can't ping IAP
  • 1.  can't ping IAP
    Posted Apr 13, 2017 11:21 AM
    hello,
    i have a cluster of around 67 IAP. I'm able to ping the virtual controller but i connot ping each APs individually.
    Can anyone help me with the issue please???
    Regards!!!
  • 2.  RE: can't ping IAP
    Posted Apr 13, 2017 11:25 AM
    Are you pinging from the second subnet?
    Is it a wired or wireless client?
  • 3.  RE: can't ping IAP
    Posted Apr 13, 2017 11:33 AM
    hi,
    it's a wire client.
    all IAPs and the virtual controller are in the same subnet.
  • 4.  RE: can't ping IAP
    Posted Apr 13, 2017 12:32 PM
    Can you share a show tech so we better know IP addressing gateway scheme used. Also provide IP of the wired client.
  • 5.  RE: can't ping IAP
    Posted Apr 14, 2017 05:20 AM
    hello,
    the client ip is 10.225.61.244
    here is the show tech of the virtual controller :
    System Location :
    Domain :FR
    VC IP Address :10.225.61.253
    AP1X :NONE
    VC VLAN :0
    VC Mask :0.0.0.0
    VC Gateway :0.0.0.0
    VC DNS :0.0.0.0
    Content Filtering :disable
    Terminal Access :enable
    Telnet Server :disable
    Organization :
    Airwave Server :
    Airwave Backup Server:
    Airwave Prov Backup :
    Number of VC transition :0
    Airwave Shared Key :27789f3a1b446001ae4a722738b93ea9
    Airwave Config Via :DHCP
    Airwave :Not Set Up
    Aruba Central Server :
    Aruba Central :Not Set Up
    Managed Via :Local
    Syslog Server :0.0.0.0
    Syslog Level :warn
    Band :all
    Master IP Address *:10.225.61.101
    IP Address :10.225.61.101
    Netmask :255.255.255.0
    Gateway :10.225.61.254
    NameServer :8.8.8.8
    Master Key :9cd53758011793bc1081ca03ba84e6095e7751f26421b784ce
    Elected Time :1d:20h:20m:18s
    Dynamic Radius Proxy :disable
    Dynamic Tacacs Proxy :disable
    NTP Server :
    Configuration Dirty :disable
    Allow New APs :enable
    Classification :disable
    Wireless Containment :disable
    Wired Containment :disable
    Wired Containment AP Adjacent MAC :disable
    Wired Containment Suspect L3 Rogue :disable
    Rogue Containment :disable
    LED Off :disable
    AppRF Visibility :none
    URL Visibility :disable
    WebCC Visibility :disable
    Image Server State :error
    Image Server Message :payload_empty
    New Image Version :
    New Image URL :
    Factory SSID :instant
    Image Sync Via :Master
    Client Alerts :0
    Active Faults :1
    Fault History :16
    Usb Support :NO
    Serial Number :CU0157414
    OpenDNS Status :Not connected
    TFTP Dump Server :0.0.0.0
    Extended SSID :enable
    Inactivity-ap-timeout:60
    Config Sync Status :TRUE
    VPN Status :Not Set Up
    Mobility Acccess Switch Integration :disable
    Deny inter user bridging :disable
    Deny local routing :disable
    Support Connection Status :Not Connected
    Dynamic CPU Management:auto
    Restrict Corporate Access:disable
    Site Local IP Address:--
    Link Local IP Address:fe80::96b4:fff:fec4:a03a
    when i'm trying a show tech on one seleted IAP here is the output :
    4/14/2017 9:09:45 AM Target: AP_10e4_ Command: show tech-support
    Internal Error, Please Retry
    and this is all the iaps i have in my cluster :
    67 Access Points
    MAC IP Address Name Clients Need Antenna Config
    94:b4:0f:c4:a0:3a 10.225.61.101 AP_10e_1 1 No
    94:b4:0f:c4:90:bc 10.225.61.82 AP_8e_2 2 No
    94:b4:0f:c4:91:d2 10.225.61.123 AP_12e_3 0 No
    94:b4:0f:c4:9c:a8 10.225.61.81 AP_8e_1 0 No
    94:b4:0f:c4:9d:76 10.225.61.52 AP_5e_2 0 No
    94:b4:0f:c4:9d:0c 10.225.61.122 AP_12e_2 0 No
    94:b4:0f:c4:a0:12 10.225.61.42 AP_4e_2 1 No
    94:b4:0f:c4:9c:5a 10.225.61.71 AP_7e_1 0 No
    18:64:72:ca:f9:56 10.225.61.12 AP_1e_2 4 No
    94:b4:0f:c4:9c:f2 10.225.61.133 AP_13e_3 0 No
    94:b4:0f:c4:9c:ee 10.225.61.135 AP_13e_5 0 No
    94:b4:0f:c4:9c:1e 10.225.61.115 AP_11e_5 3 No
    94:b4:0f:c4:9c:2e 10.225.61.85 AP_8e_5 1 No
    94:b4:0f:c4:9e:46 10.225.61.65 AP_6e_5 0 No
    18:64:72:ca:f9:1e 10.225.61.4 AP_RDC_4 11 No
    94:b4:0f:c4:9e:4c 10.225.61.66 AP_6e_6 1 No
    94:b4:0f:c4:9d:90 10.225.61.75 AP_7e_5 0 No
    18:64:72:ca:f9:58 10.225.61.13 AP_1e_3 6 No
    94:b4:0f:c4:9f:ee 10.225.61.103 AP_10e_3 0 No
    94:b4:0f:c4:9d:6e 10.225.61.45 AP_4e_5 1 No
    94:b4:0f:c4:a0:46 10.225.61.73 AP_7e_3 2 No
    94:b4:0f:c4:9f:9a 10.225.61.91 AP_9e_1 0 No
    94:b4:0f:c4:9d:de 10.225.61.55 AP_5e_5 1 No
    94:b4:0f:c4:9e:3e 10.225.61.62 AP_6e_2 0 No
    18:64:72:ca:f9:32 10.225.61.11 AP_1e_1 7 No
    94:b4:0f:c4:9e:6e 10.225.61.61 AP_6e_1 0 No
    94:b4:0f:c4:9c:34 10.225.61.56 AP_5e_6 0 No
    94:b4:0f:c4:a0:26 10.225.61.106 AP_10e_6 0 No
    94:b4:0f:c4:9d:9e 10.225.61.44 AP_4e_4 2 No
    b4:5d:50:ca:60:76 10.225.61.146 AP_14e6 1 No
    b4:5d:50:ca:5f:e6 10.225.61.36 AP_3e_6 3 No
    94:b4:0f:c4:9c:04 10.225.61.132 AP_13e_2 0 No
    94:b4:0f:c4:a0:22 10.225.61.113 AP_11e_3 2 No
    94:b4:0f:c4:93:1e 10.225.61.111 AP_11e_1 0 No
    94:b4:0f:c4:a0:4e 10.225.61.112 AP_11e_2 2 No
    b4:5d:50:ca:5c:fa 10.225.61.35 AP_3e_5 0 No
    94:b4:0f:c4:9c:dc 10.225.61.125 AP_12e_5 0 No
    94:b4:0f:c4:9d:5e 10.225.61.53 AP_5e_3 2 No
    94:b4:0f:c4:a0:04 10.225.61.104 AP_10e4_ 2 No
    94:b4:0f:c4:9d:b6 10.225.61.41 AP_4e_1 3 No
    94:b4:0f:c4:9c:c6 10.225.61.84 AP_8e_4 3 No
    ac:a3:1e:c0:36:9e 10.225.61.33 AP_3e_3 7 No
    94:b4:0f:c4:9b:7a 10.225.61.131 AP_13e_1 3 No
    94:b4:0f:c4:9c:b4 10.225.61.134 AP_13e_4 0 No
    94:b4:0f:c4:9c:4c 10.225.61.76 AP_7e_6 0 No
    94:b4:0f:c4:9c:52 10.225.61.51 AP_5e_1 0 No
    94:b4:0f:c4:9e:28 10.225.61.74 AP_7e_4 5 No
    94:b4:0f:c4:a0:48 10.225.61.72 AP_7e_2 5 No
    94:b4:0f:c4:9f:d8 10.225.61.86 AP_8e_6 0 No
    18:64:72:ca:f9:42 10.225.61.3 AP_RDC_3 4 No
    18:64:72:ca:f8:ec 10.225.61.1 AP_RDC_1 3 No
    18:64:72:ca:f8:ca 10.225.61.2 AP_RDC_2 7 No
    94:b4:0f:c4:a0:1a 10.225.61.92 AP_9e_2 0 No
    18:64:72:ca:f9:28 10.225.61.21 AP_2e_1 2 No
    18:64:72:ca:f8:04 10.225.61.23 AP_2e_3 0 No
    94:b4:0f:c4:9e:82 10.225.61.63 AP_6e_3 0 No
    94:b4:0f:c4:9c:ae 10.225.61.126 AP_12e_6 0 No
    94:b4:0f:c4:8e:c2 10.225.61.94 AP_9e_4 0 No
    94:b4:0f:c4:a0:3c 10.225.61.116 AP_11e_6 3 No
    94:b4:0f:c4:9c:bc 10.225.61.102 AP_10e_2 0 No
    94:b4:0f:c4:9e:40 10.225.61.64 AP_6e_4 2 No
    94:b4:0f:c4:a0:44 10.225.61.114 AP_11e_4 2 No
    94:b4:0f:c4:9f:ce 10.225.61.95 AP_9e_5 2 No
    94:b4:0f:c4:9c:96 10.225.61.121 AP_12e_1 0 No
    94:b4:0f:c4:a0:14 10.225.61.105 AP_10e_5 0 No
    94:b4:0f:c4:9b:ae 10.225.61.124 AP_12e_4 3 No
    94:b4:0f:c4:92:f2 10.225.61.136 AP_13e_6 0 No
    Restricted Management Access Subnets
    thank you for your help!!!
  • 6.  RE: can't ping IAP
    Posted Apr 14, 2017 03:58 PM
    1. Show tech from master IAP would be best attached as its huge. i think you got the show summary. show tech would have given more details e.g. software version, or any funny logs.
    2. From the shared information:
    VC VLAN :0
    VC Mask :0.0.0.0
    VC Gateway :0.0.0.0
    VC DNS :0.0.0.0
    NameServer :8.8.8.8
    So you are able to ping 10.225.61.253 but not 10.225.61.101, from a PC in another subnet.
    Assuming this is the native / untagged VLAN (share VLAN number) on the ports leading to IAPs. Can you:
    a) make sure mask & gateway info is consistent on all devices.
    b) ping from gateway 10.225.61.254 to 10.225.62.101
    c) does SSH work to .253 and .101, from the network?
