Network Management
Can't add background to Visual RF
  • 1.  Can't add background to Visual RF
    Posted Jun 17, 2020 12:35 PM
    I'm running Airwave 8.2.11.0. I've got a campus map that I'm trying to add to the background of Visual RF and it's just not taking it. Is there a resolution/file size limit for this? Granted, my map is pretty big (as it's our entire campus).
    Thanks!
  • 2.  RE: Can't add background to Visual RF
    Posted Jun 17, 2020 01:34 PM
    Refresh the page.
  • 3.  RE: Can't add background to Visual RF
    Posted Jun 17, 2020 01:57 PM
    Nope. Doesn't work.
  • 4.  RE: Can't add background to Visual RF
    Posted Jun 18, 2020 08:07 AM
    Tried change the background image file in 8.2.11.0 it is working fine. What is the size of image which you are trying to upload?
    Check VisualRF audit log under VisualRF > Audit page and Visualrf.log under system > status page for any errors.
    To narrow down issue,try upload smaller image and check the status.
  • 5.  RE: Can't add background to Visual RF
    Posted Jun 19, 2020 01:33 PM
    When I hit save, the system pauses, then the page blinks like it refreshed, but nothing happens. There are no entries in the either log for the time I try to add.
  • 6.  RE: Can't add background to Visual RF
    Posted Jun 19, 2020 01:38 PM
    Don't know what was wrong, but I cropped it slightly, dropping the file size to 10Mb and now it works. /shrug
  • 7.  RE: Can't add background to Visual RF
    Posted Jun 18, 2020 12:38 PM
    If you dont mind could you share the image file we are trying to upload.
  • 8.  RE: Can't add background to Visual RF
    Posted Jun 18, 2020 02:06 PM
    Sure. Here you go.
  • 9.  RE: Can't add background to Visual RF
    Posted Jun 18, 2020 02:17 PM
    I was able to upload it on my lab server running on 8.2.11.  Issue looks specific on your server. We would have to take a look at the logs to see what is happening. You can inbox me your email ID i can
    take a look at the server.
