Can't connect to SSID until AP rebooted
  • 1.  Can't connect to SSID until AP rebooted
    Posted Nov 26, 2014 07:37 AM
    Hi
    I had a weird one at a client where we are broadcasting 3 different SSID's - throughout the whole environment we could connect to 2 of the SSID with no problem except the one.
    The SSID was broadcasting but no connection could be established with no clear error -- after rebooting the APs we could once again reconnect to the SSID.
    Could there be a logical explanation for this?
  • 2.  RE: Can't connect to SSID until AP rebooted
    Posted Nov 26, 2014 08:45 AM
    There is no logical reason for that.
    You should open a support case.
  • 3.  RE: Can't connect to SSID until AP rebooted
    Posted Nov 26, 2014 08:52 AM
    Thanks Collin -  I thought as much...
    Unfortunately the Controller has also been rebooted since then so no logs available...
    Just thought I'd pose the question anyway.
  • 4.  RE: Can't connect to SSID until AP rebooted
    Posted Nov 28, 2014 02:16 AM
    Hendrik
    There are a couple of known issues floating around that could manifest as this. What AOS version are you on and what topology (lms+bkup lms? rap? cap? bridge? tunnel?) do you have.
    If it happens again, collect the following to help narrow it down faster
    show ap remote debug mgmt-frames ap-name <>
    show ap tech-support ap-name <>
    logging level debugging user-debug <mac of affected client>
    show auth-tracebuf
    tar logs techsupport
    regards
    -jeff
  • 5.  RE: Can't connect to SSID until AP rebooted
    Posted Dec 01, 2014 01:40 AM
    Hi - thanks for the advise - will be sure to run the comamnds if it occurs again, so far it hasn't been a problem again.
    We are running AOS 6.3.1.8 - All APs are CAP, with primary LMS set(no backup), all connections should be tunnel and controller is local with upstream master controller for vap-config and licensing.
  • 6.  RE: Can't connect to SSID until AP rebooted
    Posted Apr 17, 2015 05:58 AM
    I wonder what may have casued it.
    I also encountered this kind of issue.
  • 7.  RE: Can't connect to SSID until AP rebooted
    Posted Jun 15, 2017 03:56 PM
    I am having this issue right now, i'm on a 7205 controller running 325's.  Did you ever find a solution?
  • 8.  RE: Can't connect to SSID until AP rebooted
    Posted Jun 15, 2017 04:17 PM
    How is your issue similar? This thread was opened two years ago.
  • 9.  RE: Can't connect to SSID until AP rebooted
    Posted Jun 20, 2017 03:53 AM
    Hi
    Very Old thread, but if memorty serves the issue was related to a bad controller - same issue wasn't seen again but other problems cropted up afterwards (firmware on controller made no diference) restoring backup config onto a replacement controller resolved the issue.
  • 10.  RE: Can't connect to SSID until AP rebooted
    Posted Nov 03, 2017 02:39 AM
    Hi guys,
    Similar to the problem that Hendrik experienced. Ssid problem started to live. I have problems using 3 ssid. But using 2 ssid working normally. Any comments on this topic?
    Thank you so much.
