That message tells you that there is a redirect happening when you connect to the wireless network. This is expected if you have an unconfigured Instant AP or when you have a guest network. As the screenshot shows that you are connected to the 'instant' network, it appears to be an unconfigured network.
I think that if you press 'Connect' on that screen that you will be connected and should be able to connect to the management UI. As the default ssid instant indicates a quite old version of firmware, it may be that you need to try a few different browsers to get access to the UI. Modern browsers may prevent access as the crypto settings and certificates are old and expired. Upgrade the AP as soon as you have access to it to fix that type of issue.
If you have urgent issues, always contact your Aruba partner, distributor or Aruba TAC Support. Check
https://www.arubanetworks.com/support-services/contact-support/ for how to contact Aruba TAC.
Original Message:
Sent: Nov 05, 2020 01:16 PM
Subject: can't connect to IAP web UI
Hi
I have the same problem too. I connected IAP205-RW to DHCP server with internet access. But i am unable to connect to Webui. Below is the error page. Please advise.
CHOR SENG HO
Original Message:
Sent: Mar 31, 2017 12:13 AM
Start with a DHCP server and internet access. You are making things much harder if those two things are not in place..
