Network Management
Can't find "Use Metric Units" in Airwave 8.2.5.1
  • 1.  Can't find "Use Metric Units" in Airwave 8.2.5.1
    Posted Jan 08, 2018 11:05 AM
    I just enabled VisualRF after upgrading an Airwave Server from 8.2.4.1 to 8.2.5.1.
    I also wanted to integrat floor plan for our new building but the unit is "feet". i Wanted to switch to metric unit but i don't know where i can do this change. VisualRF SetupVisualRF Setup
    In 8.2.4.1, i can check a box called "Use Metric Units" but in 8.2.5.1, thix box doesn't appeat anymore.
    I also look in General Settings but i can't find it anywhere.
    Can you tell me if this option is till available in 8.2.5.1?
    If yes, where can i enable it?
    Best Regards,
    Quentin
  • 2.  RE: Can't find "Use Metric Units" in Airwave 8.2.5.1
    Posted Jan 09, 2018 05:31 PM
    Setting is moved -> it's now a per-user maintained setting.
    Steps:
    1) Navigate to VRF (main network view)
    2) Click on Edit (on the right hand menu)
    3) Set meters/feet toggle
  • 3.  RE: Can't find "Use Metric Units" in Airwave 8.2.5.1
    Posted Jan 15, 2018 10:07 AM
    Thank you for the quick response.
    Best Regards,
    Quentin Dubois
