Can't log into factory default IAP-215 AOS 8.6.0.2
This thread has been viewed 16 times
  • 1.  Can't log into factory default IAP-215 AOS 8.6.0.2
    Posted Feb 12, 2020 07:44 PM
    Hi all,
    I'm hoping I'm missing something trivial but I factory defaulted (used the reset button) an IAP-215 to AOS 8.6.0.2 but I can't seem to login. I performed the factory reset procedure before and after the upgrade and admin/admin isn't working. Any ideas what I could be missing?
    Thanks!
    -Ryan
  • 2.  RE: Can't log into factory default IAP-215 AOS 8.6.0.2
    MVP GURU
    Posted Feb 12, 2020 08:01 PM
    Use admin as the username and the Serial Number as the password.
  • 3.  RE: Can't log into factory default IAP-215 AOS 8.6.0.2
    Posted Feb 12, 2020 08:10 PM
    Thanks!! - This worked.
    Of note, this runs contrary to Aruba's published (and very recently updated) documentation. Oy
  • 4.  RE: Can't log into factory default IAP-215 AOS 8.6.0.2
    MVP GURU
    Posted Feb 12, 2020 08:16 PM
  • 5.  RE: Can't log into factory default IAP-215 AOS 8.6.0.2
    Posted Apr 29, 2020 04:44 AM
    I have bought an used Aruba iap 215 rw . I reset it a few times an made configuration. After that, when I connected it to internet , it  Works  almost 1 minutes then it changes its config to different wifi name and I coundnt to connect it. How can I solve it.
    SN: CK0265552
    Thanks now
  • 6.  RE: Can't log into factory default IAP-215 AOS 8.6.0.2
    Posted Apr 29, 2020 05:12 AM
    You need to contact Aruba TAC.  The device was most likely assigned to a Central Account.
    You may be required to show proof of purchase of the device.
