Can't access to instant UI
  • 1.  Can't access to instant UI
    Posted Jun 26, 2019 08:25 AM
    Hello to the forum members
    I have an existing wireless network running  on aruba 305
    I am trying to connect another 207 IAP to the existing network
    When i add the IAP it get IP address from DHCP on the same subnet of The IAP 305 but it not auto join to the network (the auto join is enabled )
    However i can't access to Instant UI with the default user & password but Can access via SSH with default user & password and I get warnning "CLI modul is running in degraded state..."
    Another thing when i connect the IAP 207 to different subnet i'm able to connect to the Instant UI with default user & password
    please advice
    Attachment(s)
    txt
    New Text Document (2).txt   3 KB 1 version
  • 2.  RE: Can't access to instant UI
    Posted Jun 26, 2019 08:49 AM
    Do you run the same firmware version on the 207 and the 305?
    Please make sure the 207 runs the same version before connecting it to the same subnet/cluster.
  • 3.  RE: Can't access to instant UI
    Posted Jun 26, 2019 08:57 AM
    The IAP 305 version 6.5.4.3
    The IAP 207 version 6.5.4.8
  • 4.  RE: Can't access to instant UI
    Posted Jun 26, 2019 07:23 PM
    Since they are running different versions and are different models, you need to enable internet access from the subnet that the IAPs are on. Then it can get the same version.
    Else if you have Airwave you can ensure that these two firmware versions are available and they get upgraded from there.
    Lastly you can take one of them put it on its own subnet and upgrade it manually to match the other one and then add it to the other IAP.
  • 5.  RE: Can't access to instant UI
    Posted Jun 27, 2019 01:36 AM
    I will try it and update
  • 6.  RE: Can't access to instant UI
    Posted Jul 04, 2019 01:43 AM
    Hi
    Sorry for the delay
    I tried everything without success
    I checked that the system version on both devices is the same
    Auto join mode is enabled
    Both IAPs on the same subnet and get IP from DHCP
    One IAP is working perfect but when i try to connect one more IAP it is Not auto join and not get inherit configuration
    Even when I attach it manually
    I can not set it to the same network as you can see in the attached file
    Please help me I'm really desperate
