Cloud Managed Networks
last person joined: 9 hours ago
Cape Sensor Netflix healthcheck
  • 1.  Cape Sensor Netflix healthcheck
    Posted Jul 14, 2020 09:41 AM
    I've noticed on our cape sensor dashboard that the netflix ( fast.com)
    healthcheck never actally seems to work.  Occasionally we get a ping from it but by and large nothing other than that shown below. Other than enabling it are we supposed to do some other configuration?
    Rgds
    Alex
    Cape alert notification
    SSID: eduroam
    Service: Netflix (Fast.com)All targets failed to be run for a particular step
       Sensor: X-Block
       Started at: 08:23 on July 9thConnection to proxy server is refused
       Sensor: SLB/210
       Started at: 09:30 on July 9th
  • 2.  RE: Cape Sensor Netflix healthcheck
    Posted Jul 14, 2020 12:51 PM
    Did you check your proxy server? It clearly states the proxy server refused the connection..
    There isn't anything special required for testing..
  • 3.  RE: Cape Sensor Netflix healthcheck
    Posted Jul 14, 2020 06:42 PM
    o.k. only problem is that we don't use proxy servers.
    Checked both the wired and wifi settinmgs and proxy server is set to none
  • 4.  RE: Cape Sensor Netflix healthcheck
    Posted Oct 05, 2020 01:32 PM
    This was a known issue with the Netflix test. A fix has been worked upon and should be out soon.
