  • 1.  CAP´s randomly disconnects
    Posted Aug 23, 2024 02:41 AM
    Hi Airheads
    I have a problem that iv tried to rap my head around for weeks, but I need  you help
    We randomly have access point disconnect from the controllers all over the globe, it can be at a site 800 meters away from the controller or in the US, 6400 KM away from the controller. It can be one access point or five access points.
    Its random.
    We tried different thing to resolve the issues and to get the AP´s to connect again, with mix results.
    Clear session the palo alto, reset POE on the 2930F switch, disable/enable the port, clear gap-db on the MM…
    Nothing really helps to force em back on the controller… they like live there own lives… and eventually when iv try different things without success, next day they maybe active on the controller or half of em, and the rest will connect over a day or two
    Iv notices that the AP get an IP from the DHCP server , and that the AP is pingable, even that's its not show up in LLDP on the switch, and the controller, and they draw PoE power
    Iv tried to login to an AP the pingable but have joined the controller, but I cant, is there a way to enable ssh on the AP´s so I can see that's going on from the AP´s side when I doesn't join the Controller, but has an IP?
    Any advice to proceed the troubleshooting?
    Br. Th3Plug
    Attach some screenshots
    info
    Info 2
  • 2.  RE: CAP´s randomly disconnects
    Posted Aug 23, 2024 09:40 AM
    Yes, you can enable SSH access to the AP.
    https://www.arubanetworks.com/techdocs/ArubaOS_8.12.0_Web_Help/Content/arubaos-solutions/access-points/conf-ap-syst-prof.htm
    Based on your description of the issue, sounds like you've installed APs that are having to traverse a WAN connection to reach the controller?  Note, deploying a controller based infrastructure that has the APs connected back to the controller over a WAN connection is not a supported topology.  APs are expected to be local to the controller and be well connected via a LAN.
    Carson Hulcher, ACEX#110
  • 3.  RE: CAP´s randomly disconnects
    Posted Aug 26, 2024 01:40 AM
    Thanks chulcher
    Ill have a look in to that.
    Br.
  • 4.  RE: CAP´s randomly disconnects
    Posted Aug 25, 2024 09:00 AM
    It is already possible to operate CAPs over a WAN line, only certain requirements must be met. The AP behavior can also be optimized, it is documented here.
    The AP goes online as soon as it has established an IPSec tunnel to the controller. If no tunnel has been established, the controller shows it as offline, even though the AP is reachable and you can ping it.
    Use show crypto ipsec sa peer <CAP-IP> to check the IPSec status.
    I don't think you'll get anywhere with an SSH session on the AP, you won't find the familiar syntax there.
    Troubleshoot IP-Sec behavior on the controller instead. Increase log level on mobility controller by using the following commands in MM:
    1) Debugging IKE and ISAKMP
    OS version dependent
    (config)# logging level debugging security process crypto
    (config)# logging level debugging security subcat ike
    or
    (config)# logging security process crypto level debugging
    2) Debugging L2TP and local-db authentication:
    (config)# logging level debugging security process l2tp
    (config)# logging level debugging security process localdb
    Check log on the mobility controller useng commands:
    show log system 300 | include <AP-Name>,<AP-IP>,<AP-Wired-MAC>
    show log security 300 | include <AP-Name>,<AP-IP>,<AP-Wired-MAC>
    Waldemar
    ACCX # 1377, ACEP, ACX - Network Security
  • 5.  RE: CAP´s randomly disconnects
    Posted Aug 26, 2024 01:42 AM
    Edited by Th3Plug Aug 26, 2024 01:42 AM
    Hi Lord Waldemar
    Your replay and suggestions was just what i had hoped for. Many thansk for pointing me in the right direction
    Br.
  • 6.  RE: CAP´s randomly disconnects
    Posted Aug 26, 2024 10:23 AM
    While possible, supported is a different story.
