Cant access to aruba 3200xm controller from other vlan
  • 1.  Cant access to aruba 3200xm controller from other vlan
    Posted Apr 08, 2014 05:42 AM
    Hi
    Why I cant access to aruba web management when my computer is on different vlan than the controller? Im able to ping to it. Everytime I need to access to it, I have to physicallly go the the server room and direct plug my computer to the controller switch port.
    I deployed some 650 and 3400 model didnt encounter this type of problem. Is there any default access rule that have been specify ?
    Regards
    #3400
  • 2.  RE: Cant access to aruba 3200xm controller from other vlan
    Posted Apr 08, 2014 06:05 AM
    what happens when you try to access it via the web?  Is there a firewall between you and the controller?
  • 3.  RE: Cant access to aruba 3200xm controller from other vlan
    Posted Apr 08, 2014 08:32 AM
    Hi cjoseph
    Thanks for the reply, When I want to web access, the page didnt appear. The browser just keep on loading but nothing happen.
     Attached is my network diagram. Internal network didnt go thru firewall
  • 4.  RE: Cant access to aruba 3200xm controller from other vlan
    Posted Apr 08, 2014 07:09 PM
    do you have correct default gateway set on your controller?
    Is the interface / VLAN set as trusted?
  • 5.  RE: Cant access to aruba 3200xm controller from other vlan
    Posted Apr 08, 2014 08:28 PM
    my interface are set to trusted, I think it is gateway issue.
    Thanks for the tips!
    Regards
