cant drop clearpass subscriber due to virtual IP settings
  • 1.  cant drop clearpass subscriber due to virtual IP settings
    Posted Aug 14, 2014 03:32 AM
    got a clearpass cluster (version 6.3.4) of two nodes, a publisher and subscriber. the publisher has failed and no standby publisher is configured. now i would like to drop the subscriber to make it publisher, but im stuck in a catch 22 i believe.
    when i click drop subscriber it says "Drop Subscriber is not permitted. Server is part of Virtual IP Settings"
    but when i try to remove the virtual ip settings it says "Modifications are not supported on Subscriber node; please use Publisher node."
    also i would like to leave the virtual ip untouched as removing that can cause an interuption.
    i found the CLI command cluster make-publisher is that my only option or is there something else to do?
  • 2.  RE: cant drop clearpass subscriber due to virtual IP settings
    Posted Aug 14, 2014 06:32 AM
    Yes, you should promote to publisher. You should always have an active publisher.
  • 3.  RE: cant drop clearpass subscriber due to virtual IP settings
    Posted Aug 14, 2014 03:01 PM
    ok and via the CLI is the only way to go?
    little note for aruba, update the documentation to also say the -f flag is possible for the cluster make-publisher command.
  • 4.  RE: cant drop clearpass subscriber due to virtual IP settings
    Posted Aug 14, 2014 03:16 PM
    In this instance, yes.
  • 5.  RE: cant drop clearpass subscriber due to virtual IP settings
    Posted Aug 14, 2014 10:08 PM
    In 6.4 the VIP restriction is removed so you don't have to have both servers defined.
    I will have to test and see if it will help in your instance.
  • 6.  RE: cant drop clearpass subscriber due to virtual IP settings
    Posted Aug 18, 2014 03:58 AM
    thanks guys, that is enough information for now.
