Comware
Can't apply TCP rule to VLAN ACL on 5400 Series
  • 1.  Can't apply TCP rule to VLAN ACL on 5400 Series
    Posted Aug 26, 2022 09:07 AM
    So I've done this a ton of times, but I seem to have stumped myself.
    I have an ACL that is for my remote Camera system.  I want to allow communication within the internal network over port TCP 4100
    There are some other things in the ACL but this mainly for networking/switch management.  All of that is working fine, it's just the TCP line #9 that doesn't seem to work.  To clarify the VLAN's i'm trying to connect from have no ACL's applied to them so the issue isn't in the inbound traffic.  If I apply an implicit permit any any rule to the start of this ACL the traffic works, so I know it's isolated to this rule.
    ip access-list extended "DVR-VLAN30"
    2 permit ip 192.168.30.0 0.0.0.15 192.168.0.0 0.0.255.255
    3 permit ip 192.168.30.0 0.0.0.15 10.1.0.0 0.0.255.255
    8 permit ip 192.168.30.0 0.0.0.255 192.168.30.0 0.0.0.255
    9 permit tcp 192.168.30.0 0.0.0.255 192.168.0.0 0.0.255.255 eq 4100
    10 permit ip 192.168.30.0 0.0.0.255 192.168.30.254 0.0.0.0
    20 permit ip 192.168.30.0 0.0.0.255 192.168.4.254 0.0.0.0
    30 permit ip 192.168.30.0 0.0.0.255 192.168.4.204 0.0.0.0
    50 deny ip 192.168.30.0 0.0.0.255 192.168.0.0 0.0.255.255
    55 deny tcp 192.168.30.0 0.0.0.255 192.168.0.0 0.0.255.255
    60 deny ip 192.168.30.0 0.0.0.255 10.1.0.0 0.0.255.255
    65 deny udp 192.168.30.0 0.0.0.255 192.168.0.0 0.0.255.255
    90 permit ip 192.168.30.0 0.0.0.255 0.0.0.0 255.255.255.255
    at first I had this rule applied to the vlan as "ip access-group "DVR-VLAN30" in
    However I read somewhere that I should try to apply it using "vlan" instead of in.  From my understanding it's interchangeable and It seems to work identically to the "in"
    vlan 30
    name "DVR"
    untagged A3-A4,B10,J24
    ip helper-address 192.168.4.11
    ip helper-address 192.168.4.37
    ip address 192.168.30.254 255.255.255.0
    ip access-group "DVR-VLAN30" vlan
