Aruba Instant Wi-Fi: Meet the controllerless Wi-Fi solution that's easy to set-up, is loaded with security and smarts, and won't break your budget.
Cannot SSH a cluster of instant
This thread has been viewed 19 times
  • 1.  Cannot SSH a cluster of instant
    Posted 15 days ago
    Hello
    im getting this message
    We have like many clusters but this is the only one that i cannot ssh for some reason
    You can access through gui and also i did a test to access via telnet and works too.  For now i disabled again the Telnet for security reasons but i would like to fix this to have the ssh working when i need to go to  the CLI remotely.
    I also tried with another ssh client which is not putty but the same problem we have.  It just that cluster
  • 2.  RE: Cannot SSH a cluster of instant
    Posted 15 days ago
    looks like the SSH cipher that you are using is not listed as supported for this Instant AP.
    what firmware are you running on your other instant AP clusters that you can use ecdsa ecdsa-sha2-nistp256?
  • 3.  RE: Cannot SSH a cluster of instant
    Posted 3 days ago
    Hello Ariyap
    The firmware is 8.10.5-8.10.0.5_85552.  The APs are 207 in all that cluster(this access for SSH does not work here)
    i have another cluster with the same firmware but the APs are another model(in this cluster it works fine!)
    It seems that the lastest firmware update for the 207 its the 8.10.5-8.10.0.5_85552.
    Any troubleshooting i can do ariyap that can help me?
  • 4.  RE: Cannot SSH a cluster of instant
    Posted 2 days ago
    not that i know of. it seems the cipher support is related to the AP model. I suggest to open a TAC case.
  • 5.  RE: Cannot SSH a cluster of instant
    Posted 2 days ago
    Thanks Ariyap, im opening the case!
