Can't pass traffic from Eth1 to Eth0 on Wifi AP
  • 1.  Can't pass traffic from Eth1 to Eth0 on Wifi AP
    Posted Jul 22, 2018 07:53 PM
    I've put in an AP-203H and would like to use the Eth1 on an access VLAN. I can't get it to pass traffic from the access vlan port eth1 and out the trunk port eth0. The Wifi works on the AP on the same VLAN so I know the vlan'ing from eth0 up is fine.
    eth0 is using the default wired port profile and eth1 is using a new profile set as an access port.
    I've tried various vlans with no success.
    What am I missing here? I've never had to use the eth1 ports on an AP before.
  • 2.  RE: Can't pass traffic from Eth1 to Eth0 on Wifi AP
    Posted Jul 24, 2018 05:47 PM
    Is your 203H running in IAP or cap mode?
  • 3.  RE: Can't pass traffic from Eth1 to Eth0 on Wifi AP
    Posted Jul 24, 2018 11:46 PM
    It's running in AP mode using Central to manage it.
  • 4.  RE: Can't pass traffic from Eth1 to Eth0 on Wifi AP
    Posted Jul 25, 2018 10:57 AM
    Okay, so running as Instant.
    Do you have an 802.1q trunk connecting the AP to the switching on eth0, and then you're trying to break out a specific VLAN as untagged on eth1 for a client device? Or something different?
  • 5.  RE: Can't pass traffic from Eth1 to Eth0 on Wifi AP
    Posted Jul 25, 2018 05:05 PM
    That's exactly how I have it configured.
  • 6.  RE: Can't pass traffic from Eth1 to Eth0 on Wifi AP
    Posted Jul 25, 2018 06:09 PM
    Can you grab the port profile configuration that you're trying to apply to eth1? Also, what version of ArubaOS are you running on your 203h?
    Here's what works for me:
    eth0
    wired-port-profile default_wired_port_profile
    switchport-mode trunk
    allowed-vlan all
    native-vlan 1
    shutdown
    access-rule-name default_wired_port_profile
    speed auto
    duplex full
    no poe
    type employee
    captive-portal disable
    no dot1x
    eth1
    wired-port-profile Test
    switchport-mode access
    allowed-vlan all
    native-vlan 150
    trusted
    no shutdown
    access-rule-name Test
    speed auto
    duplex auto
    poe
    type employee
    auth-server InternalServer
    no dot1x
  • 7.  RE: Can't pass traffic from Eth1 to Eth0 on Wifi AP
    Posted Jul 25, 2018 06:30 PM
    It's Aruba OS: 8.3.0.1_65474
    I can't get the config at the moment as the devices have been taken to site yesterday and not installed yet. Your config looks very similiar to mine though except I'm not using trusted on eth1. I have tried it though and it didn't make any difference.
    Once I have them online I will post it.
