You may check the Mobility Conductor logs, as those can contain more information about why the exception is raised. And you may as well try to remove the controller from the CLI, commands should be in the user guide.
Original Message:
Sent: May 10, 2023 10:50 PM
Subject: Cannot Remove VMC out of Mobility Conductor
Hi All, I have been trying remove my VMC from my Mobility Conductor but I faced an issue where an error message pop up "Exception raised while processing request". I have search online and find out that the issue may comes from something related CPSec but there is no workaround for it. Do you guys know how can I solve this issue?
The version for VMC: 8.10.0.6
