can't do cli: SID Validation failed
This thread has been viewed 23 times
  • 1.  can't do cli: SID Validation failed
    Posted Apr 10, 2014 11:04 AM
    Hello, I do the update to 6.3.1.5, when I try to go to the maintenance tab I received this message: can't do cli: SID Validation failed.
    Somebody can help me?
  • 2.  RE: can't do cli: SID Validation failed
    Posted Apr 10, 2014 11:26 AM
    Have you tried using another browser by any chance ?
  • 3.  RE: can't do cli: SID Validation failed
    Posted Apr 10, 2014 11:40 AM
    Yes, with IE work, but can I do something for Firefox work?
  • 4.  RE: can't do cli: SID Validation failed
    Posted Apr 10, 2014 12:09 PM
    Try turning off compatibility mode in firefox and see if that helps
  • 5.  RE: can't do cli: SID Validation failed
    Posted Apr 10, 2014 12:36 PM
    Try clearing your web content cache (options/advanced/network). This fixed this issue for me on this version.
    Gary E.
  • 6.  RE: can't do cli: SID Validation failed
    Posted Apr 11, 2014 04:57 AM
    Usually after an upgrade you should clean the cache of the browser
  • 7.  RE: can't do cli: SID Validation failed
    Posted Apr 12, 2014 11:49 AM
    Clearing the cache of Firefox was the solution in my environment. Thanks.
  • 8.  RE: can't do cli: SID Validation failed
    Posted May 06, 2014 03:38 AM
    I have the same problem with 6.3.1.5 version. I received same error message when ı try to access maintenance tab
  • 9.  RE: can't do cli: SID Validation failed
    Posted May 06, 2014 03:49 AM
    Have you already cleared your browser-cache?
  • 10.  RE: can't do cli: SID Validation failed
    Posted May 06, 2014 03:57 AM
    I worked, Thank you
  • 11.  RE: can't do cli: SID Validation failed
    Posted Oct 06, 2014 10:15 AM
    I'm getting this everytime I log into to customers device remotely through JunOS sessions. There isn't an option to clear the cache within the JunOS portal and clearing the cache on the browser doesnt help. Any ideas?
  • 12.  RE: can't do cli: SID Validation failed
    Posted Oct 19, 2014 02:17 PM
    good question, i have the same issue going through a Juniper MAG (SSL VPN device), anyway to solve that?
  • 13.  RE: can't do cli: SID Validation failed
    Posted Nov 23, 2014 07:27 AM
    anyone with some experience on this?
    if not ill open a ticket.
  • 14.  RE: can't do cli: SID Validation failed
    Posted May 20, 2015 03:26 PM
    Has there been any update on this issue...when connecting through a Juniper SSL VPN connection?
  • 15.  RE: can't do cli: SID Validation failed
    Posted May 21, 2015 01:42 PM
    you do mean a juniper MAG SSL portal approach right? not the full VPN, that would be a different situation.
    for the MAG SSL portal it seems the rewriting fails. Juniper can fix this if they get access to a device and can do their debuging.
    another work around is to do direct access, bypassing rewriting which is discused here:
    https://www.juniper.net/techpubs/software/ive/guides/howtos/How_To__PTP.pdf
  • 16.  RE: can't do cli: SID Validation failed
    Posted May 21, 2015 03:21 PM
    Thanks for the response. I needed access to the customers network to grab the config off of an Aruba controller. Since fixing this issue is outside of the scope of work, I just downloaded the Pulse client and connected that way. We may have to re-visit the issue at a later date for the customer.
    Thanks again!
    -Herman
