last person joined: 9 hours ago
CAP wireless licensing
  • 1.  CAP wireless licensing
    Posted Oct 29, 2017 10:02 PM
    Hi All,
    May i check on the following message,
    AP Licenses               3
    RF Protect Licenses       4
    PEF Licenses              2
    Overall AP License Limit  2
    Is the current limitation on LIC PEF ? Based on the assumption if we add one more LIC PEF it will bring Overall AP License Limit  to 3?
  • 2.  RE: CAP wireless licensing
    Posted Oct 29, 2017 10:16 PM
    Yes. You are limited to the lowest license number installed.
  • 3.  RE: CAP wireless licensing
    Posted Oct 29, 2017 10:41 PM
    Thanks joesph for the fast reply :)
  • 4.  RE: CAP wireless licensing
    Posted Oct 30, 2017 12:07 AM
    Hi Colin,
    In this case, PEF was 2 but AP was 3.
    How the controller calculate which one use PEF or PEF is inactive when the license lower than AP?
  • 5.  RE: CAP wireless licensing
    Posted Oct 30, 2017 12:09 AM
    The controller will only allow the lowest number of APs to work (2 in your example).
    If you only have AP licenses, 3 APs could work.  If you add any difference licenses, the controller will only allow the number of APs for the least amount of licenses.  That is why your number of licenses need to match.
  • 6.  RE: CAP wireless licensing
    Posted Oct 30, 2017 12:22 AM
    Actually, I told my customer to purchase additional license to mach with AP license. But some customer had a question about what happens when it is not equal.
    For example, the quantity as who posted. The difference license cannot work until it equals to AP license, right?
  • 7.  RE: CAP wireless licensing
    Posted Oct 30, 2017 12:29 AM
    The maximum number of access points allowed would match the smallest license.
  • 8.  RE: CAP wireless licensing
    Posted Oct 30, 2017 12:34 AM
    Understood, Thank you.
