Can't provision the AP105 on Aruba 3200?
  • 1.  Can't provision the AP105 on Aruba 3200?
    Posted May 31, 2017 12:20 AM
    Hi Supports,
    I can't provision the new AP105 on Arub3200 which is running v6.4.4.6. Please kindly advise.
    Here’s provision log without any error:
    May 24 12:20:32  webui[1710]: USER:admin@10.154.248.102 COMMAND:<ip dhcp pool "VLAN_2" dns-server 10.55.31.229 > -- command executed successfully
    May 24 12:20:40  webui[1710]: USER:admin@10.154.248.102 COMMAND:<write memory > -- command executed successfully
    May 24 12:20:51  webui[1710]: USER:admin@10.154.248.102 COMMAND:<clear provisioning-ap-list > -- command executed successfully
    May 24 12:20:51  webui[1710]: USER:admin@10.154.248.102 COMMAND:<provision-ap read-bootinfo ap-name "AP105_01" > -- command executed successfully
    May 24 12:21:51  webui[1710]: USER:admin@10.154.248.102 COMMAND:<clear provisioning-ap-list > -- command executed successfully
    May 24 12:21:51  webui[1710]: USER:admin@10.154.248.102 COMMAND:<provision-ap read-bootinfo ap-name "AP105_01" > -- command executed successfully
    May 24 12:22:17  webui[1710]: USER:admin@10.154.248.102 COMMAND:<provision-ap ap-group "Empolyee-Grp" > -- command executed successfully
    May 24 12:22:17  webui[1710]: USER:admin@10.154.248.102 COMMAND:<provision-ap ap-name "AP105_01" > -- command executed successfully
    May 24 12:22:17  webui[1710]: USER:admin@10.154.248.102 COMMAND:<provision-ap copy-provisioning-params ap-name "AP105_01" > -- command executed successfully
    May 24 12:22:17  webui[1710]: USER:admin@10.154.248.102 COMMAND:<provision-ap installation default > -- command executed successfully
    May 24 12:22:17  webui[1710]: USER:admin@10.154.248.102 COMMAND:<provision-ap master "192.168.2.200" > -- command executed successfully
    May 24 12:22:17  webui[1710]: USER:admin@10.154.248.102 COMMAND:<provision-ap no external-antenna > -- command executed successfully
    May 24 12:22:17  webui[1710]: USER:admin@10.154.248.102 COMMAND:<provision-ap server-ip 192.168.2.200 > -- command executed successfully
    May 24 12:22:18  webui[1710]: USER:admin@10.154.248.102 COMMAND:<clear provisioning-ap-list > -- command executed successfully
    May 24 12:22:18  webui[1710]: USER:admin@10.154.248.102 COMMAND:<clear provisioning-params > -- command executed successfully
    May 24 12:22:18  webui[1710]: USER:admin@10.154.248.102 COMMAND:<provision-ap mesh-role none > -- command executed successfully
    May 24 12:22:18  webui[1710]: USER:admin@10.154.248.102 COMMAND:<provision-ap no remote-ap > -- command executed successfully
    May 24 12:22:18  webui[1710]: USER:admin@10.154.248.102 COMMAND:<provision-ap no syslocation > -- command executed successfully
    May 24 12:22:18  webui[1710]: USER:admin@10.154.248.102 COMMAND:<provision-ap reprovision ap-name "AP105_01" > -- command executed successfully
    May 24 12:22:20  sapd[825]: <311002> <WARN> |AP AP105_01@192.168.2.2 sapd|  Rebooting: Rebooting after provisioning
    May 24 12:22:20  sapd[825]: <311002> <WARN> |AP AP105_01@192.168.2.2 sapd|  Rebooting: SAPD: Rebooting after provisioning
    May 24 12:22:21  nanny[796]: <303086> <ERRS> |AP AP105_01@192.168.2.2 nanny| Process Manager (nanny) shutting down - AP will reboot!
    May 24 12:22:53  fpcli: USER: admin has logged in using serial.
    May 24 12:23:34  nanny[798]: <303022> <WARN> |AP AP105_01@192.168.2.2 nanny|  Reboot Reason: AP rebooted Wed May 24 12:22:21 PST 2017; SAPD: Rebooting after provisioning
    May 24 12:23:34  stm[834]: trace_on: tracing to "/var/log/trace/stm.log" started
    (Aruba3200_1) #show ap data
    AP Database
    Name Group AP Type IP Address Status Flags Switch IP Standby IP
    AP105_01 default 105 192.168.2.2 Up 36m:32s 2I 192.168.2.200 0.0.0.0
    AP105_02 default 105 192.168.2.3 Up 7d:0h:33m:10s 2I 192.168.2.200 0.0.0.0
    Flags: U = Unprovisioned; N = Duplicate name; G = No such group; L = Unlicensed
    I = Inactive; D = Dirty or no config; E = Regulatory Domain Mismatch
    X = Maintenance Mode; P = PPPoE AP; B = Built-in AP; s = LACP striping
    R = Remote AP; R- = Remote AP requires Auth; C = Cellular RAP;
    c = CERT-based RAP; 1 = 802.1x authenticated AP; 2 = Using IKE version 2
    u = Custom-Cert RAP; S = Standby-mode AP; J = USB cert at AP
    i = Indoor; o = Outdoor
    M = Mesh node; Y = Mesh Recovery
    Total APs:2
    Aruba3200_1) #show wlan ssid-profile Empolyee-Wlan01-ssid_prof
    SSID Profile "Empolyee-Wlan01-ssid_prof"
    Parameter                                         Value
    SSID enable                                       Enabled
    ESSID                                             Empolyee-Wlan01
    Encryption                                        wpa2-psk-aes
    Enable Management Frame Protection                Disabled
    Require Management Frame Protection               Disabled
    DTIM Interval                                     1 beacon periods
    802.11a Basic Rates                               12 24
    802.11a Transmit Rates                            12 24 36 48 54
    802.11g Basic Rates                               12 24
    802.11g Transmit Rates                            12 24 36 48 54
    Station Ageout Time                               1000 sec
    Max Transmit Attempts                             8
    RTS Threshold                                     2333 bytes
    Short Preamble                                    Enabled
    Max Associations                                  64
    Wireless Multimedia (WMM)                         Disabled
    Wireless Multimedia U-APSD (WMM-UAPSD) Powersave  Enabled
    WMM TSPEC Min Inactivity Interval                 0 msec
    Override DSCP mappings for WMM clients            Disabled
    DSCP mapping for WMM voice AC (0-63)              N/A
    DSCP mapping for WMM video AC (0-63)              N/A
    DSCP mapping for WMM best-effort AC (0-63)        N/A
    DSCP mapping for WMM background AC (0-63)         N/A
    Multiple Tx Replay Counters                       Disabled
    Hide SSID                                         Disabled
    Deny_Broadcast Probes                             Disabled
    Local Probe Request Threshold (dB)                0
    Auth Request Threshold (dB)                       0
    Disable Probe Retry                               Enabled
    Battery Boost                                     Disabled
    WEP Key 1                                         N/A
    WEP Key 2                                         N/A
    WEP Key 3                                         N/A
    WEP Key 4                                         N/A
    WEP Transmit Key Index                            1
    WPA Hexkey                                        N/A
    WPA Passphrase                                    ********
    Maximum Transmit Failures                         0
    EDCA Parameters Station profile                   N/A
    EDCA Parameters AP profile                        N/A
    BC/MC Rate Optimization                           Disabled
    Rate Optimization for delivering EAPOL frames     Enabled
    Strict Spectralink Voice Protocol (SVP)           Disabled
    High-throughput SSID Profile                      Empolyee-Wlan01-htssid_prof
    802.11g Beacon Rate                               12
    802.11a Beacon Rate                               12
    Video Multicast Rate Optimization                 default
    Advertise QBSS Load IE                            Disabled
    Advertise Location Info                           Disabled
    Advertise AP Name                                 Disabled
    802.11r Profile                                   N/A
    Enforce user vlan for open stations               Disabled
    Enable OKC                                        Enabled
    (Aruba3200_1) #show license verbose
    License Table
    Key                                               Installed    Expires     Flags  Service Type
    ASz5ZNTD-zQCaNWxY-OebftmYd-aKspn/rx-B/Ej5ckY-p04  2017-05-11   2017-06-10   E     Access Points: 2048
                                                      23:15:00[1]  23:15:00
    joG3yoi2-oIIp0dmW-zPdtYVqg-kYbMKiV3-UxGLmNY6-tvc  2017-05-19   Never        E     Policy Enforcement Firewall for VPN users
                                                      17:05:12
    License Entries: 2
    Flags: A - auto-generated; E - enabled; R - reboot required to activate
    (Aruba3200_1) #show controller-ip
    Switch IP Address: 192.168.2.200
    Switch IP is configured to be Vlan Interface: 2
    Switch IPv6 address is not configured.
    (Aruba3200_1) #show ip dhcp database
    DHCP enabled
  • 2.  RE: Can't provision the AP105 on Aruba 3200?
    Posted May 31, 2017 08:38 AM
    Try disabling CPSec
  • 3.  RE: Can't provision the AP105 on Aruba 3200?
    Posted Jun 01, 2017 04:04 AM
    Hi Seth,
    Yes, the problem was caused by the CPsec enabled and fixed.
    Thanks a lot.
