Can't access via web
  • 1.  Can't access via web
    Posted Apr 21, 2012 12:33 PM
    Hello:
    I have this problem, I downgrade my Aruba controller AOS and then I can't access via web to my controller, web I type my user and pass I get this message:
    This XML file does not appear to have any style information associated with it. The document tree is shown below.
    <Aruba>
    <status>Error</status>
    <reason>
    Can't update a new session: 6f59ca9b-076f-4122-8f02-ccb9edf6a8d9, Unknown column 'admin' in 'field list'
    </reason>
    </Aruba>
    even though when I try to access via SSH terminal I got a message too:
    Please change configuration line "localip 0.0.0.0 ipsec" psk key to a more secure value than the default value.
    but I can enter and modify anything I want.
    I need a little help please!
    thank you very much
    regards
  • 2.  RE: Can't access via web
    Posted Apr 21, 2012 01:15 PM
    what did you downgrade to/from?
  • 3.  RE: Can't access via web
    Posted Apr 21, 2012 06:56 PM
    from 6.1.3.1 to 5.0.1.0
  • 4.  RE: Can't access via web
    Posted Apr 21, 2012 06:58 PM
    Did you clear your browser cache?
  • 5.  RE: Can't access via web
    Posted Apr 21, 2012 10:53 PM
    how can I do it?
  • 6.  RE: Can't access via web
    Posted Apr 21, 2012 11:06 PM
    Typically  ctrl-F5 will clear the cache in the browser.
  • 7.  RE: Can't access via web
    Posted Apr 22, 2012 01:23 AM
    ahh ok yes I did it and the same mistake
  • 8.  RE: Can't access via web
    Posted Apr 22, 2012 08:17 AM
    please open a support case.
