cannot upgrade AP-365 to 6.5.4.1_61494
  • 1.  cannot upgrade AP-365 to 6.5.4.1_61494
    Posted Oct 10, 2017 03:48 PM
    I have a cluster with IAP-325s running ArubaInstant_Hercules_6.5.4.1_61494
    Now I have a new AP-365, running 6.5.3.2_60886. I cannot add the 365 to the cluster (different Images - that is ok for me.)
    I want to patch my AP-365 to the 6.5.4.1_61494 with the same images that I have use for the IAP-325. It do not work. Error Code: "Invalid Image File".
    Do someone has an idea?
    Is there a separate image file for AP-365?
    Thank you
    Regards
    Patric
  • 2.  RE: cannot upgrade AP-365 to 6.5.4.1_61494
    Posted Oct 11, 2017 02:01 AM
    ok. I think "Hercules" is the wrong image. I need "Ursa". My mistake.
    For Arub newcomers:
    "Hercules" is not the name for a Build of image. It is the name for the AP-family.
    Hercules = IAP-314/314 and IAP-324/325
    Ursa = IAP-304/305 and AP-365/367 and AP-303H
    If you have only one type of AP in your cluster, you see in "Maintenance/Firmware" only one Image file with a "name". If you have different APs, you see for each type an image File.
