1. So you will need a new controller to run the 93H APs.
  • 5.  RE: Cannot Provision AP93H
    Posted Mar 26, 2016 02:23 PM
    Hi Jerrod
    according to http://community.arubanetworks.com/t5/Controller-Based-WLANs/What-is-the-minimum-code-version-that-AP-92-and-AP-93-support/ta-p/180964
    AP93's Mimimum code version is ArubaOS 5.0.1.x.
    Full Extract to save clicking
    Product and Software: This article applies to AP-92 and AP-93 and ArubaOS 5.x.
    AP-92 and AP-93 are the indoor access points (APs) that support dual-band with single radio.
    The minimum code that these two APs support is ArubaOS 5.0.1.x.
    AP-92 and AP-93 must have ArubaOS 5.0.1.x to work as:
    • campus AP
    • remote AP
    • mesh AP
    • remote mesh
    • air monitor
    • AP and AM"
  • 6.  RE: Cannot Provision AP93H
    Posted Mar 26, 2016 02:32 PM
    AP 93 and AP 93H have different minimum code versions. I guess AP 93H has a minimum code version of 6.1.3.0.
    #AirheadsMobile
  • 7.  RE: Cannot Provision AP93H
    Posted Mar 26, 2016 02:42 PM
    That Sucks,
    which controllers (thinking second hand, cheap) would support the required arubaos version?
    Cheers
    Adam
  • 8.  RE: Cannot Provision AP93H
    Posted Mar 26, 2016 02:46 PM
    3200XMs should be pretty cheap these days.
