Ciao Stefano, probably I should take my time to better read this whole thread from beginning...è sera e sono cotto...let me just ask you why VLAN 10 (a quite normal VLAN, as far as I see) has IP address set to 172.16.11.222 when instead your Admin Console server was configured with 172.16.11.254 as its default gateway?
Original Message:
Sent: 2/17/2023 9:39:00 AM
Subject: RE: Can't access to management vLAN
Hi parnassus,
below I send you an ipconfig of the console and the show run of a stack.
The console is a physical workstation directly attached to port 33 of stack member 1 and as you see port 1/33 is untagged for vlan 10.
There is no doubt that this works at the connection/network level because if I simply change the workstation's IP to, for example, 172.16.11.122, I manage to administer everything correctly.
The problem is that with the IPs 172.16.11.121 of the workstation and 172.16.11.21 of the server dedicated to management (which also acts as the DNS of 172.16.11.0/24 Network) I can't connect to the IPs of the stacks that I gave to vLAN 10.
As strange as this is, I think it's because the switches somewhere wrote that the IPs 171 and 21 have so far been used to administer the switches using the native vLAN IPs (192.168.0.234 in this example) and for some reason I don't allow for the change to new IP.
C:\Users\Admin.Console>ipconfig
Configurazione IP di Windows
Scheda Ethernet Ethernet:
Suffisso DNS specifico per connessione:
Indirizzo IPv4. . . . . . . . . . . . : 172.16.11.121
Subnet mask . . . . . . . . . . . . . : 255.255.255.0
Gateway predefinito . . . . . . . . . : 172.16.11.254
SW-A-CED02# sh run
Running configuration:
; hpStack_WC Configuration Editor; Created on release #WC.16.07.0003
; Ver #14:01.4f.f8.1d.9b.3f.bf.bb.ef.7c.59.fc.6b.fb.9f.fc.ff.ff.37.ef:02
stacking
member 1 type "JL323A" mac-address 883a30-a15d00
member 1 priority 250
member 1 flexible-module A type JL083A
member 2 type "JL323A" mac-address 883a30-a03d80
member 2 priority 200
member 2 flexible-module A type JL083A
member 3 type "JL323A" mac-address 883a30-a0af40
member 3 priority 150
member 3 flexible-module A type JL083A
exit
hostname "SW-A-CED02"
trunk 1/A1,2/A1 trk1 lacp
trunk 1/A2,2/A2 trk2 lacp
trunk 2/44,3/44 trk6 lacp
timesync ntp
ntp unicast
ntp server 193.204.114.232
ntp enable
telnet-server listen data
time daylight-time-rule western-europe
time timezone 60
web-management listen data
ip default-gateway 192.168.0.252
ip ssh listen data
snmp-server community "public" unrestricted
snmp-server host 192.168.0.4 community "public" trap-level critical
snmp-server listen data
snmp-server contact "*************" location "Divisione Attrezzature - Rack02 CED"
oobm
disable
ip address dhcp-bootp
member 1
exit
member 2
exit
member 3
exit
exit
vlan 1
name "DEFAULT_VLAN"
no untagged 1/29-1/30,1/32-1/43,2/29-2/30,2/32-2/43,2/48,3/32-3/42
untagged 1/1-1/28,1/31,1/44-1/48,1/A3-1/A4,2/1-2/28,2/31,2/45-2/47,2/A3-2/A4,3/1-3/31,3/43,3/45-3/48,3/A1-3/A4,Trk1-Trk2,Trk6
ip address 192.168.0.234 255.255.255.0
ipv6 enable
ipv6 address dhcp full
exit
vlan 10
name "Management"
untagged 1/33,1/43,2/43
tagged Trk1-Trk2
ip address 172.16.11.222 255.255.255.0
exit
vlan 20
name "DMZ"
untagged 2/33,3/33
tagged Trk1-Trk2
no ip address
exit
vlan 30
name "Fonia"
untagged 1/29-1/30,1/32,1/41-1/42,2/29-2/30,2/32,2/41-2/42,3/41-3/42
tagged Trk1-Trk2
no ip address
exit
vlan 40
name "Sorveglianza"
untagged 1/35-1/37,2/35-2/37,2/48,3/35-3/37
tagged 3/47,Trk1-Trk2
no ip address
exit
vlan 50
name "ProdA"
untagged 1/34,1/38-1/40,2/34,2/38-2/40,3/32,3/34,3/38-3/40
no ip address
exit
vlan 90
name "Isolamento"
no ip address
exit
management-vlan 10
spanning-tree Trk1 priority 4
spanning-tree Trk2 priority 4
spanning-tree Trk6 priority 4
no tftp server
tftp server listen data
no autorun
no dhcp config-file-update
no dhcp image-file-update
password manager
Original Message:
Sent: Feb 16, 2023 01:36 PM
Subject: Can't access to management vLAN
Hi, could you share a sanitized running configuration of one of your three Aruba 2930M backplane stacks? are you testing SSH (or HTTPS) access within a stack (example: workstation connected to - say - interface 1/n untagged member of Management VLAN 10 with proper IP addressing of the stack where you defined VLAN 10 as the "Management (non-routable) VlAN")?
Original Message:
Sent: Feb 16, 2023 03:44 AM
Hi Zac67, thanks for answer.
Yes I know and I think it's a feature and not a problem, that's why I intend to use it to further isolate the management network.
In fact, if you see from the show run, port 1/33 is untagged for vLAN 10 and that's where the console is connected.
The problem is that with the current IP (172.16.11.121) the console is unable to connect either in SSh or in HTTPS to the IP 172.16.11.222 which I assigned to the vLAN10 of the switch.
If I change the IP at the console (e.g. 172.16.11.123) then everything works.
I think the switches don't allow access to management's IP from IPs that have already accessed vLAN 1 IP before.
Since I can't change the IP of the other console, the virtual one (172.16.11.21) I wanted to know if there is a command to "reset" the cache or whatever it is that prevents me from connecting.
Original Message:
Sent: Feb 16, 2023 03:31 AM
You are aware that the management VLAN is exempt from L3 switching?
If you activate management-vlan 10
you need to either connect the management consoles directly to VLAN 10 or provide routing via other means, e.g. a firewall.
