Can´t stop autoboot over SoE
  • 1.  Can´t stop autoboot over SoE
    Posted Jun 10, 2014 07:04 PM
    we have a couple of AP65s that don´t show up at the controller.
    I tried to reset them via SoE (tried telnet port 2300 and ssh with user serial).
    The AP boots but I can´t interrupt autoboot by hitting the enter key.
    It just waits the two seconds and then continues to boot.
    It seems to load the image via TFTP from the controller, boots it and then stops at those messages:
    AR2313_REV8
    wifi1: Base BSSID 00:0b:86:50:49:00, 8 available BSSID(s)
    edev->dev_addr=00:0b:86:cd:04:90
    wifi1: AP type AP-65, radio 1, max_bssids 8
    wifi1: Atheros 5312 WiSoC: mem=0xb8500000, irq=5
    Is there an option to get into the apboot meu and reset the AP? Other than using a breakout cable?
    Christian
  • 2.  RE: Can´t stop autoboot over SoE
    Posted Jun 11, 2014 05:22 AM
    If it stops at that point, there is probably a hardware issue that cannot be remedied.  Normally if you cannot stop the boot with [ENTER] that is when you do not have flow control on.  If you cannot stop it with SOE, AND it stops there, that means that the AP has a hardware issue...
  • 3.  RE: Can´t stop autoboot over SoE
    Posted Jun 11, 2014 11:02 AM
    It turned out that I could stop autoboot when connecting the APs to ports fe1/5 and 1/6 on the Aruba 800.
    It didn´t work when they were connected to fe1/3 and 1/4.
    Another AP on 1/2 also couldn´t be interupted.
    All  ports were configured the same.
    Christian
