Network Management
Can't log in Airwave 8.0.0
  • 1.  Can't log in Airwave 8.0.0
    Posted Jul 02, 2014 02:43 AM
    After upgrade to Airwave 8.0.0, I can't log in with the GUI. I can see the little animation but it's loading loading loading and I am stuck there. I can access to the console, no problem.
    Any idea where I can take a look at ?
    Dimitri
  • 2.  RE: Can't log in Airwave 8.0.0
    Posted Jul 02, 2014 06:37 AM
    You should contact TAC, unfortunately.
  • 3.  RE: Can't log in Airwave 8.0.0
    Posted Jul 02, 2014 09:52 AM
    No ideas here. Were you able to find something out?
  • 4.  RE: Can't log in Airwave 8.0.0
    Posted Jul 02, 2014 10:10 AM
    Does a GUI appear?
    If so, try resetting the admin account from the CLI like so
    dbc "update users set password='2cf94b0aea63ebf7bf41c90fe500603e' where username ='admin';"
    This will reset the admin account to admin/admin
    Give that a shot.
  • 5.  RE: Can't log in Airwave 8.0.0
    Posted Jul 02, 2014 10:32 AM
    Yes the GUI appears and it's not a problem of user and password, I can log in thru the console.
  • 6.  RE: Can't log in Airwave 8.0.0
    Posted Jul 02, 2014 11:13 AM
    The console account is different than the webUI account.
    Unless your console allows you webui access
  • 7.  RE: Can't log in Airwave 8.0.0
    Posted Jul 02, 2014 02:51 PM
    did you try different browsers? I've had problems with IE11 and Chrome, but got it working in latest build Firefox.
  • 8.  RE: Can't log in Airwave 8.0.0
    Posted Jul 03, 2014 02:14 AM
    Yes, I have tried it with differents browsers, still the same problem, I am stucked in the log in, see the capture.
  • 9.  RE: Can't log in Airwave 8.0.0
    Posted Jul 03, 2014 07:34 AM
    try to reset the password through the console with the command I gave you and try again.
    If that does not work, you need to open a support case
