Developer
Can't connect to switch via telnet script(Python3)
  • 1.  Can't connect to switch via telnet script(Python3)
    Posted May 14, 2020 10:59 AM
    Hello everyone,i have a problem:I can't connect via python script to switch,using telnetlib module:
    Script:
    import getpass
    import telnetlib
    HOST = "10.255.23.10"
    user = input("Enter your account: ")
    password = getpass.getpass()
    tn = telnetlib.Telnet(HOST)
    tn.read_until(b"Username: ")
    tn.write(user.encode('ascii') + b"
    ") if password: tn.read_until(b"Password: ") tn.write(password.encode('ascii') + b"
    ") tn.write(b"show version
    ") print(tn.read_all().decode('ascii'))
    And what's happening:
    After input password nothing happened.
    I don't know why.
    HP J9774A 2530-8G-PoEP Switch
    What's wrong???
  • 2.  RE: Can't connect to switch via telnet script(Python3)
    MVP GURU
    Posted May 15, 2020 02:59 AM
    What firmware version ?
    Why don't use API ? it is will be more easy...
  • 3.  RE: Can't connect to switch via telnet script(Python3)
    Posted May 15, 2020 03:38 AM
    YA.16.08.0001
    Why not API?
    Because i'm learning Python and want so.
  • 4.  RE: Can't connect to switch via telnet script(Python3)
    MVP GURU
    Posted May 15, 2020 04:10 AM
    you can use Python and API !
  • 5.  RE: Can't connect to switch via telnet script(Python3)
    Posted May 15, 2020 05:44 AM
    Ok,I heard you,thanks.
    С уважением,
    Щеголев Глеб Геннадьевич
