Can't print from vlan guest
  • 1.  Can't print from vlan guest
    Posted Jan 16, 2019 11:04 PM
    I've set up VC IAP cluster on aruba IAP with version 6.5.4.0-6.5.4. I use the VC to provide DHCP on both SSID: guest and emp. My local network is 192.168.1.0/24. And no filtering/acl on SSID emp.
    Every client on both SSIDs can go to local subnet server or Internet, but can't print (show offline) to printers in 192.168.1.0  although I've set SSID to  broadcast-filter none and enable airprint and airplay. Also I can ping from wlan client to that printer server. Please advise.
    My configuration (excerpted from backup.cfg):
    arm
     wide-bands 5ghz
     80mhz-support
     min-tx-power 12
     max-tx-power 21
     band-steering-mode prefer-5ghz
     air-time-fairness-mode default-access
     client-aware
     scanning
     client-match
    wlan ssid-profile emp
    enable
    index 0
    type employee
    essid emp
    wpa-passphrase dfeef2c86663320963fa20ceda27045c3146f30a7c982d98
    opmode wpa2-psk-aes
    max-authentication-failures 0
    vlan guest
    rf-band all
    captive-portal disable
    dtim-period 1
    dmo-channel-utilization-threshold 90
    local-probe-req-thresh 0
    max-clients-threshold 64
    ids rogue-containment
    ids
     wireless-containment none
     infrastructure-detection-level medium
     client-detection-level medium
     infrastructure-protection-level low
     client-protection-level low
    wired-port-profile default_wired_port_profile
     switchport-mode trunk
     allowed-vlan all
     native-vlan 1
     shutdown
     access-rule-name default_wired_port_profile
     speed auto
     duplex full
     no poe
     type employee
     no dot1x
    enet0-port-profile default_wired_port_profile
    uplink
     preemption
     enforce none
     failover-internet-pkt-lost-cnt 10
     failover-internet-pkt-send-freq 30
     failover-vpn-timeout 180
    airgroup
     enable mdns-only
     multi-swarm
    airgroupservice airplay
     enable
     description AirPlay
    airgroupservice airprint
     enable
     description AirPrint
    cluster-security
     allow-low-assurance-devices
     When I used show ap datapath session table, would appear:
    192.168.1.152 is priner ip server. IAP physical ip address is 192.168.1.200.
