Can't login via https on iap when managed by airwave
  • 1.  Can't login via https on iap when managed by airwave
    Posted Dec 16, 2021 06:09 AM
    just wondering...  I'm experimenting with an iap which is managed by airwave.  I can set an admin password in airwave and push that config to the iap.  When using https i can connect to the loginpage of the controller, but my login is never accepted (login failed).  I parsed all settings but can't find any setting which prohibits local admin login (i would expect to fallback into a readonly mode since they are managed by Airwave).  Am i overlooking something?
