Hi all.
HP VAN SDN Controller has been releases recenlty and I wanted to give it a try.
I have Ubuntu 14.04 LTS and my own Keystone service from OpenStack Icehouse release - 1:2014.1.1.
I follow steps from this installation guide.
Before actualy installing hp-sdn-ctl_2.3.5.6505_amd64.deb with dpkg I set up environment variable ADMIN_TOKEN, because my keystone is set up to use non default (ADMIN) value. All tenants and users and user-roles are already created in my keystone by hand.
# export ADMIN_TOKEN=SomeAdmin_token_ratherLongString
I am coping token from keystone.conf to be sure it is correct.
After that I
# dpkg -i hp-sdn-ctl_2.3.5.6505_amd64.deb
and get
(Reading database ... 22709 files and directories currently installed.)
Unpacking hp-sdn-ctl (from hp-sdn-ctl_2.3.5.6505_amd64.deb) ...
Setup has detected a compatible jre-headless - 1.7.0_55
Verifying keystone server...
Unable to validate keystone at http://127.0.0.1:35357/v2.0 - Invalid administrator token [ ADMIN ] - Unauthorized
Halting installation !!
Looks like installation is not using my custom ADMIN_TOKEN set from evironment variables and using value ADMIN instead. How can I overcome this? I really don't want to use default ADMIN value.
#keystone#installation#SDN
