Can't redirect to external captive portal of 2 SSID
  • 1.  Can't redirect to external captive portal of 2 SSID
    Posted Nov 28, 2017 07:25 AM
    Hi
    I've a controller AOS 6.5.4 without PEF-NG license. I need to config SSID authentication with Captive portal.
    SSID1:Guest authentication on ClearPass
    After create Guest ssid from campus WLAN. I go to L3 Authentication and change web login url point to ClearPass login page.
    I connect to Guest ssid the controller will redirect to clearpass guest login page. That work properly.
    Next...
    I create SSID2: Internal PSK with enable captive portal(forescout).
    After create Internal ssid from campus WLAN. I go to L3 Authentication and change web login url point to External Radius web portal.
    after that... I connect to internal SSID. Filled the key ***********.
    Controller will redirect to external radius web portal.
    That work properly. Right!!!
    OK...
    Just now, I'm still connected on Internal SSID.
    I thing make sure better and go to recheck guest ssid.
    Reconnect to Guest SSID again... But, got error about " too many redirect" and controller can't redirect to ClearPass guest captive.
    I don't know why??
    Help me to solve this issue, Please...
    Thank you.
