Can't ping Master standby-while after it became stand by is it normal?
  • 1.  Can't ping Master standby-while after it became stand by is it normal?
    Posted Jun 23, 2014 10:40 AM
    Dears I can't ping the Master standby IP whil I can ping VRRP and it is working
  • 2.  RE: Can't ping Master standby-while after it became stand by is it normal?
    Posted Jun 23, 2014 02:07 PM
    could you explain a little more about the configuration? perhaps post the different VRRP and IP configs?
    all in same subnet?
    i dont recall that certain things don't work anymore once you have the ipsec tunnel between controllers. it probably works but the traffic goes in a different direction. in principle it isn't that bad as long as your tunnels are up.
  • 3.  RE: Can't ping Master standby-while after it became stand by is it normal?
    Posted Jun 23, 2014 07:30 PM
    I solved it
  • 4.  RE: Can't ping Master standby-while after it became stand by is it normal?
    Posted Jun 23, 2014 08:04 PM
    Do you mind telling us the solution?
  • 5.  RE: Can't ping Master standby-while after it became stand by is it normal?
    Posted Jun 25, 2014 04:35 AM
    I was using one of iterface in local that is not the Controller IP
  • 6.  RE: Can't ping Master standby-while after it became stand by is it normal?
    Posted May 19, 2015 03:42 AM
    From the local controller, I tried pinging Loopback IP of the standby controller, it was not working....
    From the local controller, I tried pinging Interface IP of the standby controller, it was working....
    From the standby master controller, I tried pinging Interface IP of the local controller, it was not working....
    From the standby master controller, I tried pinging Loopback IP of the local controller, it was working....
    Anyone knows what is the difference and why is it behaving this way? ____
    What would be the command(s) to troubleshoot the issue?
  • 7.  RE: Can't ping Master standby-while after it became stand by is it normal?
    Posted May 26, 2015 01:36 AM
    Michael
    it is likely due to the fact the IPsec tunnel is not up, meaning that there is a route-map on controller1 that has the loopback ip of controller2 down the ipsec tunnel, but since the tunnel is not up/broken/other it is just a sink. Causes include (ab)using nat-inside on vlan1, dupe ips, ipsec issues etc.
    regards
    -jeff
  • 8.  RE: Can't ping Master standby-while after it became stand by is it normal?
    Posted May 28, 2015 08:16 AM
    meaning to say, if local is unable to ping to master-standby, it is due to the "sink" characteristics of the master-standby IP address, right? ____
  • 9.  RE: Can't ping Master standby-while after it became stand by is it normal?
    Posted May 28, 2015 08:22 AM
    more to the point, it's due to the fact there is a problem with the ipsec tunnel - be it master/local or master/master-redundant
    regards
    -jeff
