cannot set RAP in 6.3.1.5
  • 1.  cannot set RAP in 6.3.1.5
    Posted Apr 23, 2014 09:59 AM
    After the upgrade to 6.3.1.5 I no longer have the option to setup a RAP in the AP Provisioning. We are using AP93's and AP105's and need them setup as a RAP.
    Does anyone have the commandline verion of this or is it only able to be done from the UI?
  • 2.  RE: cannot set RAP in 6.3.1.5
    Posted Apr 23, 2014 10:02 AM
    It should be there , rap whitelist tab
  • 3.  RE: cannot set RAP in 6.3.1.5
    Posted Aug 27, 2014 06:20 AM
    Hi
    I just witnessed the same actual problem to a customer running 6.3.1.5.
    When trying to provision a RAP or CAP, the choices in the provision menu for chosing CAP or RAP is missing.
    The whole section for selecting certificate or user for auth method for the RAP is missing.
    I suspect this has something to do with 6.3.1.5, i will proceed to read release notes for newer releases of 6.3.1
    Roar
  • 4.  RE: cannot set RAP in 6.3.1.5
    Posted Aug 27, 2014 06:22 AM
    Hi
    Problem is fixed in 6.3.1.7
    99961 Symptom: Remote AP settings were missing in the controller WebUI under the Configuration->Wireless-
    >AP Installation > Provision page. The remote AP license check is removed to fix this issue.
    Scenario: This issue was observed in controllers running ArubaOS 6.3.1.6.
    Platform: All platforms.
    Reported Version: ArubaOS 6.3.1.6
    Upgrade in order
    Roar
