Cant ping Aruba controller from same subnet
Jump to Best Answer
This thread has been viewed 22 times
  • 1.  Cant ping Aruba controller from same subnet
    Posted Jul 03, 2022 09:35 AM
    I have a Aruba 7010 controller with multiple vlans configured, but for some reason i cant ping gateway (aruba controller) from one of the subnets.
    Example
    Vlan 100 /27 - works as expected
    New vlan 200 /26
    If i configure dhcp on the switch connected to the controller i receive dhpc address but i cant ping anything from vlan 200 and ping from vlan 100 to 200 dosent work.
    When i remove dhcp configuration from the switch i can ping vlan 200 gateway from vlan 100
    The mask and gateway configuration for vlan 200 seems right on the dhcp server.
  • 2.  RE: Cant ping Aruba controller from same subnet
    Posted Jul 08, 2022 09:34 AM
    I'm having a hard time understanding what IPs are on what devices and from which devices you are attempting to ping from. Are you able to sketch up a rough network diagram to show the topology and IP addressing so we can help more?
  • 3.  RE: Cant ping Aruba controller from same subnet
    Posted Jul 19, 2022 08:37 AM
    I couldn't ping the controller from any new vlan I configured. But after restarting the controller, everything worked again.
