Can't select a policy for untrusted VLAN
  • 1.  Can't select a policy for untrusted VLAN
    Posted Dec 27, 2017 02:23 AM
    Hi all.
    I can't select a VLAN Firewall Policy for untrusted VLAN on controller port.
    Get an error : "Illegal Operation: Vlan is untrusted"
    User guide says that it is possible :
    7. In the VLAN Firewall Policy drop-down list, select the policy through which VLAN traffic must pass. You can select a policy for both trusted and untrusted VLANs.
    How can I do this on an untrusted port?
    Thanks.
  • 2.  RE: Can't select a policy for untrusted VLAN
    Posted Dec 27, 2017 02:34 AM
    Do you have a link to that document?
    You can only set firewall policies for a trusted VLAN, as far as I know.  An untrusted VLAN would get the inital role attached to the AAA profile in Configuration> Advanced Services> Wired Access..
  • 3.  RE: Can't select a policy for untrusted VLAN
    Posted Dec 27, 2017 02:47 AM
    There may be an error in user guide....
    link below
    http://www.arubanetworks.com/techdocs/ArubaOS_60/UserGuide/
    Network Parameters  -  Configuring Trusted/Untrusted Ports and VLANs
  • 4.  RE: Can't select a policy for untrusted VLAN
    Posted Dec 27, 2017 03:05 AM
    To be clear, what are you trying to do?
