Wireless
last person joined: 3 hours ago
Can't Login to to IAP AP555
  • 1.  Can't Login to to IAP AP555
    Posted Jul 30, 2023 09:52 AM
    HI
    i have a cluster with two  IAP  after upgrade to 8.11.1 each AP working separately , so i decide to downgrade to  Scorpio 8.10.0.7 thought that will solve the issue
    one of the AP (Main Conductor) came back up with no issue , the other one is reachable only through SSH not reachable through HTTPS
    when i tried to login through SSH with the username and the password that has been set before it didn't work , i tried to use the S/N for AP as well and didn't work
    any thoughts
  • 2.  RE: Can't Login to to IAP AP555
    Posted Jul 31, 2023 05:41 AM
    Hi Joe.
    First check if both APs are in the same vlan. They will not form the cluster if they are in different broadcast domains.
    Check if Autojoin is allowed.
    Then you can factory reset the AP that is not joining the cluster and if it the same family, it will upgrade/downgrade itself automatically when booted and joined into the cluster with working AP.
    Configuration is maintained by cluster VC ap.
    Best, Gorazd
    Gorazd Kikelj
    MVP Expert 2023
