Cant see wired user(303H,205h) on my VMC Controller 8.2
  • 1.  Cant see wired user(303H,205h) on my VMC Controller 8.2
    Posted May 11, 2018 04:49 PM
    Hello friends, is there any visibility for this type of users ?
    I can't see them on my controller, no matter what port they are connected(e1,e2,e3).
  • 2.  RE: Cant see wired user(303H,205h) on my VMC Controller 8.2
    Posted May 11, 2018 05:05 PM
    You would have to make the port "untrusted" to see them in the user table.  Configuration> AP Groups> Profiles> AP > Ethernet Interface 1 port configuration.  Under General, make sure the Trusted box is unchecked:
    After that, you need to go to Configuration> AP Groups> Profiles> AP > Ethernet Interface 1 port configuration> AAA.  You then need to select a AAA profile, because when your port is untrusted, it now becomes subject to some sort of authentication (hence the AAA profile).  Choose a AAA profile that has an initial role of authenticated, otherwise your traffic will be stopped based on whatever is in that initial role:
  • 3.  RE: Cant see wired user(303H,205h) on my VMC Controller 8.2
    Posted May 14, 2018 08:53 AM
    Ok. But, I how can view the user in the GUI interface. What colluns need actived.
    By command "show user" in the CLI is Ok:
    (ArubaMC-VA) [mynode] #show user
    This operation can take a while depending on number of users. Please be patient ....
    Users
    IP MAC Name Role Age(d:h:m) Auth VPN link AP name Roaming Essid/Bssid/Phy Profile Forward mode Type Host Name User Type
    172.16.1.12 f0:4d:a2:12:34:56 logon 00:00:02 20:4c:03:12:34:56 Wired 192.168.1.95:0/1 default-open tunnel Win 10 WIRED
  • 4.  RE: Cant see wired user(303H,205h) on my VMC Controller 8.2
    Posted May 14, 2018 08:57 AM
    If the user did not authenticate on the wired network, there will be no username, just an ip address and a mac address
    Edit, if the user shows up on the CLI, it should show up in the GUI, as well.
