CAPs not coming back up with Control Plane Security enabled after upgrading to 6.3.1.1
  • 1.  CAPs not coming back up with Control Plane Security enabled after upgrading to 6.3.1.1
    Posted Nov 09, 2013 05:14 PM
    Opened up this thread for tracking the fix to this issue as Aruba TAC is currently looking into this. However, if anyone has experienced this issue, please share your fix.
    Regards.
  • 2.  RE: CAPs not coming back up with Control Plane Security enabled after upgrading to 6.3.1.1
    Posted Nov 09, 2013 05:29 PM
    Eosuorah,
    If you type "show log security 50" and show ap database, it might give you a clue what state the access points are in when they do not come up.  In addition, CPSEC requires new ports for access points to connect to the controller, and if your remote or local site is blocking this traffic, your access points will not come up:
    https://arubanetworkskb.secure.force.com/pkb/articles/FAQ/What-is-control-plane-security-How-does-one-configure-verify-it
    https://arubanetworkskb.secure.force.com/pkb/articles/Troubleshooting/APs-are-continuously-rebooting
     Also make sure the ap-role has the correct ACLs:  https://arubanetworkskb.secure.force.com/pkb/articles/Troubleshooting/R-1205
  • 3.  RE: CAPs not coming back up with Control Plane Security enabled after upgrading to 6.3.1.1
    Posted Nov 09, 2013 05:54 PM
    @cjoseph wrote:
    Eosuorah,
    Regarding the ACLs, this applies to upgrades to AOS5.X and higher. My 620 Controller was already running AOS6.1.
    And regarding the CAPs and their states, I made sure they were already in an "approved-ready-for-cert" state and I tweaked between "switch cert" and "factory cert" and still doesn't work.
    This is just so weird. This was all working before upgrading from 6.1 to 6.3.
  • 4.  RE: CAPs not coming back up with Control Plane Security enabled after upgrading to 6.3.1.1
    Posted Nov 09, 2013 05:57 PM
    But what is the output of "show ap database" when they refuse to come up?
    What is the output of "show log system 50"?
    The controller has to report why access points are not coming up and both of these commands give you a clue what is happening.
    We cannot exactly replicate your environment, so we rely on you for clues as to why it is not coming up.  "It does not work, but it worked before" is a start, but we require additional information about the controller while this is happening.  If you cannot attempt it and give us the output of those commands, please wait until you can try to turn cpsec on, collect the output of those commands, and feed that back to us.  For now, we don't have any information to go on.
  • 5.  RE: CAPs not coming back up with Control Plane Security enabled after upgrading to 6.3.1.1
    Posted Nov 09, 2013 06:01 PM
    Been looking at the Logs and I don't see anything that helps me determine what the root cause is. See below:
    (Aruba620BurlingtonMaster) #show log system 50
    Nov 9 17:50:16 :337000:  <DBUG> |stm|  mon_mgr_update_thread_main: updateq empty. into conditional wait...
    Nov 9 17:50:16 :304003:  <DBUG> |stm|  setup_hbt_tunnel: done S 192.168.100.61 D 192.168.221.133 A 0 Tun 0
    Nov 9 17:50:16 :305025:  <DBUG> |stm|  sapm_clear_rejected_vap_list: AP MarkhamCAP radio -1: clearing
    Nov 9 17:50:19 :306502:  <DBUG> |stm|  Publish service 'stm-remote-node-license', object len 28
    Nov 9 17:50:25 :337000:  <DBUG> |stm|  mon_mgr_update_thread_main: updateq empty. into conditional wait...
    Nov 9 17:50:54 :305025:  <DBUG> |stm|  sapm_gap_get_changed_plan_info(1585): Running query SELECT UNIX_TIMESTAMP(MAX(modified_time)) FROM wms.sap_xg
    Nov 9 17:50:54 :305025:  <DBUG> |stm|  sapm_gap_get_plan_delete_time(1412): Running query SELECT UNIX_TIMESTAMP(MAX(modified_time)) FROM wms.plan_info_updated
    Nov 9 17:50:56 :303022:  <WARN> |AP BurlingtonCAP@192.168.100.200 nanny|  Reboot Reason: AP rebooted Sat Nov 9 17:49:54 EST 2013; SAPD: Rebooting after setting cert_cap=1. Need to open a secure channel(IPSEC)
    Nov 9 17:51:05 :305025:  <DBUG> |stm|  sapm_papi_rcv_cb: from 127.0.0.1:8235 to 8222 code 14001 length 359
    Nov 9 17:51:05 :305025:  <DBUG> |stm|  sapm_ap_list_generate: Generating new AP list
    Nov 9 17:51:05 :337000:  <DBUG> |stm|  mon_mgr_update_thread_main: updateq empty. into conditional wait...
    Nov 9 17:51:19 :305025:  <DBUG> |stm|  sapm_papi_rcv_cb: from 127.0.0.1:8235 to 8222 code 14001 length 359
    Nov 9 17:51:19 :305025:  <DBUG> |stm|  sapm_ap_list_generate: Using previously generated AP list
    Nov 9 17:51:19 :306502:  <DBUG> |stm|  Publish service 'stm-remote-node-license', object len 28
    Nov 9 17:51:25 :337000:  <DBUG> |stm|  mon_mgr_update_thread_main: updateq empty. into conditional wait...
    Nov 9 17:51:48 :305025:  <DBUG> |stm|  sapm_papi_rcv_cb: from 127.0.0.1:8226 to 8222 code 14001 length 105
    Nov 9 17:51:48 :304003:  <DBUG> |stm|  get_global_configuration called for key = discovery
    Nov 9 17:51:48 :304003:  <DBUG> |stm|  get_global_configuration called for key = igmp-join
    Nov 9 17:51:48 :304003:  <DBUG> |stm|  get_global_configuration called for key = igmp-vlan
    Nov 9 17:51:48 :304003:  <DBUG> |stm|  get_global_configuration called for key = rtcp-inactivity
    Nov 9 17:51:48 :304003:  <DBUG> |stm|  get_global_configuration called for key = alg-based-cac
    Nov 9 17:51:48 :304003:  <DBUG> |stm|  get_global_configuration called for key = sip-midcall-req-timeout
    Nov 9 17:51:48 :304003:  <DBUG> |stm|  get_global_configuration called for key = ap-blacklist-time
    Nov 9 17:51:48 :304003:  <DBUG> |stm|  get_global_configuration called for key = flush-r1-on-new-r0
    Nov 9 17:52:05 :337000:  <DBUG> |stm|  mon_mgr_update_thread_main: updateq empty. into conditional wait...
    Nov 9 17:52:19 :306502:  <DBUG> |stm|  Publish service 'stm-remote-node-license', object len 28
    Nov 9 17:52:25 :337000:  <DBUG> |stm|  mon_mgr_update_thread_main: updateq empty. into conditional wait...
    Nov 9 17:52:39 :399838:  <WARN> |nanny|  Resource 'Controlpath CPU' has exceeded  30%  threshold (actual:50%).
    Nov 9 17:53:05 :337000:  <DBUG> |stm|  mon_mgr_update_thread_main: updateq empty. into conditional wait...
    Nov 9 17:53:19 :306502:  <DBUG> |stm|  Publish service 'stm-remote-node-license', object len 28
    Nov 9 17:53:25 :337000:  <DBUG> |stm|  mon_mgr_update_thread_main: updateq empty. into conditional wait...
    Nov 9 17:53:40 :399838:  <WARN> |nanny|  Resource 'Controlpath CPU' has dropped below  30%  threshold (actual:0%).
    Nov 9 17:54:05 :337000:  <DBUG> |stm|  mon_mgr_update_thread_main: updateq empty. into conditional wait...
    Nov 9 17:54:18 :305025:  <DBUG> |stm|  sapm_papi_rcv_cb: from 127.0.0.1:8235 to 8222 code 14001 length 211
    Nov 9 17:54:19 :306502:  <DBUG> |stm|  Publish service 'stm-remote-node-license', object len 28
    Nov 9 17:54:25 :337000:  <DBUG> |stm|  mon_mgr_update_thread_main: updateq empty. into conditional wait...
    Nov 9 17:55:05 :337000:  <DBUG> |stm|  mon_mgr_update_thread_main: updateq empty. into conditional wait...
    Nov 9 17:55:19 :306502:  <DBUG> |stm|  Publish service 'stm-remote-node-license', object len 28
    Nov 9 17:55:25 :337000:  <DBUG> |stm|  mon_mgr_update_thread_main: updateq empty. into conditional wait...
    Nov 9 17:55:54 :305025:  <DBUG> |stm|  sapm_gap_get_changed_plan_info(1585): Running query SELECT UNIX_TIMESTAMP(MAX(modified_time)) FROM wms.sap_xg
    Nov 9 17:55:54 :305025:  <DBUG> |stm|  sapm_gap_get_plan_delete_time(1412): Running query SELECT UNIX_TIMESTAMP(MAX(modified_time)) FROM wms.plan_info_updated
    Nov 9 17:56:05 :337000:  <DBUG> |stm|  mon_mgr_update_thread_main: updateq empty. into conditional wait...
    Nov 9 17:56:19 :306502:  <DBUG> |stm|  Publish service 'stm-remote-node-license', object len 28
    Nov 9 17:56:25 :337000:  <DBUG> |stm|  mon_mgr_update_thread_main: updateq empty. into conditional wait...
    Nov 9 17:57:05 :337000:  <DBUG> |stm|  mon_mgr_update_thread_main: updateq empty. into conditional wait...
    Nov 9 17:57:19 :306502:  <DBUG> |stm|  Publish service 'stm-remote-node-license', object len 28
    Nov 9 17:57:25 :337000:  <DBUG> |stm|  mon_mgr_update_thread_main: updateq empty. into conditional wait...
    Nov 9 17:58:05 :337000:  <DBUG> |stm|  mon_mgr_update_thread_main: updateq empty. into conditional wait...
    Nov 9 17:58:19 :306502:  <DBUG> |stm|  Publish service 'stm-remote-node-license', object len 28
    Nov 9 17:58:25 :337000:  <DBUG> |stm|  mon_mgr_update_thread_main: updateq empty. into conditional wait...
    (Aruba620BurlingtonMaster) # show ap database
    AP Database
    Name           Group             AP Type  IP Address       Status  Flags  Switch IP       Standby IP
    BurlingtonCAP  BurlingtonCampus  105      192.168.100.200  Down           192.168.100.61  0.0.0.0
    MarkhamCAP     RAPOffice         105      192.168.221.133  Down           192.168.100.61  0.0.0.0
    Flags: U = Unprovisioned; N = Duplicate name; G = No such group; L = Unlicensed
           I = Inactive; D = Dirty or no config; E = Regulatory Domain Mismatch
           X = Maintenance Mode; P = PPPoE AP; B = Built-in AP
           R = Remote AP; R- = Remote AP requires Auth; C = Cellular RAP;
           c = CERT-based RAP; 1 = 802.1x authenticated AP; 2 = Using IKE version 2
           u = Custom-Cert RAP; S = Standby-mode AP; J = USB cert at AP
           M = Mesh node; Y = Mesh Recovery
    Total APs:2
  • 6.  RE: CAPs not coming back up with Control Plane Security enabled after upgrading to 6.3.1.1
    Posted Nov 09, 2013 06:06 PM
    I only see two access points, is that correct?
    Do you have a firewall between the controller and those two sites?  If that is the case, you need to allow UDP 4500 as well as UDP 8209.  For the access points that will not come up do a "show datapath session table 192.168.100.200" and "show datapath session table 192.168.221.133" to see what traffic is being allowed to the controller.   From the message, the access point got the message that it needs to connect via IPSEC and that is the last message I see
    "Nov 9 17:50:56 :303022:  <WARN> |AP BurlingtonCAP@192.168.100.200 nanny|  Reboot Reason: AP rebooted Sat Nov 9 17:49:54 EST 2013; SAPD: Rebooting after setting cert_cap=1. Need to open a secure channel(IPSEC) "
    You might have to turn of some debugging because important messages are getting pushed because debugging is turned on.
  • 7.  RE: CAPs not coming back up with Control Plane Security enabled after upgrading to 6.3.1.1
    Posted Nov 09, 2013 06:14 PM
    Yes you are correct. And there isn't any Firewall from these Sites to the Controller. Besides the 192.168.100.200 is in the same Location as the Controller. And I see both APs attempting a session to the Controller. That's why I find this issue so weird. However see below:
    (Aruba620BurlingtonMaster) #show datapath session
           Q - Real-Time Quality analysis
           E - Media Deep Inspect, G - media signal
      Source IP     Destination IP  Prot SPort DPort  Cntr Prio ToS Age Destination TAge Packets   Bytes      Flags
    192.168.2.1     224.0.0.9       17   520   520    0/0     7 48  1   1/8         17   0         0          FC
    192.168.100.103 224.0.0.5       89   0     0      0/0     0 48  0   1/8         47   0         0          FC
    192.168.100.61  192.168.102.130 6    22    60437  0/0     0 4   0   1/8         84f  0         0
    192.168.100.3   224.0.0.5       89   0     0      0/0     0 48  0   1/8         4e   0         0          FC
    192.168.100.4   224.0.0.5       89   0     0      0/0     0 48  0   1/8         4a   0         0          FC
    192.168.101.1   224.0.0.5       89   0     0      0/0     7 48  0   1/8         46   0         0          FC
    192.168.101.1   224.0.0.9       17   520   520    0/0     7 48  1   1/8         17   0         0          FC
    192.168.100.103 224.0.0.9       17   520   520    0/0     0 48  1   1/8         17   0         0          FC
    192.168.100.61  192.168.221.133 17   4500  4500   0/0     0 0   27  1/8         1c2  0         0          FY
    192.168.101.255 192.168.101.75  17   37    1030   0/0     0 0   5   1/8         4b   0         0          FY
    192.168.100.92  192.168.100.255 17   138   138    0/0     0 0   0   1/8         4    0         0          FC
    192.168.100.255 192.168.100.92  17   138   138    0/0     0 0   0   1/8         4    0         0          FY
    192.168.101.75  192.168.101.255 17   1030  37     0/0     0 0   1   1/8         4b   0         0          FC
    192.168.221.133 192.168.100.61  17   4500  4500   0/0     0 0   0   1/8         1c2  0         0          FC
    192.168.100.61  99.227.188.4    17   4500  49623  0/0     0 0   1   1/8         c    0         0          FY
    192.168.100.200 192.168.100.61  17   4500  4500   0/0     0 0   1   1/8         10   0         0          FC
    99.227.188.4    192.168.100.61  17   49623 4500   0/0     0 0   1   1/8         c    0         0          FC
    192.168.100.61  192.168.100.200 17   4500  4500   0/0     0 0   1   1/8         10   0         0          FY
    192.168.102.130 192.168.100.61  6    60437 22     0/0     0 4   0   1/8         84f  0         0          C
  • 8.  RE: CAPs not coming back up with Control Plane Security enabled after upgrading to 6.3.1.1
    Posted Nov 09, 2013 06:19 PM
    We also need to output of "show log system 100" and "show log security 100" as well as "show crypto ipsec sa"
  • 9.  RE: CAPs not coming back up with Control Plane Security enabled after upgrading to 6.3.1.1
    Posted Nov 09, 2013 06:27 PM
    Attached herein.
    Attachment(s)
  • 10.  RE: CAPs not coming back up with Control Plane Security enabled after upgrading to 6.3.1.1
    Posted Nov 09, 2013 07:22 PM
    What ip address is 192.168.100.61?  If that is the controller, what VLAN is that?  Is that the controller's switchip (type "show switchinfo")?
  • 11.  RE: CAPs not coming back up with Control Plane Security enabled after upgrading to 6.3.1.1
    Posted Nov 09, 2013 07:25 PM
    Yes that is the Controller's IP Address. VLAN 1.
  • 12.  RE: CAPs not coming back up with Control Plane Security enabled after upgrading to 6.3.1.1
    Posted Nov 09, 2013 07:34 PM
  • 13.  RE: CAPs not coming back up with Control Plane Security enabled after upgrading to 6.3.1.1
    Posted Nov 09, 2013 07:36 PM
    1475597.
  • 14.  RE: CAPs not coming back up with Control Plane Security enabled after upgrading to 6.3.1.1
    Posted Nov 09, 2013 08:03 PM
    eosuorah,
    Thank you.  We will follow up with your case and get more information about this.
  • 15.  RE: CAPs not coming back up with Control Plane Security enabled after upgrading to 6.3.1.1
    Posted Nov 09, 2013 09:48 PM
    @cjoseph wrote:
    eosuorah,
    Thanks...
  • 16.  RE: CAPs not coming back up with Control Plane Security enabled after upgrading to 6.3.1.1
    Posted Nov 29, 2013 09:34 AM
    Hello All,
    This issue has been finally been resolved with the help from the Engineering/Development Team.
    For some reason, it was determined that my Controller had two Wired Oplinks both on separate VLANs (1 and 10). No one knows for sure if the upgrade created this 2nd Wired Uplink.
    So, Aruba APs communicate to the Contoller via this Wired Uplink on an internally created VLAN (VLAN ID 4095) for processes. So with the fact that my Controller had two Wired Uplinks on separate VLANs, this created a conflict and thus led to the CAPs and RAPs not establishing sessions back to the Controller.
    The minute we removed the 2nd Wired Uplink configuration (for VLAN 10), my CAPs established their session back to the Controller with CPSec enabled. See below for the highlighted issue:
    (Aruba620BurlingtonMaster) #show running-config | include vlan
    Building Configuration...
    controller-ip vlan 1
    vlan 10 "Mgmt"
    vlan 101
    vlan 333
    trusted vlan 1-4094
    switchport access vlan 101
    trusted vlan 1-4094
    trusted vlan 1-4094
    trusted vlan 1-4094
    trusted vlan 1-4094
    trusted vlan 1-4094
    trusted vlan 1-4094
    trusted vlan 1-4094
    trusted vlan 1-4094
    switchport trunk allowed vlan 1,10,101,221,333
    interface vlan 1
    interface vlan 10
    interface vlan 101
    interface vlan 333
    uplink wired vlan 1
    uplink wired vlan 10
    adp igmp-vlan 0
       vlan 333
       vlan 333
       vlan 333
       vlan 333
       vlan 1
       vlan 1
       vlan 101
       vlan 1
       vlan 221
       vlan 10
