Can't Activate Regulatory Files.
  • 1.  Can't Activate Regulatory Files.
    Posted Jan 16, 2018 11:41 PM
    Hi all,
    I have just successfully copied Regulation File to my Controller, but i can't activate it even though i have it in flash
    here is output:
    #ap regulatory activate reg-data-1.0_61955.dat
    Failed to parse regulatory file reg-data-1.0_61955.dat
    dir
    -rw-r--r-- 1 root root 5819 Jan 9 13:39 AUDITTRAIL-HISTORY.log
    -rw-r--r-- 1 root root 963 Jan 9 13:39 AUDITTRAIL-LOGIN_OUT-HISTORY.log
    -rw-r--r-- 1 root root 18916 Jan 16 13:08 default.cfg
    -rw-r--r-- 1 root root 12848 Sep 9 04:54 default.cfg.2017-09-08_13-54-03
    -rw-r--r-- 1 root root 12766 Sep 9 04:36 default.cfg.2017-09-08_14-36-19
    -rw-r--r-- 2 root root 13052 Jan 9 11:12 default.cfg.2018-01-08_20-12-04
    -rw-r--r-- 1 root root 13134 Jan 9 11:22 default.cfg_writemem_2018-01-08_20-22-12
    -rw-r--r-- 1 root root 18634 Jan 9 13:37 default.cfg_writemem_2018-01-09_13-37-17
    -rw-r--r-- 1 root root 18828 Jan 9 13:38 default.cfg_writemem_2018-01-09_13-38-31
    -rw-r--r-- 1 root root 18828 Jan 16 13:07 default.cfg_writemem_2018-01-16_13-07-52
    -rw-r--r-- 1 root root 18916 Jan 16 13:08 default.cfg_writemem_2018-01-16_13-08-02
    drwxr-xr-x 4 root root 4096 Jan 8 10:10 fieldCerts
    -rw-r--r-- 2 root root 13052 Jan 9 11:12 original.cfg
    -rw-r--r-- 1 root nogroup 319040 Jan 17 10:50 reg-data-1.0_61955.dat
    drwx------ 2 root root 4096 Jan 8 10:09 tpm
    Anyone can help me resolve this issue?
    Many Thanks
  • 2.  RE: Can't Activate Regulatory Files.
    Posted Jan 17, 2018 04:11 AM
    the filesize on the controller (from your post) is some 300k, but the size of that file is more like 154k on Aruba's website. You should check what you actually put there is the correct file, or at least re-download and re-put to the controller.
  • 3.  RE: Can't Activate Regulatory Files.
    Posted Jan 17, 2018 04:25 AM
    Could it be that you transferred in ASCII instead of binary?
    Also, there the 61955 version is from October last year, there is a more recent one from this month: HERE.
    Indeed double-check what you uploaded and how... size for 61995 should be 157095 bytes.
  • 4.  RE: Can't Activate Regulatory Files.
    Posted Jan 17, 2018 10:17 AM
    Hi Dugem and Herman,
    Many thanks for your support. I've checked it again and found the problem.I have copied .dat file content than pasted to another .dat file to transfer to controller instead download directly. That's why my .dat file in flash is bigger than the file on Aruba's website.
    Anyway, I'm very appreciate your support.
  • 5.  RE: Can't Activate Regulatory Files.
    Posted Oct 02, 2020 01:30 PM
    Hello i have a big issue here.
    I would like to reload a previous configuration.
    but every time i go to regulatory files and select it and click apply I get an error
    What am I doing wrong?
  • 6.  RE: Can't Activate Regulatory Files.
    Posted Oct 02, 2020 01:49 PM
    The DRT file should be a .dat file, and you can get it from Aruba Support Portal: link.
    Seems like you try to activate configuration files (default.cfg).
