Can't force AP93 to work with Ghz
  • 1.  Can't force AP93 to work with Ghz
    Posted Jul 09, 2014 12:04 PM
    Hi, I am using 7210 controller and AP93
    I have 6 AP93 in one location, so i need to set 3 of them 2.4 and the other 3 to 5Ghz
    Regarding the first 3 they worked 2.4 witout any problems, regarding the other 3 I added a new AP group for them and in the VAP I choosed (a only), but they are inactive and even ointhe 2.4 band (in Monitoring Tab).
    What shall I do to force it to use 5 Ghz only
    Another question, in the ARM I modified the minimum EIRP to be 18, but still some of the AP93 access points are working with 16 dBm, while other models are working fine.
    #7210
  • 2.  RE: Can't force AP93 to work with Ghz
    Posted Jul 09, 2014 12:12 PM
    https://arubanetworkskb.secure.force.com/pkb/articles/HowTo/R-1621
    The APs that are operating below the TX power, did you take a look at the ARM profile attached to the AP-Group of the APs with the issue?
  • 3.  RE: Can't force AP93 to work with Ghz
    Posted Jul 09, 2014 12:33 PM
    Regarding the problem of the single radio, it has been solved (Thanks)
    regarding TX Power, I did the follwing test
    I added 3 X AP-275 & 3 X AP-93H & 3 X AP-93 to the same AP Group and set the minimum TX to 20 dBm
    All the AP-275 and AP-93H used 20 dBm While AP-93 one used 16 dBM and another used 17 dBm while the third used 20 dBm !!!!!!
  • 4.  RE: Can't force AP93 to work with Ghz
    Posted Jul 09, 2014 12:38 PM
    There is a max TX for the G radio and one for the A radio.  Make sure that you change both if you want to set the minimum to 20.
  • 5.  RE: Can't force AP93 to work with Ghz
    Posted Jul 09, 2014 12:43 PM
    Do You mean 802.11a Radio & 802.11g Radio under RF Managment (I already changed them)
  • 6.  RE: Can't force AP93 to work with Ghz
    MVP
    Posted Jul 09, 2014 12:50 PM
    If ARM is enabled (default) the min TX values from the radio profiles is/are ignored in favor of the min TX values inside the ARM profile which itself is 'attached' within the radio profiles. See attached image.
    But make sure that both the arm profile used in the a-radio profile as well as the arm profile used in the g-radio profile is set to what you want.
  • 7.  RE: Can't force AP93 to work with Ghz
    Posted Jul 10, 2014 07:19 AM
    They are the same in both profiles
    I think, its something related to AP93, as AP-275 and AP-93H both worked normally in the same AP group
    even I thought that the AP-93 can't support this TX power, but already one of them reached it
  • 8.  RE: Can't force AP93 to work with Ghz
    Posted Jul 10, 2014 07:29 AM
    Please use the command "show ap allowed-max-EIRP ap-name <name of ap> country-code <country code>"
    That is to find out what is the maximum EIRP for each channel for that AP in your country code.
    (192.168.1.3) # show ap allowed-max-EIRP ap-name Office-225 country-code US
    Thu Jul 10 06:25:39 2014
    Max EIRP setting for Country Code US Country United States and AP type AP-225
    Channel  1   2   3   4   5   6   7   8   9   10  11  12  13  14  36  40  44  48  52  56  60  64  100  104  108  112  116  120  124  128  132  136  140  144  149  153  157  161  165
    b        29  29  29  29  29  29  29  29  29  29  29  *   *   *   *   *   *   *   *   *   *   *   *    *    *    *    *    *    *    *    *    *    *    *    *    *    *    *    *
    g/a      32  32  32  32  32  32  32  32  32  32  32  *   *   *   21  21  21  21  28  28  28  28  28   28   28   28   28   *    *    *    27   27   27   27   33   33   33   33   33
    HT 20    32  32  32  32  32  32  32  32  32  32  32  *   *   *   21  21  21  21  27  28  28  28  28   28   28   28   28   *    *    *    27   27   27   27   33   33   33   33   33
    HT 40    32  32  32  32  32  32  32  32  32  32  32  *   *   *   20  20  20  20  24  24  24  24  24   24   24   24   *    *    *    *    24   24   24   23   32   32   32   32   32
    VHT 80   *   *   *   *   *   *   *   *   *   *   *   *   *   *   21  21  21  21  21  21  21  21  21   21   21   21   *    *    *    *    21   21   21   20   33   33   33   33   33
  • 9.  RE: Can't force AP93 to work with Ghz
    Posted Jul 10, 2014 07:40 AM
    I will do,
    But I think it is not the problem as one of them already reached 20 dBm
  • 10.  RE: Can't force AP93 to work with Ghz
    Posted Jul 10, 2014 07:46 AM
    Yes, you are right
    only channel 6 can support 20 dBm
    It the first time to know the the max TX power can be different between different channels
  • 11.  RE: Can't force AP93 to work with Ghz
    Posted Jul 10, 2014 07:51 AM
    Okay.
    Use the "show ap config ap-name <name of ap> | include EIRP" command.  That will tell you the current max and min EIRP and where it gets it from:
    (192.168.1.3) #show ap config ap-name Office-225 | include EIRP
    Transmit EIRP        15 dBm                          15 dBm                 rf dot11g-radio-profile "default" / rf dot11a-radio-profile "default"
    Advertized regulatory max EIRP                                               0                               0                      rf dot11g-radio-profile "default" / rf dot11a-radio-profile "default"
    Max Tx EIRP        18 dBm                          18 dBm                 rf arm-profile "default"
    Min Tx EIRP        12 dBm                          12 dBm                 rf arm-profile "default"
