Security Training
Can't filter for framed IP(v6) address
  • 1.  Can't filter for framed IP(v6) address
    Posted Oct 13, 2022 07:00 AM
    I would to use the access tracker to filter out the framed IP and IPv6 address. I thought I have done this in the past, but now this does not seem to work anymore. I opened a case for this but they say you can't filter this in the access tracker. Their conclusion is: although you can select filter based on specific Radius Input paramaters this acutually doesn't not work and the error is normal. If you want to get the framed ip, you have to create a custom data filter which contains the ip-address you're looking for and than select this in the Access tracker. Does anyone have another opinion on this?
    Even a simple filter on Aruba vlan fails.
