CAP/RAP CLI traceroute
  • 1.  CAP/RAP CLI traceroute
    Posted Mar 09, 2018 10:53 AM
    Hi all!
    Is it possible to do a traceroute from a CAP or RAP CLI?
    Thank you!
  • 2.  RE: CAP/RAP CLI traceroute
    MVP EXPERT
    Posted Mar 09, 2018 11:24 AM
    Hey, you can perform a traceroute from the AP if you have a console cabkle attached. You will need to break the prompt (esc + ctrl + k)
    ~ # Switching to Full Access
    ~ # traceroute 8.8.8.8
    traceroute to 8.8.8.8 (8.8.8.8), 30 hops max, 38 byte packets
     1  ** *
    The above may also be possible if you have Telnet enabled in the AP System Profile and also via the Backup ESSID.
  • 3.  RE: CAP/RAP CLI traceroute
    Posted Mar 10, 2018 09:52 AM
    Hi!
    Thank you, works....
